Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
Dryer not performing as it should
It eventually does the job but takes sooo long I believe the vent to outside is half plugged or am I WRONG..
  • 192 Answers
A blocked air vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Posted on May 28, 2009
  • 864 Answers
If the vent pipe or the outlet at the outside wall is clogged with lint it will slow down the drying time.  Make sure the vent is clear.
It takes forever to dry clothes. A small load takes at least an hour & a half, sometimes longer.
The most common problem for a dryer to take more than one cycle to dry is restricted air flow.
1.when the dryer is running go outside and find where the venting is located, there should be a good amount of air flow.
2. if the air flow is not good look at the ducting coming from the back of the dryer and make sure it is not kinked or pushed back to far.
there is usually lint build up some where along the ducting or at the end of the duct where it vents to the outside.
3. if you have access to a leaf blower,this can be used to help clear any lint build up inside the duct from the dryer to the outside venting.
move your dryer out and take the leaf blower tube and stick it in the hole and turn it on.
the vented louvers need to be removed from the ouside of the house to allow the lint and things in the duct work to be blown out.
Feb 17, 2011 | Kenmore 73952 Gas Dryer
My dryer takes two cycles to dry any help lg tromm 2 years old
clean the vent hose clean the port where it exits the house sometimes there is a grate on port which needs to be cleaned also
Mar 20, 2010 | LG DLE2514 Electric Dryer
DLG5988S gas dryer takes long time to dry cloths in either mositure sensor mode or timerd mode. I have throughly cleaned the dryer exhaust and internal part of dryer where all electronics and controls are...
How long is the exhaust venting system from the dryer to the outside, where it vents? The dryer is not equipped to push air through any pipe that is too much past 8-10'. Each 90 degree bend in the pipe adds 3-5', so a few feet plus a few 90 degree turns makes it nearly impossible for the dryer to do a good job drying clothes. I own a Tjernlund LB1 dryer boost fan and it works wonderfully - a great solution to drying clothes in a reasonable amount of time with much less wear and tear on my dryer.
Here is another idea - I recently opened up my dryer to fix a problem and found that the interior exhaust pipe - the part that takes the exhaust air out of the dryer, into the vent pipe on the back of the dryer and eventually outside - had become disconnected INSIDE the dryer. The dryer itself was full of lint and the air wasn't getting out of the dryer at all. If you have this problem you'll also have a lint problem, so check this out - it would be an easy thing to fix.
Mar 01, 2010 | LG DLG5988 Gas Dryer
Our model medt5870tw0 maytag dryer does not dry properly
First , remove the vent hose from the dryer to see if good air flow is coming out the dryer vent . If not , could have a bad blower wheel . If so , then check the vent hose AND vent to outside to see if blocked . A dryer will either heat or not heat . Since your dryer heats , try drying a load without the vent hose connected to the dryer and see if it heats fine (telling you , a vent problem is apparent . Sometimes a dryer is pushed too far back , kinking the vent hose also .
Aug 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer is spinning and warming up but it's not drying
Exhaust full of lint. Vacuum into dryer exhaust as far as you can, Then clean out complete vent from dryer to outside. Any lint will catch moisture and clothes will not dry.
Jul 21, 2009 | Dryers
Takes too long to dry
Check the following ares carefully to combat this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 18, 2009 | Kenmore 63942 Dryer
It now takes on average an hour and a half to dry one normal load of laundry. The clothes come out hot but I constantly need to add more time before they are all dry, any suggestions to the problem... it...
Ok, this is a venting issue or, faulty thermostat. check he following to combat this issue.
1. Venting
2. Thermostat
Jun 15, 2009 | Whirlpool Dryers
Amana gas dryer not hot enough. Flame is too small.
Jun 10, 2009 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
Splendide 2000 dryer venting
Absolutely. You need to pull the unit out. Not what you wanted to hear. It not a pretty job.
www.coachtech.info
Feb 15, 2009 | Splendide 2000S Vented Washer/Dryer
Whirlpool Dryer
Your prof. vent cleaner failed to do his job. Ther is a definite restriction in the vent from point A to B, The prof is in the test u performed. You need a straight shot from the dryer to the outside using a class A 4"vent line and a dryer exhaust hood at the termination point,then your problem will be resolved...
Apr 29, 2008 | Dryers
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
60 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
