Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
AQULINK CONTROLLER WILL NOT TURN OFF FILTER PUMP
The pool filter pump stays on even when the Aualink RS/6 Controller is finished with the daily cycle. The only way I can get the filter pump off is to go to the panel at the outdoor Aqualink unit by the pool equipment and flick the circuit breaker off. I tried pushing the service button, but the pump stays on. I'm having a similar issue. I'm able to get it to turn off sometimes by continuing to press the on off button until it turns off, but most of the time, I need to turn it off at the breakers. I found that it does work, after playing with things, until my pool service guy comes and puts it into time out mode, not service mode as he turns it off and on from the outside controller to do his servicing (just found this out today). This seems to be "irritating" my Aqualink (and me) and perhaps messing with the system. I am on my fourth pool service co. in a 1 1/2 year period and still seem to know more about the system than any pool service co. Aqualink is not very helpful when it comes to the system and the "specialists" they refer customers to have not be knowledgeable, but one actually broke my heater. I'm hoping someone will be able point me in the direction of a pool co in Phoenix that I can pay for the care of my pool and not have to spend hours upon hours working on my system as well. I've had 6 houses with this system and this is the first time I've had any problems. I need help!
    Top Expert:
  • Jandy Master
  • 7,915 Answers
Shorted relay stuck on replace
Posted on Jan 30, 2016
2 Suggested Answers
  • 61 Answers
SOURCE: AQULINK CONTROLLER WILL NOT TURN OFF FILTER PUMP
Sounds like one of the relay's has gone bad inside the box. If your lucky you can move the wires to another relay if there is one available. Make sure you move the top wires too, not just the 4 bottom wires, or you will have to do some reprogramming.
Posted on Apr 04, 2009
My pool inside control unit showed Firmware Rev B09 error and did not work. Outside control works fine. How to fix this issue?
make sure that the 4 pin red plug is plugged in and wires are tight and no copper ends touching other ones if doesn't work switch with the other if still bad bad controller if other one goes out bad wiring or plug
Jul 24, 2015 | Jandy AquaLink RS OneTouch RS6 Pool or Spa...
Indoor panel is a code 7202 rev HH showing?
need more info is it a wired controller if so make sure 4 pin red plug is plugged into bezel board sometimes they unplug for winterization if plugged in make sure where it goes into house or into RS system that the wire isnot cut or nicked sounds like it isnt seeing controller if all ok shut system down and reboot
Apr 07, 2014 | Jandy AquaLink RS OneTouch RS16 Pool or...
Jamdy RS Shuts off heater too soon
when using the aqualink make sure heater is in tstat mode if not for your heater then turn heater all the way up make sure the wires are connected to pool and com then make sure the wires 5and 6 are connected to the heater then the aqualink will command heat if the red light is lit on controller
Feb 10, 2014 | Jandy 7953 AquaLink RS One Touch Control...
Pool filter pump won't shut off.
I'm assuming it continues to run when you switch the system to "service" mode. You probably have a relay stuck shut. Unless you are very comfortable with working with high voltage it's best to get a tech out to verify the problem and switch out the relay. If you are okay with it the replacement isn't very difficult. You'll have 4 or 6 wires to move from the old relay to the new one, and switch out the small black and red paired wires that go from the relay to the control board. Make certain that your breaker is off while changing it out.
Apr 12, 2013 | Water Pik Aqualink Rs4 Package - Pool and...
Aqualink RS6, 6700 rev c message
check to see if wires are cut or shorted if ok need new controller
Apr 30, 2012 | Jandy AquaLink RS OneTouch RS6 Pool or Spa...
Hi- I'm a new intex above ground metal frame pool owner. I bought the saltwater chlorinator to go with my pool. I constantly have a problem with the pool filter not getting enough water to flow through...
You've gotta keep that annoying filter pretty darn clean to please the saltwater pump. I have to scrub my filters daily for this reason. What pump do you have? Mine is rated for 4000gph but I see Intex even offers support for pumps with as little as 500gph.
Jun 16, 2010 | Intex 1000 Gallon Swimming Pool Filter...
Mar 14, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
238 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
