Question about Fedders D Chassis AED24E7E Air Conditioner
Air conditioner fan/cooling will not run I get power to it though
I have a Fedders D chassis AED24E7E and it wont turn on at all. Do they have fuses that could have blown? I just put in a Fedder ac in my room and it ran for awile. then it started gradually getting slower even though it was on high then the cooling/fan completely stopped working. I get a readout on the front but the fan will not starts Bad motor? Belt? Any suggestions would be helpful Thanks
2 Suggested Answers
  • 3433 Answers
SOURCE: air conditioner wont turn on
Power at outlet/cord awitch
Posted on May 28, 2009
I have a fedders ac unit that does not put out cold air only for a couple of minutes. model # A2Q06F2BG-D can i add freon
Hello, you can add freon by installing a piercing valve on the low side of the system. Before adding freon I would check and make sure the air filter and both coils are clean. If everything is clean then most likey the unit has a leak and is low on freon.
May 26, 2011 | Fedders D Chassis AED24E7E Air Conditioner
CAN I ADD FREON TO MY FEDDERS AC ? it gets cool for a few mins then compressor kicks off ! does it sound like low on freon , ?
Take the front cover off and make sure the copper bulb is not touching the fins. Bend out a distance of 1/2 inch
Jun 15, 2010 | Fedders D Chassis AED24E7E Air Conditioner
Heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
Fedders window unit won't blow cool air
Hi There,
It needs to be re-charged with freon.
Mar 28, 2009 | Fedders Q Chassis AEQ08F2E Air Conditioner
Heat Not Working
Pls follow the step
1) Check your connector wire to the termostat (possible may be loose).
2) Set your thermostat up to 29C and set to heat control.
3) Check the connector wire to reversing vale (possible may be loose).
If they not solve the problem your Control Board have a problem,pls go to the nearest service center for repair.
Thanks & best regards
Jan 18, 2008 | Fedders D Chassis AED24E7E Air Conditioner
Fedders Y Chassis Quit Running
Bummer. I bought an AEY08F2G that put out no warm air and very little cool air. Fedders filed chapter 11 in August. They do not honor warranties now, and apparently offer no repair service. I was fortunate that I bought mine from Venting Direct, and the unit was still within the 60 defective return period. They told me that Fedders units are junk. They provided full credit for the unit (plus shipping costs) without requiring that the unit be returned to them. My advice is to toss it. Live and learn.
Aug 26, 2007 | Fedders Y Chassis AEY12F7E Air Conditioner
Fedders Window AC
You may have thermostat problems. If the blower and compresssor kicks on, that indicates their ok. If you have a two wire thermostat, you can tie those wires together to see if the unit will operate. BE SURE TO DISCONNECT POWER.
Aug 16, 2007 | Fedders X Chassis A6X08F2A Air Conditioner
Fedders air conditioner beeps but doesn't turn on.
Unplugged unit first. Take control panel out but dont unplug wiring. Cut Firth wire out from the center on the touch pad six wire plug. Cap both ends and plug back in. now unit will run on high cool and turn it on and off by plug and unplug
Aug 15, 2007 | Fedders X Chassis A6X05F2B Air Conditioner
Fedders D Chassis AED24E7E Air Conditioner Logo
172 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
