Question about LG Refrigerators
Water leak in back of fridge for 2 days. All else works fine
There has been water leaking on the floor behind the fridge for the last two days. The water dispenser works fine, the ice maker as well. What would be the source of the water leakage?
    President:
  • 1,489 Answers
It sounds like the fridge water supply line is leaking. Pull the fridge out and have a look. May just need tightening.
Posted on May 28, 2009
Have whirlpool gold refrigerator with freezer on top. Water leaking continuously out bottom on floor. I turned water valve behind to off. All leaking stopped. Can someone tell me where to look for the...
One big question before you go hunting. Before you turn off the water, was the water running all the time? Meaning if the water had a continuos flow the leak is before the fridge. If the leak is erratic then its on the valve side to fridge.
Follow the water source in the fridge, supply line to water valve (bottom right behind the fridge), from there it should run straight up the back into the freezer. So, if the water is coming from the valve, replace it, if from the water line - replace it. If the water line came off or out of the freezer reconnect and check for a frozen fill tube.
I hope this information helps.
Oct 21, 2013 | Refrigerators
Refrigerator leaks
If it a frost free fridge it should self defrost every 6 to 8 hours all by its self. If you see ice or frost buildup in side the freezer usually back wall harder to notice if the cooling fins are just under the freezer floor but above the fridge ceiling or better picture it as the fridges taint. Sounds like the fridge is having defrost problems and if it every once in awhile does go into defrost or you do it, all that water flows down a hose and out the back around the compressor. Heat from the compressor or other gadgets evaporate the water. If it only defrost a few times a year it is going to overflow the catch basin. Easy to check some times catch basin or drain hose move check back bottom or remove front cover look if bottom catch basin. Main fault is defrost timer stuck in run, location all over in or out, defrost element around cooling fins,defrost thermostat on cooling fins,wiring to / from / joining the last two.
Mar 17, 2017 | KitchenAid KBRP20ERSS Stainless Steel
GE SIDE BY SIDE FRIDGE HAS WATER LEAKING ON FLOOR FROM FREEZER SIDE
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Aug 14, 2012 | GE Refrigerators
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Hotpoint. Water is leaking from behind light bulb
The drain hose in the back of your freezer is frozen shut. The water you see is coming from the defrost cycle. Turn off the refrigerator. Remove the floor from your freezer and remove/thaw all of the ice. Locate the drain in the back of the freezer. It may be behind the back panel. Thaw the drain until water flows freely through it. Reassemble the freezer, and you are back in business.
Oct 22, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
A small amount of water is leaking out of the front of the refrigerator onto the floor every day and I can not fine the source of the water. Is there a drain pan and if so where is it? If it is not the...
older fridges drained water into a pan with the compressor in it, thus cooling the compressor and evaporating the water, this is located at the bottom back of the fridge. if this fridge has a water and/or ice dispensor, the water could be leaking from many a place.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
10 year old frige leaking water from the freezer onto the floor
drain tube is plugged the fridge goes into defrost about every 8 hours use a hair dryer to melt the ice and check the drain tube goes to the pan by the compressor
Jun 30, 2009 | Refrigerators
WATER PUDDLE ON FLOOR
no water will be coming from that line it is going to be a blocked drain line or a rust hole under where you can't see
Apr 17, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Water accumuluation under the fridge
at the back there should be a drip tray if this is full it will leak onto the floor it could be this, it could also be the drain in the fridge is blocked on the back there should be a self made into the back with a hole in it this is to go to the vapure, the part i was on about before, the tank is on top of the pump and its hot so turns the water in to vapour, usually there is not a lot of water but if the pipe becomes blocked it stores the water in the pipe and then lets it go in one full step over flowing the container. to clean the pipe out you can use a flex line or a net curtain rod, push it down and up the hole a few times the blockage will fool to the bottom or come out on the flex.
Jun 15, 2017 | Amana ASB 2623 Side by Side Refrigerator
Water and ice in fridge leaking on floor.
you have to defrost the freezer it will take almost a day byitself,but you can speed it up with a hair blower pointed inside the freezer toward the back at the bottom,unplug your fridge and hair blower on low you dont want to melt the styrofoam,put 2 bowls in you fridge top shelf towards the back to catch watr falling from the vents,when you see water come into the pan under the fridge your all set ,clean up water and plug fridge back in,its the drain hose is blocked with ice
Jul 08, 2008 | Refrigerators
Refrigerators Logo
830 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
