Question about Maytag Atlantis MAV8000
Intermittent Motor Overload
Maytag MAV8000AWW -- The washer runs a cycle or two without incident. Then suddenly, at the start of the next spin or agetation cycle, the motor hum is abnormally loud and after about 10 or 15 seconds, the thermal breaker kicks out. The centrifugal switch appears to be in good condition, so I don't think the problem is a stuck-on starter winding. Also, the owner claims that the hum and shut-down have occured in the middle of aggitation and/or spinning (with the motor already up to speed and initially running normally). The mechanism, drum, and agitator turn freely by hand. Belt, pulleys, and motor slide mount/spring assembly all look OK. I suspect an intermittent mechanical problem (e.g., the brake occasionally not disengaging, something binding or jamming intermittently in the transmission, etc.). Is there a commonly encountered problem with this design that sounds like what I'm describing? If so, what parts are typically required? Thank you in advance for your feedback.
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
SOURCE: Maytag Washer PAV2300AWW
Your Thrust bearing on the bottom of the transmission is not releaseing the break. try turning the pulley with the belt off in the opposite direction this should free up your break. If it doesn't replace your brake ststor and rotor as well as your thrust bearing. This should solve your problem. Roger
Posted on Sep 27, 2007
watugot
  • 290 Answers
SOURCE: Washer will not agitate but will spin
You are correct that motor turns one direction for agitate and the other for spin. The problem you describe sounds serious but there is a chance it is not. First, try to turn the transmission by hand. If it wont turn by hand, remove the agitator and see if something has gotten under it and has it locked to the basket. To remove the agitator, pop off the top cap and look down inside. You will see the bolt that holds the agitator on. After you take it loose the agitator will slide off.
If there is nothing there, the transmission will need to be replaced. If the washer is less than 5 years old, the transmission may still be covered by warranty. Check your owners manual for warranty details. Post back to let me know what you find out.
Posted on Oct 21, 2007
arashid
SOURCE: Maytag MAH21 - main motor won't run
Please check microswitch block door/ Best result change this microswitch on the new. If terminal is shot - longered on wire.
Rashid Moscow (arashid@yandex.ru)
Posted on Jan 25, 2008
  • 20 Answers
SOURCE: Maytag washer won't Spin freely
You have a worn brake
Posted on Feb 10, 2009
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Maytag stacked washer dryer lse7806ace
Take the belt off the transmission pulley and see if you can turn it by hand. It will agitate on direction and spin when you turn it the other direction.
Put the timer to spin with the belt off and see if the motor will run. There may be a problem in the start switch on the motor letting it start in one direction but not in the reverse direction.
Special tools are required to remove the transmission and brake assembelies. You also want to make sure there is nothing sticking through the holes in the basket causing it to lock up such as a nail or screw that may have been left in a pocket.
Post back with what you find.
Thanks/Mike
Dec 05, 2007 | Maytag LSE7806A Top Load Stacked...
Machine was overloaded and now the spin cycle will not work
hum check the belt if applicable, the door switch just in case co incidence plays out here, also may have a bad clutch or motor coupler, or worse case problem ur tranny. are u saying it still washes though? overload should not throw out ur spin cycle but can damage ur clutch and tranny? lest u have a digital electronic board on this machine and they are know to go bonkers. some machines actually have a auto fixit for overload or unbalanced issues.
Feb 18, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Pump or bearing problem?
If this is a top load maytag, the pump bearing sleeve will rub the pump pulley and make a grinding noise. Replace the pump.
Sep 26, 2013 | Maytag Washing Machines
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag top load washer - model MAVT546EWW purchased from Lowes. The entire led lights blink twice, then the "regular" wash light is lit. This repeats every 20 seconds or so. The washer will only...
This sounds like the electeronic is faulty. Do this. Turn off the machine and unplug it from the power outlet for 5 minutes. Then plug it in and select a cycle. Make sure the water is on and try the spin only cycle first. if it wont spin only then there is a problem in the controller or the motor circuit. Thsi could be something simple like the unbalance switch or something worse like the motor or controller. ensuder the bowl is central. Pull the bowl to the centre. if rthe button you refer to is an overload button then the motor is faulty. A motor overload button measures the motor current in the neutral leg and if it is too great then it pops and stops the appliance.
Aug 01, 2010 | Maytag MAV7580E Top Load Washer
Washer trips circuit breaker during spin cycle
try unplugging the motor then put onto spin it will pump out ok and run othewise spin if all else is fine ,next reconnect the motor if it trips again then motor ' fault; repair /replace.
Apr 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Exessive noise when in spin cycle?
Could be dirty bearings. As long as it is still spinning, it is nothing to worry about. If it suddenly stops one day, it is probably frozen bearings or the brushes in the motor.
Jun 23, 2009 | Maytag Dependable Clean Top Load Washer,...
Washer wont run but is trying to
Sounds like the motor or capacitor (next to the motor), the capacitor helps the motor to start, once running a switch inside the motor disconnects the capacitor from circuit.
Mar 18, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
100 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
