Question about Dometic RM2852 Refrigerator
2002 RM 2852, the refrigerator (lower section) will not work its warm inside, but the freezer (upper section) works fine, it will freeze water bottle to hard ice. All fuses are good. Please help!!
2002 RV fridge RM 2852, the refrigerator (lower section) will not work, its warm inside, but the freezer (upper section) works fine, it will freeze water bottle to hard ice. All fuses are good. Please help!!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
Cooling unit is bad my friend there is a temporary fix but in my opinion not worth your time take the unit out and flip the refer upside down this sometimes dislodges the blockage in the cooling unit all a rv fridge is is amonia and salt if not used all the time the salt crystalizes in the orfice and blocks the unit a rebult cooling unit 550 about and labor 4 hours at your dealers rate a new fridge about 1500 installed
my shop 360 for labor 550 about for unit 910
I ALLWAYS RECOMEND REPLACING THE FRIDE COMPLETLTY
you get all new electronics and a new box
Posted on Aug 01, 2009
Our refrigerator works on AC. When switched to lp gas it sometimes come on and works and then goes off. Then we can't get it to work again. Then it will work if we turn on the hot water hea
It seems like a gas pressure problem. Possible blockage or kinked pipe or faulty regulator on the gas bottle. If the fridge runs ok only when you use the gas hot water, that would change the gas flow / pressure. LP gas products are normally around 1.5 to 2.75 kpa pressure. If you have access to a manometer, the gas pressure can be checked. (NB/ You should hold a gas service licence to do this)
Sep 29, 2014 | Dometic RM2852 Refrigerator
I have a Domatic RM 2852 in my RV. The freezer works fine but the refrigerator won't cool to 40 on electricity. It cools fine on gas.
You need to unplug the heating element from the circuit board and using a digital multi meter check the ohms. You should read approximately 44 ohms +/- 10%. If it is out of range change the heating element.
Aug 15, 2013 | Dometic RM2852 Refrigerator
Fridge does not get cold during propane gas function only. Upper Freezer section does. Whole unit does perform and freeze and cold function fine with electric and generator function. Why only during...
According to the manual the following is the most likely items to cause that failure. But since it is only in the frigerator section and not the freezer section it could be the lower circuit board.
LP Gas
Orifice
Flue Baffle
Flue Tube
Burner
Lower Circuit Board
Sep 10, 2011 | Dometic RM2652 Refrigerator
Freezing in the refrigerator
you probably have a damper control that is sticking open letting the cold air in fromthe reezer but not closing the small door when the freezer is to tempreture check this first
Apr 30, 2010 | Dometic RM2852 Refrigerator
Freezer and fridge not cooling (halfway)
SxS Amana upper half of feezer and Refrigerator not working
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
The freezer coil in the lower freezer section freezes up with ice. I have the upper section at 5C and the freezer 18C. We first notice that there is water under the fruit drawers and the fridge seems to...
unplugged it and defrosted the coil with a blower and it starts working fine ...
It it happens again perhaps defrost sensor, timer, or perhaps the heater coil being a problem. the heater is on the coil you will seethe wires the therm. is on the top of coils timer could be at lower back of refrig.
Thanks
Fame !
Jun 17, 2009 | Refrigerators
Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Jun 11, 2009 | Jenn-Air JFC2089HE French Door...
Water always inside refrigerator sometimes ice forms
Sounds like you might have a condensation problem. Is the fan in your freezer working? If not it's not circulating the cold air. If it is you might have frost on the lower rear wall of your freezer meaning its not defrosting like it should and restricting your air flow. Last but not least you have a damper door in the upper left corner of your fridge that allows the cold air from your freezer into the fridge to cool it, that might not be opening up. Any one of these things would cause your water problem and a warm fridge section
Dec 05, 2007 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Dometic RM2852 Refrigerator Logo
718 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
