Question about Fujitsu Computers & Internet
Dropped new external drive from 2 ft, please help
I just got a new Fujitsu Wyvo 300GB "mobile storage device" (pretty much an external hard drive). The device is 2.5", with an HDD inside. Soon after opening the packaging, I dropped the drive. I was on my bed; it slid off the bed side and hit the wooden floor. The second thing in the manual says "do not drop". F my life. The drop was 63 cm/24.8 in./2.067 feet. Will this roughly two feet drop do anything??? I then plugged in the drive, for the first time, and it was detected, installed, and worked fine. What can I do to be sure it's okay? Please help, Thanks. It sucks 'cause I just got it too (as a gift).
  • 1,305 Answers
You can run a disk utility program such as disc warrior. It can put your hard drive thru read write etc...
if no such program is available to you, I would try a few reads, writes, erases and renames of files... you may just be A-OK..
I've dropped drives, piano keyboards etc... and they've lived to work again...
Besides, if you ever saw how UPS handles their packages before they get to your door or to the stores...
Is the drive working quietly? without any strange hesitations? ... sounds like you may have received grace from the hard drive elf on this one...
Ps. You may want to put in on a no-skid pad or attach a piece to the bottom to help secure it a bit.
Let me know how it goes.
k
Posted on May 28, 2009
MY MAXTOR ONE TOUCH 3 EXTERNAL HARD DRIVE WILL NOT BE RECOGNIZED BY THE COMPUTER AND MAKES A BEEPING NOISE. ANY SUGGESTIONS WHAT IS WRONG? CHEAPEST SOLUTIONS?
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 22, 2010 | Maxtor OneTouch II external hard drive...
I have IBM eServer with ServeRaid-7K on board controller and have 3 SCSI 73GB hard drives configured in RAID-5 array. Hard Drives are running critically low on space and I bought 3 300GB scsi Ultra320 hard...
First, buy an external storage device, at least 80GB (although it's currently difficult to find any _smaller_ size!) and make a file-by-file, folder-by-folder, backup of your 73GB of "data".
Second, buy another external storage device, and do a Google-search for "drive image freeware".
Pick one of those applications, and do a "image" backup to this second external storage device.
Third, disconnect the 3 "old" drives, carefully label them, and set them aside.
Fourth, connect the 3 "new" drives, delete the old RAID-5 array definition,
and create a new RAID-5 array definition.
Fifth, do an "image restore" from the second external storage device to the new array.
If you have any problems, all you need to do to "back-out" is to:
* disconnect the "new" drives
* reconnect the "old" drives
* delete the "new" array definition
* redefine the "old" array definition
and you're back to the "old" configuration.
Dec 07, 2010 | IBM ServeRAID-7k Controller (71p8642) SCSI...
My Maxtor External Hard Drive is not working
You need to check it with Norton Utilities. I hope you still have this hard drive (this posting is posted 5 years ago) and it is not dead yet, so you can copy all of the valuable files to your other data storage.
Here is the link to download the 30 day trial (free):
http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
Dec 19, 2009 | Maxtor 300GB ONE TOUCH 2 USB2- 7200RPM...
I have a seagate external hard drive that I dropped, and now the blue light stays on, but the computer does not recognize it. is there a way to retrieve the info?
Are you using XP?
It should show up. Are yo sure you are plugged in correctly everywhere?
Check your device manager ...
Let me know if this works for you.
a
Sep 26, 2009 | Seagate USB 2.0 External Enclosure + 300GB...
Hard Drive Dropped
Hi there
You may want to try going to add new hardware and see if scanning for hardfware change will let it recognoze the device if not uninstall it under device manager and have it reinstall the device upon start up of the pc
Jan 03, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Maxtor one Touch 300GB no steady green light
The USB Isn,t supplying/providing enough Power to the device.
Search e-bay or similar for a 2 into 1 USB Cable.
Then power the unit with 2 USB Ports on the Computer.
2 x USB Into 2 x Sockets On P.C. 1 x Into Device Drive.
This will be enough power to operate the Device Correctly.
I,ve done this on several external Drives, never failed for Me.
Mike @ compurepair.
Mar 16, 2008 | Maxtor OneTouch II external hard drive...
Power surge on hard drive
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Jan 04, 2008 | Maxtor OneTouch II external hard drive...
HD PROBLEM
Goto Control Panel> Administrative Tools> Computer Management, click Disk Management if you found harddrive doesn't assigned yet a drive letter please do to assign it and apply.
Hope this will be helpful, rate me solved!
Good Luck
Nov 20, 2007 | Maxtor OneTouch II external hard drive...
Power indication light flashing
Hi, you may want to try connecting it by USB if you're currently using firewire or the other way around and see if it works. If this fails, you are probably better off using diagnostics by Seagate @ http://www.seagate.com/ww/v/index.jsp?vgnextoid=7f4e19e0babfd010VgnVCM100000dd04090aRCRD&locale=en-US#. Try to use the Troubleshooting or FAQ or if you feel comfortable using their utilities, download SeaTools. Hope this be of help to you. Good luck.
Apr 23, 2007 | Seagate 300GB Pushbutton Backup External...
Computers & Internet Logo
307 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
