Question about Cell Phones
Need passcode to connect to my phone
I am trying to link my headset to my new phone. Have no clue what the passcode is
  • 421 Answers
Your password can be,0000,1234,12345
Posted on May 28, 2009
I am changing cell phones and need to link the HS820 to the new phone but I do not remember the pass key. I have tried 0000 and 1234 but neither work. Can you offer a solution? Thanks
0000 should be the passcode - check to be sure your phone is compatible with the bluetooth headset or try taking it back and exchanging for a new one?
Jul 23, 2011 | Motorola Mobility HS820 Consumer Headset
Motorola Hs850
The default passcode is "0000" You can get a step by step guide to pairing this headset (plus manual) on the following link: http://www.motorola.com/consumer/v/index.jsp?vgnextoid=38b5f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=fd13e7af976c9010VgnVCM1000008206b00aRCRD
Jul 27, 2007 | Motorola Mobility HS850 Consumer Headset
Need a passcode to actavate LG620G bluetooth to phone
Hi, How to Pair (Connect) a Bluetooth Headset to Your Phone
So you've heard of this new thing called "bluetooth..." But what is it? ...And what does it do for me? It's wireless technology that can link your phone to a headset, computer, another phone, or in extreme cases, your car and home.
We'll just start with the basics and connect a headset to the phone
Instructions
Things You'll Need:
* A Bluetooth cellular phone
* A Bluetooth Headset
Blue tooth can simply be called "a generic wireless technology that can connect your phone, computer, headset, PDA, laptop, and any other enabled device to each other."
In essences, it was designed to be a universal wireless connector between devices.
Ok... Here we go.
Make sure that both your phone and new headset are charged up.
Since every brand of headset is different, please refer to the instructions for "Pairing", but I will tell you how the most common headsets pair.
By the way, "Pairing" just means "connecting". If you find it more simple, you can substitute the word.
On most headsets, from the Headset being off, hold down the answer/end button down until the indicator light(s) glow a solid color (usually blue). This may take up to 10 seconds. They might flash first, then after a couple more seconds, go solid on.
On your handset, find the bluetooth menu.
On most phones, go to the settings menu, then to "connections" and then "Bluetooth". You are looking for a link to "Add a new device".
On Motorola phones, it is in the "Handsfree" link. Select [look for new device] select this option, and hit "OK".
Nokia Phones: look for "search for new audio enhancements". Hit OK.
On Samsung phones: **Bluetooth menu might be under "tools"** Look for "Add new device". Hit OK.
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
At this point, the phone MAY ask if you want to use the headset. This means all audio from phone calls would be routed to the headset rather than in to the phone's speaker or earpiece. Select yes, or ok.
Your headset is now set up for you to talk on like a REALLY important CIA agent or something of the like...
Keep in mind that when a call comes in, the phone will still ring like normal.
You can answer the call by either:
1. Pulling the phone out of your pocket and hitting the answer button.
2. Touching the answer/end button on your headset without reaching for you phone.
The range of your headset is up to 30 feet, in a direct line of sight.
If you go into another room, your range may be decreased.
If you do happen to go out of range, the call will be transferred back to the phone, and as soon as you are in range again, touch the answer button on the headset to let the phone know you're back in range. It will re-transfer the call back to the headset.
If you turn off the phone, or headset, you can repair them again simply by going to the bluetooth menu and selecting the headset again from the list. It will reconnect without a pass code and you are up and running again.
*** Please note that you do not have to hold down the answer/end button on the headset until it goes a solid on again.
Tips & Warnings
If you have difficulty, please feel free to contact me and I'll help you get things sorted out.
Mar 17, 2011 | Cell Phones
I need Sony Ericsson J105a passcode for use bluetooth
Instructions
Things You'll Need:
Ok... Here we go.
Tips & Warnings
T
Thanks for using fixya....
Jan 27, 2011 | Cell Phones
I need the passcode to re-connect my headset, motorola H350
The passcode is the same that you have entered in your phone . so switch on to activate the bluetooth in both the devices, the phone and the headset, the accept to connect by the passcode.
Sep 01, 2010 | Motorola Mobility H300 Wireless Headset
Where do i find the passcode for my new bluetooth
Here is a helpful link http://www.ehow.com/how_5169210_bluetooth-passcode.html
Phone passcode:
if you haven't actually manually changed it, the password is always the last four digits of your phone number (ex. 1-555-868-2212 your password is 2212). If you manually changed it, you need to call your cell phone provider and have that worked out.
-CompDoctor
Feb 17, 2010 | Just Wireless Bluetooth Headset Wireless...
I lost my passcode and now I can't connect my bluetooth
Phone passcode:
-CompDoctor
Feb 14, 2010 | Jabra BT8030 Bluetooth Headset
Ive lost my instructions for my headset device i need to know how to turn my phone to headset pairing mode
Hello my friend,do these steps
Pairing with another Bluetooth device
By pairing your KU990 and another device,
you can set up a passcode protected
connection. This means your pairing is
more secure.
1 Check your Bluetooth is On and Visible.
You can change your visibility in the
Settings menu.
2 Touch Paired Devices then New.
3 Your KU990 will search for devices.
When the search is completed Refresh
and Add will appear on screen.
4 Choose the device you want to pair with
and enter the passcode then touch OK.
5 Your phone will then connect to the other
device, on which you should enter the
same passcode.
6 You passcode protected Bluetooth
connection is now ready.
Using a Bluetooth headset
2 Follow the instructions that came with your
headset to place your headset in pairing
mode and pair your devices.
3 Touch Yes to Connect now. Your KU990
will automatically switch to Headset profile.
If you have any questions you can try reading the manual here
http://www.in.lge.com/Product/Manual/KU990.pdf
Jan 11, 2010 | LG KU990 Viewty
4pr909 bluetooth headset passcode won't work with samsung juke
had same problem with this headset on two phones and finally solved it.
1. make sure bluetooth on phone is activated (know that sounds silly but some people forget)
2. with the headset turned off, press and hold the on/off button on the headset until the light on the headset FLASHES CONTINUOUS BLUE AND RED (about 8 seconds). This is most important, because if lights on headset are not continuously flashing blue and red, the headset is not in discovery mode.
3. once headset is in discovery mode, go into "my devices" on bluetooth menu on phone and click to search for new devices. make sure phone and headset are close together. phone will say searching- BE PATIENT, THIS STEP TAKES THE PHONE SOME TIME. eventually phone will show that it found your headset.
4. once the phone lists the headset, click on the headset and tell the phone to connect to the device. at this point the phone will bring up a passcode screen. enter 0000, and tell it to connect. when it connects, the lights on the headset will automatically go to an intermittent blue. you should be all set.
the biggest mistakes my kids made trying to pair these headsets were:
1. failing to turn bluetooth on for the phone
2. turning the headset on in something other than discovery mode (continuous blue/red flashing lights)
3. not being patient enough to wait for the phone to find the device.
hope this helps
Dec 21, 2008 | Cell Phones
Bluetooth passcode
When pairing two phones, you need to set up the connection on both phones. One will ask you to enter the password when you are creating the new connection, which you will then need to enter on the second phone to complete the connection. This ensures that only people you allow to connect (people you gave the code to) can connect to your device.
As for pairing your headset, try this link:
http://www.phonedog.com/cell-phone-research/blog/how-do-i-pair-my-bluetooth-headset-to-my-phone.aspx
Jun 11, 2008 | LG VX9400 Cellular Phone
Cell Phones Logo
113 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
