Question about Samsung J700 Cellular Phone
My phone does not ring and goes directly to my message system.
Also when I open my phone Airplane Mode pops up. How can I get this off. Thanks for your help.
  • phylide May 28, 2009
    Thank you so much for helping me. Now it works. P.
    Sniper:
  • 50 Answers
When it is in airplane mode it blocks all transmissions so it is safe to use on airlines. This can be disabled under settings in a J700 where you should be able to change profiles. Also you can try resseting the phone by dialling *2767*3855#
Posted on May 28, 2009
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Apr 15, 2015 | Apple iPhone 4S
How do my iphone5 not ring just straight to voicemail
Usually phones only send callers directly to voice mail if the phone is turned off, if the tower cannot reach the phone or if the phone is in airplane mode.
Can you make calls? That will determine whether you can reach a tower.
Check to make sure you're not on airplane mode (if you can call out you probably are NOT in airplane mode)
Have you activated 'Do Not Disturb'? See this link for more info: http://support.apple.com/en-us/HT5463
Dec 06, 2014 | Apple iPhone Cell Phones
I have droid phone. Says on airplane mode. How do I turn airplane mode off?
1. Press and Hold the Power button for 2 Seconds. A menu pops up. On that list, you will see "Airplane Mode" (under which should state "Airplane mode is ON").
2. Now tap "Airplane Mode" to switch it Off. If you press the power button again after a few seconds, it should now say "Airplane Mode is OFF". This is how you want to leave it. Done.
Sep 14, 2011 | Apple iPod touch
Cant open phonebook,messages
To fix the problem and restore your connection (turn OFF airplane mode), click "Menu," then "Settings," then "Phone Settings," then "Airplane Mode," and then set the mode to "Off." Once you turn off the airplane mode, your Samsung phone will function as normal.
Oct 04, 2010 | Samsung Cell Phones
All incoming calls go direct to voice mail,phone does not ring.
You may have turned the radio off on your phone by activating Airplane mode. This mode will send all calls to your voice mail.
Check your owners manual to re-active your phone to Normal mode.
Apr 07, 2010 | Nokia 6700 Classic Cell Phone
I own LG VX8360 and can't figure out hoe to turn ringer on. Can you help me?
To restore the ringer it will depend on what mode your phone is in:
Vibrate Mode:
Sets the phone to vibrate instead of ring.
To set Vibrate Mode, with the flip open, press and hold the # key .
To return to Normal Mode, press and hold the # key again.
Sounds Off Mode:
Quickly deactivate your phone's sounds when you're in a place where phone sounds would be disruptive.
From standby mode with the flip open, press and hold the lower side volume key for 3 seconds. To return
to normal sounds mode, press and hold the upper side key.
Airplane Mode:
Turning on Airplane Mode will disable all wireless communications.
1) With the flip open, press the Menu key.
2) Use the Directional Key (top center of phone) to scroll to 'Settings and Tools'.
3) Press the 6 key for Phone Settings.
4) Press the 1 key for Airplane Mode.
5) Use the Directional Key to highlight a setting, then press OK.
On/Off
Mar 30, 2010 | LG VX8360 Cell Phone
When an incoming call comes in my motorola rokr rings once and then go directly to voicemail even if I press the answer key. What do I need to do to fix this problems?
Possibly it is on aiplane mode, to turn that off
Press menu key
scroll to settings then press the joystick
scroll to airplane mode, then press joystick
scroll right to turn airplane mode on / off
set prompt at startup to turn on or off when you turn the phone on or off here.
Also~
ANSWER OPTIONS:
Press [_] > settings > incall setup > Answer options > multi-key > on or off
Cheers
Apr 29, 2009 | Motorola Mobility ROKR E8 Cellular Phone
How do you turn of phone - no calls and turn off just roaming?
Enable Airplane Mode on your iPhone by choosing Settings, then turn airplane mode off.
This will disable the ability to:
Make phone calls
Send or receive email
Browse the Internet
Send or receive text messages
Stream YouTube videos
Get stock quotes
Get maps locations
Get weather reports
When in airplane mode you can still:
Listen to music and watch video
Listen to visual voicemail
Check your calendar
Take or view pictures
Hear alarms
Use the stopwatch or timer
Use the calculator
Take notes
Read text messages and email messages already stored
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | Apple iPhone 3G
Iphone does not ring on sleep mode
1. File manager in ipcsuite
/System/Library/SystemConfiguration/PowerManagement.bundle
2. Find the file:
com.apple.SystemPowerProfileDefaults.plist
Then rename it to:
com.apple.SystemPowerProfileDefaults.plist2
3. Reboot your phone
Apr 07, 2008 | Apple iPhone Smartphone
Samsung J700 Cellular Phone Logo
118 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
