Question about Dryers
Start button does not work
When i set the time desired and press the start button, nothing happens
  • 89 Answers
This could be one of three possible issues.
the start button itself may have failed
the door switch could be broken
one side of 240v plug is out.
Posted on May 28, 2009
    President:
  • 1,136 Answers
Hi, Could I get the model # so I can see exactly what model dryer you have?
Could be many things and I want to help you through this.
Vic
I need to change the hour time because of daylight savings time. How do I do that. I've been pressing the time + but nothing happens.
Press and HOLD the - or the + button until the time begin to move forward and press the negative button if you go pass the desired time.
Mar 13, 2011 | Bose Wave Radio
Greetings: Problem with auto grind Cusinart DGB600 coffeemaker. Properly prepared coffeemaker to brew coffee but noticed time is replaced by - - - . Suspected it was time to replace cleaning filter, which...
sounds like the coffee maker had a power surge. Try setting the time again.
1. Setting the Clock When the coffeemaker is plugged in, 12:00 will appear until you set the time. Entering "Time Set" Mode: To set the time, hold down either the "Hours" or "Minutes" button until the clock begins flashing (about 2 seconds). You are now in the "Time Set" mode and can operate either button to achieve the desired setting. The buttons can be held down to scroll through the digits, or pressed and released lightly to advance one digit at a time. When scrolling, the numbers will advance slowly at first and then speed up to the rate of about three per second. When the number displayed approaches the desired setting, release the button and press repeatedly to advance one digit at a time. Be careful to make sure that the PM indicator is on if a PM time is desired. Exiting "Time Set" Mode: The "Time Set" mode can be exited in one of two ways: 1. Press any button besides the "Hours" or "Minutes" button. This will exit the "Time Set" and activate the selected function. 2. Do nothing. If neither the "Hours" nor "Minutes" button is pressed for a period of five seconds, the "Time Set" mode will be exited. 2. Setting the Program Ti m e : When you press the "Program Set" button, it displays the current program time (default time 12:00 p.m.). Entering "Set Program Time" Mode: Press and hold the "Program Set" button (about 2 seconds) until the green light and LCD display begin to flash. This signals that you have entered the "Set Program Time" mode. The desired time can be set by pressing the "Hours" and "Minutes" buttons to scroll forward through the digits. Pressing and holding either button will allow you to scroll continuously, slowly at first, and then to accelerate to the rate of about three digits per second. As the desired time setting approaches, release the button and then press repeatedly to advance one digit at a time. The coffeemaker will start to brew at the programmed time. The "Program" mode cannot be entered if the c o ffeemaker is in its "brew" cycle. Exiting "Set Program Time" Mode: "Set Program Time" may be exited in any of three ways: 1. Press the "Program Set" button. This will cause the coffeemaker to revert to its previous state. If it was OFF, it will return to the OFF position. If "Programmed", it will revert to this state, and so on. This is a safety feature. 2. Press any other button (except "Hours" or "Minutes"). "Set Program Time" will be exited and the function of that button will be executed. 3. Do nothing. If neither the "Hours" nor "Minutes" button is pressed for a period of five seconds, the "Set Program Time" mode will be exited and the programmed setting will be in effect.
Dec 28, 2010 | Cuisinart DGB-600 Coffee Maker
Lost instructions for TE109 appliance timex timer.\r\nCan you help? Thank You & Merry Christmas
    • Plug your Timex seven day timer into a standard electrical outlet. Allow the timer's rechargeable battery to charge for at least 10 minutes before attempting to program the appliance; the battery will serve as a backup power source to prevent your custom programmed settings from being lost in the event the timer is unplugged or the power goes out.
    • Press the depressed "RST" button on the timer with the tip of a ballpoint pen to reset the timer's internal memory.
  • To Set the time on your Timex timer. Press and hold the "Set" button for three seconds or until the day-of-week indicator begins to flash. Press the "->" or "<-" button repeatedly until the desired day appears on the digital display; press "Set." Use the "->" or "<-" buttons to set the hours when they begin to flash; press "Set" when the desired hour is shown. Use the same process to set the minutes, then press the "Set" button again to confirm the day and time settings.
    • To Program a start time for your seven day timer. Press the ">" button to access the appliance's programming mode; the program number will begin to flash. Use the "->" and "<-" buttons to highlight the desired program number, then press "Set." Highlight the desired day and press "Set" again. Program the hour for your timer; press "Set." Set the minute and press the "Set" button to confirm.
    • wait for the timer to go back to std mode (like 10 seconds)
To program a stop time for your timer. Press the "Set" button to cause the day-of-week indicator to flash. Highlight the desired day and press "Set" to confirm. Adjust the timer's hour with the "->" and <-" buttons; press "Set" when the desired hour is shown. Set the minute for your timer and press the "Set" button again. Press the "Time" button to exit the setting mode.
Dec 17, 2010 | Timex Hardware & Accessories
How do you set the time and alarm on a MI2290 Memorex Ipod Dock system
Here's how to set the time, but I don't know how to set the alarm.
Hold the "Time Set" button until the time starts flashing, then press the "play/pause" button so that only the hour is flashing. Use the ">>" and "<<" buttons to set the desired hour. Once the hour is set, press the "play/pause" button again so that the minute is flashing. Again, use the ">>" and "<<" buttons to set the desired time.
To change to military time from am/pm, hold the "Time Set" button until the time starts flashing, then press the ">>" button. In order to revert back to am/pm, hold the "Time Set" button until the time starts flashing (if it is not already flashing) and then press the "<<" button.
Apr 07, 2010 | Memorex Travel Speaker with iPod Dock...
Dryer not working
How do you know the belt is on? Did you take the unit apart? Maybe a connection to the control knob came off. Otherwise:
1) Check the breaker to see if it has been tripped
2) Dryer plugged in
3) dryer door securly closed
4) if your unit is a single knob with various dryer settings, try a different setting (delicate, permanent press, etc)
5) if your unit has a start button, set the knob to the desired setting first, then press start.
Jun 09, 2009 | Whirlpool Dryers
I have a Zenith ZG120M alarm clock radio. I can't set it.
Here is how I set my ZENITH ZG120M radio alarm clock.
1) PRESS AND HOLD DOWN the HOUR BUTTON and then PRESS the TIME BUTTON to set the correct hour.
2) PRESS AND HOLD DOWN the MINUTE BUTTON and then PRESS the TIME BUTTON to set the correct minute.
To Set The Wake Up Time
1) PRESS and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the HOUR BUTTON to set the desired hour.
2) Press and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the MINUTE BUTTON to set the desired minute.
There are two light indicators that light up on the left side of the LED display...the top light indicator will come
on once the time turns to PM. The bottom light indicates the alarm is set.
Mar 25, 2009 | Timex T309TT Clock Radio
Operating Instructions Model No BA218
Setting the time and calendar
1. Press the [TIME] button once to enter Time Mode. The display shows the current time with hour, minutes, and seconds digits.
2. Press and hold the [SET] button for more than one second. The "Hour" digits of the time will begin flashing.
3. While the "Hour" digits are flashing, press the [^] or [down] button to set the desired hour time. Note: Press the [^] or [down] button once to advance the setting forward or backward by one digit. Pressing the [^] or [down] for more than one second will accelerate the forward or backward setting at a higher rate.
4. When the desired hour time is reached, press the [SET] button again. The "Hour" setting will be confirmed and the "Minute" digits will begin flashing.
5. While the "Minute" digits are flashing, press the [^] or [down] button to set the desired minute time.
6. When the desired minute time is reached, press the [SET] button again. The "Minute" setting will be confirmed and the "Year" digits will begin flashing.
7. While the "Year" digits are flashing, press the [^] or [down] button to set the desired year.
8. When the desired year is reached, press the [SET] button again. The "Year" setting will be confirmed and the "Month" digits will begin flashing.
9. While the "Month" digits are flashing, press the [^] or [down] button to set the desired Month.
10. When the desired month is reached, press the [SET] button again. The "Month" setting will be confirmed and the "Date" digits will begin flashing.
11. While the "Date" digits are flashing, press the [^] or [down] button to set the desired Date.
12. When the desired date is reached, press the [SET] button again. The "Date" setting will be confirmed and the calendar setting is complete.
Feb 21, 2009 | Oregon Scientific WW338H Weather Station...
Lg lre30451sw oven the start button doesn't work
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner, but I fixed it today!!
Sep 25, 2008 | Ovens
Setting the Time
First, turn the Function Knob (bottom-left of the Control Panel) to “Clock”.
Hours: Press and hold the “HR” button to go through the numbers quickly. When the number displayed approaches the desired setting, release and press(pulse) the button to advance one digit at a time.
Note: When the number passes 12, the PM light will be displayed on the LCD.
Minutes: Press and hold the “MIN” button to go through the numbers quickly. When the number displayed approaches the desired setting, release and press (pulse) the button to advance one digit at a time.
To finish setting time, turn the Function to any setting other than "Clock", or simply wait until the numbers stop blinking.
Jul 26, 2008 | Cuisinart DCC-1200 Coffee Maker
Keeps flashing 12:00
Hi jippers - try this :
When the coffeemaker is plugged in, 12:00 willappear until you set the time.
Entering “Time Set” Mode:
To set the time, hold down either the “Hours” or“Minutes” button until the clock begins flashing (about 2 seconds). You are now in the “Time Set” mode and can operate either button to achieve the desired setting. The buttons can be held down to scroll through the digits, or
digit at a time.
slowly at first and then speed up to the rate of about three per second. When the number displayed approaches the desired setting,release the button and press repeatedly to advance one digit at a time. Be careful to make sure that the PM indicator is on if a PM time is desired.
Exiting “Time Set” Mode:
The “Time Set” mode can be exited in
one of two ways:
1. Press any button besides the “Hours” or
“Minutes” button. This will exit the “Time Set”
2. Do nothing. If neither the “Hours” nor
“Minutes” button is pressed for a period
of five seconds, the “Time Set” mode will
be exited.
If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks and have a nice day.
Jeff
May 08, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Dryers Logo
59 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
