Question about Mitsubishi VS-50607 50" Rear Projection Television
Mitsubishi VS-50607 TV code 24 which caps to replace?
I just bought a Mitsubishi projection TV Model No. VS-50607. The TV will not come on, but after reading posts here I did get it to give me a blinking code of 24. I read that the 1000uf caps and the vertical output IC may be the problem. Do I just pull the boards and replace all of the 1000uf caps ? Which of the ICs is the vertcal output ? I have not worked on a TV before, but have worked on many pinball machines and video (arcade) games and can solder. Would you replace just the caps first to see it that works, or replace both the caps and IC while you have the boards out ? Also would you socket the IC ? If someone could tell me which IC and caps to replace...that would be great. I also read that the caps should be changed to 680uf 16v...would this be a good thing to do? Thanks for all your help...this should be fun.
Scott
  • adeagle Jun 06, 2009
    I changed the caps and now I am getting a code 22. I do believe that the caps needed changed and that the problem is just down the line a little. I am going to change the convergence ICs and see it that helps. Any ideas on this please let me know.
3 Suggested Answers
SOURCE: mitsubishi tv repair WS55859
same problem I am having....tech came out said it was probably the board containing the power source which on my tv is the right circuit board, said he would either have to buy complete board or get a refurbished one....probably about $400 bucks.
Posted on Nov 21, 2008
  • 126 Answers
SOURCE: VS-50607 Mitsubishi code 24...replaced caps now code 22
Well, I don't know about your original problem but I can guarantee that 95% of the time when a Mits projection set gives a 2-2 code it's because the convergence output IC's are drawing too much current. Replacing the convergence output IC's usually fixes the problem.
Posted on Jun 05, 2009
What do I need to fix my mitsubishi TV that has a 2-4 error code (vertical protect)???
I had three tv's VS-50607,VS-50605, same problem.I called Mitsubishi and got no help.Took me two years to find because the sets were not acting up when I was there.Last set was out completly with 2-4 code. Found problem to be cold solder connection of DY (Yokes) on vertical .I bent the tip on my Weller gun and used a mirror and soldered. It was a sure repair.I went back to the first set,and soldered and it repaired it!,The second set got junked out before I could get to it.
Sep 18, 2011 | Mitsubishi VS-50607 50" Rear Projection...
AFTER TURNING ON TV ,THE GREEN LIGHT COMES ,SOUND STARTS AND THEN TV TURNS OFF ASAP
after tv shuts off press and hold menu and input buttons on tv at same time for about 8 second. power led will start to blink error code 12 ok 22 dead short 23 deflection failore 24 vertical failore. after you know error code have electronic technition repair for you. J.D.W.
Jun 24, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Jun 05, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi vs 50607
Good Day, gntjige73 & muse923;
Let make this short and sweet, code 24 means you have a vertical problem. Four common things can cause this:
1. Bad connections on the convergence IC's,
2. Bad cap's in b + to vertical circuit,
3. Bad connections/or failing vertical output IC,
4. Or fluid on the PC board, leaking from the crt's.
The companies you called DO NOT call them back, but call a factory authorized service dealer, they will help you, but always remember to get a written estimate before you proceed with the repair. Good Luck, big IRISH>
Jun 26, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi 50607
22 is the code for short protection. Which means the set has shot down due to one of the components being shorted. My quess would be at least a 3 to 4 hundred dollar repair maybe more depending on the shops integrity.
May 09, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS 50607 Problems
Vertical output IC most likely needs to be re-solderd. However this model is famous for the CRT leaking coolant in the area of the Vertical output IC and corroding the solder. Check for a sticky residule near the Vertical IC indicating a leaky CRT seal.
Apr 09, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Wavy picture on television screen
First do the self test on these threads or goto ctechnicians.com
Dec 29, 2007 | Mitsubishi VS-50607 50" Rear Projection...
VS 50607 50 inch
Deflection Protect is the problem. You can check C411 and C412 on main board to see if bad. More info ctechnicians.com
Nov 17, 2007 | Mitsubishi VS-50607 50" Rear Projection...
The VS 50607 won't turn on.
I'm not sure of the fix, but my manual says the 2-3 error code is due to Horizontal Deflection Failure. Hope this helps. I just uploaded my service manual, it should be available in 24 hours pending fixya's approval.
Oct 30, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi vs 50607
CHeck 9 V circuit.. Change caps C2p04 & 5.. 100uf 16V & 47uf 50V..Both electrolytics....Directly behind shield on Signal PCB..
Oct 27, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
314 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
