Question about RCA CC6363 Camcorder
Need manual Would like to know where I can find a users manual for my rca cc6364 camcorder. I need to know where to get tapes and batteries.
Walmart has batteries not sure on tapes
Posted on Jun 29, 2009
  • 4,472 Answers
I have a RCA cc6364, had it for years. I bought a new battery years ago and it won't hold a charge, when the battery is on it says Remove and Retach Batterys; unit in safeguard mode. I don't know if I need...
Does your camera work of a Power Adapter? If it does, then the battery is most likely at fault. If however it will not, then it will be the camera.
Feb 22, 2010 | RCA CC6263 Camcorder
Tape will not eject may be in wrong how do i get it out manually
Open up the door and push the tape in hard and fast. Hopefully it will popup a little to remove it.
Is this an old cassette? If its damaged in any way, or it's been exposed to moisture or extreme heat, it can cause the tape to jam.
If that doesn't work and knowing that this Camcorder has no repairable parts inside, remove the door and turn the load gears in reverse. If this doesn't work, you might need to pry it out. I still have my ancient VHS recorder and had to do that once about 13 years ago. lol
It still works, but I bought new tapes. I'm not sure if those tapes are still available but you could search online for those.
I hope this works!
ps. Just in case you've lost the original User Manual I've attached a link below!
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000029241.pdf
Oct 25, 2009 | RCA CC6263 Camcorder
E03 safegaurd mode remove and replace battery? how can you fix problem? I have removed battery several times and get the same error code. (RCA CC9370 digital camcorder.)
Make sure there is no tape jammed in the mechanism anywhere and carefully clean around the whole tape compartment with cotton buds and isopropyl alcohol to remove any dust and debris, particularly on the opto sensors for read/write and tape present. If this does not solve the problem, try a different tape and if it does not solve the problem then you will need to get it serviced. This is a real pain problem in JVC’s and Panasonics and servicing (which may be costly) or scrapping is the only resolution.
Mar 28, 2009 | RCA CC9370 Mini DV Digital Camcorder
My camcorder
The Instruction Manual for this model can be found in the link below. I was unable to tell what type of tapes this unit uses.
Panasonic NV-RX33A User Manual
Apr 02, 2008 | Cameras
Canon UC1 8mm video camcorder
No solution..... but eager to know where one can get the battery packs and charger fir this camcorder (UC1) A 8 mm videotape is stuck within the camera housing and can not be ejected...No battery and charger available..
Where are those battery packs available f.i." SUNPAK RB-E77MF 6V 1700 mA ??
I would highly appreciate your advice
Thanks in advance
J.van Bochove
e-mail: jvbochove@onenet.an
Jan 05, 2008 | RCA 8MM VIDEO HEAD CLEANER (WET) 8mm Tape
RCA PRO854 camcorder
maybe I would buy your camera,
yes as far as I know hi8 and 8mm are completely different cameras,
where are you and how much for the camera?
david@fullbliss.com
Jan 21, 2007 | RCA PRO854 8mm Analog Camcorder
Can't fast forward the tape
For Models: CC6254, CC6364, CC6374, CC6384, CC6394 The Counter Memory function, which makes it easier to locate a specific tape segment, has been activated. To disable, press COUNTER R/M for less than one second until M disappears. The tape may also stop because it has reached the beginning or end of the tape, depending of course on whether you are fast-forwarding or rewinding.
Sep 06, 2005 | RCA CC-432 Camcorder
Some icons disappear
For Models: CC6254, CC6364, CC6374, CC6384, CC6394 Check to make sure that you set Display to Full in the System menu.
Weird error message
For Models: CC6254, CC6364, CC6374, CC6384, CC6394, CC9360, CC9370, CC9373 There may be a simple solution. Do the following: * Turn your camcorder's power off, then disconnect the power source (battery or AC adapter). * Remove the clock battery, if equipped with one. * Wait a few minutes, then reinstall the clock battery. Reconnect or install the power source — battery or AC. * Then try turning on the power again.
Unclear picture
For Models: CC6254, CC6364, CC6374, CC6384, CC6394. When using Quick Review to check the end of your last recording, some distortion at the beginning of the playback is normal. When using the Retake mode to record a scene, the video may darken or become monochromic. Noise bars may also appear. This is normal.
Open Questions:
RCA CC6363 Camcorder Logo
319 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
