Question about Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Trying 2 reg Nuvi 200 and down load usb drivers and lost all maps. Display reads "NO detailed maps found that support routing. The Nuvi Cannot be used without them." Can U Help My GPS says No detailed maps found that support rounting. The nuvi cannot be used without them.
  • 48 Answers
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
Posted on Jun 02, 2009
SOURCE:
My gaRMIN NUVI 200 lost it's maps information. How do I recover the information. thanks
You can try contacting Garmin and seeing if they will allow you to download the map again. The file that you are looking for on the Nuvi's flash drive is "gmapprom.img". It should be within the Garmin directory on your Nuvi (using PC to Nuvi USB cable). The file will be very large, around 1GB. More information on missing maps can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Apr 19, 2014 | Garmin nuvi® 200 Car GPS Receiver
When I turn on my nuvi 200 I get the message "no
If you got the unit from somebody they could of used a SD card and its looking for it and the ynever switched back to the regular map... to check try this..
Settings ... Map.... on he bottom of screen you will see Map Info .. press it.... it should now say what map is loaded on the gps...
It should have a checkmark in the City Navigator North American NT, if not put one there
Nov 04, 2010 | Garmin nuvi 200W GPS Receiver
My garmin nuvi 200 it say no detailed maps
my garmin 200 nuvi say no detailed maps found that support routing
May 21, 2010 | Garmin nuvi 200 Car GPS Receiver
When garmin 200 is turned on it says it is loading maps and after you hit the agree button it says"no detailed maps found that support routing. the nuvi cannont be used without them".
Not being able to start up is a sign that the system software or firmware of your Nuvi has become corrupt.
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Sep 05, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi ~ No detailed maps found that support routing.
Please see this link for more inforamtion on this problem. I can help you resolve the issue. Your map unlock code is either corrupted or missing.
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Jul 11, 2009 | Garmin nuvi® 200 Car GPS Receiver
GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
This error is caused by a corrupt or missing map unlock code. Please email me @ sharcnet-usa@sharc.net and I will talk you through on how to fix the problem.
- Jim
SHARCNET-USA
Apr 22, 2009 | Garmin nuvi® 200 Car GPS Receiver
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
Error message appeared and can not do anything with it now
Here is the the lastest response:
Thank you for contacting Garmin International.
If you updated your nuvi 200, 200w, 205, or 205w to City Navigator North America NT 2010.10 between 4/7/09 and 4/25/09, and your unit is display the message, "No detailed maps found that support routing. The nuvi cannot be used without them." or "Can't unlock maps." A new revision of the 2010.10 update file (Garmin_RMU_CNNANT2010C.exe) has been released which corrects this issue. To download this new revision, please follow these steps:
1. Log into your myGarmin account
2. Click Manage Maps and Downloads
3. Connect the nuvi to your computer
4. Click Download Again next to your nuvi
5. Click Launch Download Manager
6. Follow the prompts to install the Download manager
7. Save the file to your Desktop
The new download may take a few hours to download. Once the file has fully downloaded, double click the file to run it, and follow the onscreen prompts to begin the installation again. You will now be able to choose the appropriate region for your device.
Note: Please make sure to only select the region that originally came loaded to your device. For example, if you have a nuvi 200 that came with the Lower 49 States, select that region and not a region that includes Canada.
With Best Regards,
Mark S
Senior Product Support Specialist
Automotive Team
913-397-8200
800-800-1020
Dec 01, 2008 | Garmin nuvi 205W GPS Receiver
You can download new maps..........free......................but..........
I had this problem last year with my garmin 200 and when I called they said that I was out of the 60 day time window for a free map upgrade but they would give it to me anyway. They gave me detailed instructions on how to download a new map free of charge but they didnt explain which selection replaced what I already had on mine.
As a result, I downloaded the wrong maps and have much less detail. Even though its the "2009" version, its less acurate than my old maps were. But its worth a shot, better than paying for them.
Oct 28, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
1,631 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
