Question about Maytag Neptune FAV6800AW Top Load Washer
Cold water keeps running after cycle ends
When rinse cycle ends the cold water keeps running.
    President:
  • 1,902 Answers
Your water inlet valve is sticking which means that it needs to be replaced. You can get it at your local appliance store or at repairclinic.com
Posted on May 28, 2009
Bosch classix 1200 exprss washing machine will not move on from the wash cycle. it will keep on washing and never moves to the rinse cycle. pump and motor works ok.
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 25, 2015 | Bosch Washing Machines
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Where is the cold water valve on amana washer
the cold water valve is at the end of the hose at the back of the machine
if the cold water pipes run outside to the garage , it is a fair bet that the water in the pipes has frozen
easy to check --take the cold water hose of the tap and see if it runs
if it runs replace the solenoid for the cold water valve
May 10, 2017 | Amana Washing Machines
Washer wont fill up during rinse cycle
all rinse cycles are filled with cold water to keep the clothes from wrinkling.set up the washer to run with just cold water.start it,if no water comes into washer,shut down your house water valve that fills the washer,take off the cold water hose,stick it in the washer or if there's a sink or where ever and turn on the water,if water comes out of the hose then you need a new water valve on the washer
Feb 15, 2011 | Whirlpool Washing Machines
My hotpoint washing machine does not rinse properly it still has washing powder on it , what could this be
It could be that your cold water solonoid is at fault. Also is water pumping out ok at end of cycle? this often happens and machine will keep same water in all way through. If you put machine onto a rinse only this will then fill with cold water, if so then that will rule out solonoid problem.
Feb 12, 2010 | Washing Machines
My whirlpool washer fills up with hot / warm water (cold doesn't work) pretty quick for the washing cycle but it takes forever when filling the rinse cycle....help
The amount of water on the rinse is lower becaus it's using cooler water. You stated that the cold water isn't working.
Shut the water supplies off. Take the hoses loose from the hose bibs. There should be screen washers in the end of the hose. These are to catch the sediment that normally flows through the water supply pipes in our homes... Take the washer screens out and clean them with an old toothbrush.
Reinstall and while you're at it clean the hot side too.
Then take the machine end of the hoses off and check that it's all clear there as well.
Re install and run your machine on a cycle and monitor it to see if there is better flow on the cold wash cycle AND the rinse portions of your cycles...
If there is no screen washers in the hose, chances are you'll need to clean the water supply valves in the machine... real fun.. HOPE There's washers in your machine..
K
Jul 24, 2009 | Whirlpool Washing Machines
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Water won't stop running
It might have a small stone or something similar in the water soleniod valve or it might just be sticking open somewhat. I'd go ahead and change the cold water soleniod valve because it's not closing itself and shutting off the water flow.
Jan 08, 2008 | Maytag Performa PAV2200
Hotpoint washer Won't rinse
your cold water valve will be your problem or you've turned the water supply off, if the supply is not off put the machine on to the final rinse if it fills it will be the main rinse valve gone. The cold water valve is a double one with 2 solaniods. Unplug the machine turn water supply off remove fill hose there are 2 screws keeping the top on, remove them lift the lid off.undo the screws that keep the valve on, take note wiring and remove pull the black hoses off, replace with new one. The resistance of the valve will be around 3.4 kohms
Oct 07, 2007 | Washing Machines
Maytag Neptune FAV6800AW Top Load Washer Logo
199 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
