Question about Nokia 3589i
Unable to adjust volume control
Listening volume to low
  • 490 Answers
While u r listening to call...just press right arrow key to increase the volume....
Posted on Oct 22, 2007
Uniden uho36sx
Check the "settings". You may have it set so the volume buttons only adjust the beeps. I've seen this happen on a couple of different units.
Apr 30, 2014 | Radio Communications
I have a CS361 plantronics wireless headset and I get alot of echoing when I get calls in and out, and when I call my coworker
Reduce speaking volume by changing the speaking volume
major adjust switch setting. See page 15 in the User's Guide (link below).
• Point microphone towards your chin.
• Listening volume too high on phone. If your phone has a handset
volume control, lower this until the distortion disappears.
• If the distortion is still present, lower the listening volume adjust
button on the headset. If the distortion persists, select another
listening volume major adjust switch setting. See page 14 in User's Guide.
• Base is too close to computer or phone. See page 9 in User's Guide for
proper positioning.
For further help, this is the link for the Plantronics Wireless Headset User's Guide.
Good luck from Headsets Direct!
Apr 19, 2011 | Plantronics CS55 Wireless Headset
I can listen but when i speak, the receiver can not listen. its like on-comming sound only. what is the problem with logitech mikrophoe? could you help me please?
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 19, 2011 | Logitech (980240-0403) Consumer Microphone
Hey, I have a problem with my soundsystem Logytech Z4 and I would like to know if you can help me? The following problem occurs: The black control panel, where I can adjust the volume and bass has a...
Sounds like (no pun intended) the amplifier circuit in the speaker is bad. When you use the headphone the amplifier is not used - only the preamp. It will need repair.
Nov 25, 2010 | Logitech Z4 Speakers
Unable to listen to the sound
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 16, 2010 | Intel D915GVWB Motherboard
Low volume on a dsl line
I'm sorry but what kind of answer is that? I came on here to find out where the volume control was. If people know where it was they would know to adjust it and would not be asking.
Feb 25, 2009 | Panasonic KX-TG5100 Cordless Phone
Reading through my User's manual for a 5.8 GHZ, Model CS5111 I cannot figure out how to listen to my voicemail messages. Please help.
The volume is too low (person who loaned me this VTech 5.8 mhz, Model CS5111 did not have the manual to go with it). Unable to determine if phone volume is adjustable.
Dec 12, 2008 | Vtech Lands Phones
Volume control
Do you have the volume at -5dB when listening to source 1? That would in most cases be far beyond the receivers capabilities when listening on an average loud recording from a standard source. I would guess that your source has a way to low signal.
However, i assume the answer to the question is this:
There is a way to trim the levels of each source (Input). It can be adjusted -6dB to +6dB.
Select the input you want to adjust. Hit Set Menu on the remote. Then Manual Setup -> Input Menu - > Volume Trim. Adjust up or down. In your case adjust your source 1 to + 6dB and all other inputs to -6dB.
Regards Alex
Mar 02, 2008 | Yamaha RX-V657 Receiver
Volume Control
First go to and download the instructions for this particular mp3 player. I'm guessing it's the SDMX1. Look for this model and get the instructions. They're about 30 plus pages. Volume is adjusted very easily-Look at your SDMX1 with the data screen to your right and headphone plug to the right.
1.find the joystick control-it sticks up and is chrome plated.
2.imagine it is a compass with North-up
3.simply move the joystick North for louder volume and South for lower volume. can also read the volume numbers on the screen in the right lower quadrant. they go from 1-40. Good luck.
If you ever have headphone problems with sound from only one earphone, let me know. I know how to fix this better than new! Also, if the play-on/off switch becomes hard to operate, this fix is also very simple.
Jan 06, 2008 | SanDisk SDMX1 MP3 Player
Listening volume has suddenly become very low. I would like to raise the volume Thank you
Go to this website and download the manual.
This model has voice enhance feature. There is a volume control on the answering machine and the handset. This manual will show you how to adjust both.
Dec 04, 2007 | Panasonic GigaRange KX-TG2432 Cordless...
Nokia 3589i Logo
78 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
