Question about HP LaserJet 8100N Printer - Refurbished
Printer has set for a while. The print quality is very poor. Black is grey, there are streaks across the page.
Streaking across entire page. Black is more gray than black.
  • 241 Answers
Take the cartridge out and shack it side to side a few times to move the toner around and reinstall it.
Posted on May 28, 2009
My Ricoh 3500 color printer no longer is printing in color--just greys. It does not seem to be a problem with the color cartridges. Also, it streaks from left to right across a page from light to lighter...
The streaking could be anything internal to the printer, such as the transfer belt or a drum unit. As for the lack of color, that sounds like it is a setting in the print driver that got changed from printing in color to printing in monochrome or grayscale. Look through your print driver settings to see if you can locate this setting and change it back to color. Also, once you print in color again you may notice that the streaking is a specific color, which will help to troubleshoot that issue.
Jul 02, 2010 | Ricoh Aficio CL3500N Laser Printer
Streaking occurs from top to bottom of page. Changed the black cartridge (streaking is black). Any ideals for this HP CP3525dn:
I had the same problem and it turned out to be the ETB (Electrostatic Transfer Belt) unit that needed replacing.
Check out this link:
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3690646&prodTypeId=18972&objectID=c02661860#A5
Go to the "Print/Interpret the Print Quality Troubleshooting Pages" section and run the tests. Click the "Click Here" link in "Step two: Interpret the Print Quality Troubleshooting pages" to see if it's the ETB.
Be warned though, the ETB unit is over US$500 (If you think that's bad it's $786 here in Australia even with dollar parity) however HP support will replace it free of charge if the printer is still under warranty, just give them a call (number on HP site).
Good luck
Stuart
Jun 16, 2010 | HP Color LaserJet CP3525x CC471AABA...
Lexmark z2300m....black printing suddenly started streaking. Prints first 6 lines then streaks on rest of page. Nozzle cleaning and manual cleaning didn't help.
Your best bet is to buy new ink cartridges.
Ensure that the entire assembly is cleaned thoroughly though, just to be sure. Nozzle cleaning is rarely useful.
Apr 07, 2010 | Lexmark Z2300 InkJet Printer
On my Test Pattern 2 the blue/light blue and green/yeallow have steeks in it. The documents that I print have streaks going across the page. I've cleaned everythign I can clean. The printer has 6,251...
SolutionFollow the given steps in the order presented to resolve the issue: Step one: Retry the print jobThe problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality modeIf reprinting did not help, try increasing the print quality mode.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Step four: Clean the printheadsIf the print quality is still bad, clean the printheads.
  1. Make sure the printer is loaded with unused white paper.
  2. Open HP Solution Center .
  3. Click Settings , Print Settings , and then select Printer Toolbox .
  4. Click the Service Tab .
  5. Click Clean Printhead , and then click Clean .
Step five: Align the printheads If the print quality is still bad, align the printheads.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
  2. Open the printer Toolbox and select the Printer Services tab.
  3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
  2. Press the Setup button.
  3. Press 1 and * simultaneously.
  4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
    • If the Black block has lines – replace the KY printhead.
    • If the Cyan block has lines – replace the MC printhead.
    • If the Magenta block has lines – replace the MC printhead.
    • If the Red block has lines – replace the KY printhead.
    • If the Green block has lines – replace the KY printhead.
Dec 21, 2009 | HP OfficeJet Pro L7580 InkJet Printer
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Streaks though the pages
Step one: Retry the print job The problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality mode If reprinting did not help, try increasing the print quality mode.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing. NOTE: This step does not apply to color printouts.
Step four: Clean the printheads If the print quality is still bad, clean the printheads.
Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP L7680 Printer Head Problem
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step two: Increase the print quality mode
In the application you are printing from, click File, and then click Print. Make sure the printer is selected, and then click Properties.
Select the Paper/Quality tab. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
NOTE:- This step does not apply to color printouts.
Make sure the printer is selected and click Properties.
Click the Color tab, and select Print Grayscale and High Quality.
Open HP Solution Center.
Click Settings, Print Settings, and then select Printer Toolbox.
Click the Service Tab.
Click Clean Printhead, and then click Clean.
Open the printer Toolbox, and select the Printer Services tab.
Click Align Printheads. The Align Printheads window opens. Click Align.
Click Calibrate Advanced Linefeed. The Advanced Linefeed Calibration window opens. Click OK .
If the Cyan block has lines – replace the MC Printhead.
If the Magenta block has lines – replace the MC Printhead.
Nov 08, 2008 | HP Officejet 5610 All-In-One InkJet...
Grey background over entire page.
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Sep 15, 2008 | HP Color LaserJet 2600n Printer
Samsung CLP 510 light grey vertical streaks
you have 2 problem.
1). toner is bad
2). toner is low
change the toner should fix both porblem.
try to clean the roller while you have the toner out. (just in case).
Mar 27, 2008 | HP LaserJet 5p Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
HP LaserJet 8100N Printer - Refurbished Logo
317 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
