Question about Microwave Ovens
LIGHT INSIDE OF OVEN NEEDS REPLACING --HOW DO I GET TO BULB
WHAT PART OF MICROWAVE PART DO YOU TAKE APART TO REPLACE INSIDE BULB ----THE VENT?? Thank You
  • 3,600 Answers
Normally there is a side door that can be removed to replace the inside light bulb, the microwave bublb is changed from a different location normally on the back.
Posted on May 28, 2009
How do I replace the lightbulb in the microwave and what light bulb do I need to purchase?
to replace the bulb in microwave ovens you will have to take the outside case off the unit as the bulb placement is not accessible from inside the oven
when you get to the bulb take it to an appliance repair shop and they will have a bulb
Sep 09, 2015 | In Microwave Ovens
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
Oct 19, 2014 | Microwave Ovens
The bulb light inside the microwave went dead with the microwave working perfectly...how do I replace the bulb?
Replacing the cavity light requires taking off the outer wrapper to access the bulb. Nothing easy or magical just an exercise in patience.
Eric
Jul 05, 2010 | Maytag MMV4205 Microwave Oven
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
INTERIOR LIGHT
You need to replace the internal light, that usually can fix the problem.
If replacing the bulb does not work, check the wiring to the light.
You can find the spare light and diagrams for your oven by entering model number here.
Feb 27, 2009 | General Electric Advantium 120 Microwave...
Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
REPLACING LIGHT BULB
i have a cookwork microwave the light stoped working
Sep 16, 2008 | Microwave Ovens
Replacing lightbulb in Sharp R953M combi microwave oven
most microwave ovens built in the last 20 years do not have an
access panel to the light bulb. you must remove the screws on the back of the microwave that hold the outer sleeve in place.
Then pull upward and backward on the sleeve to disengage it
from the front lip of the chassis. the light bulb should be close to the front of the microwave behind the control panel. Some lights
are not unscrewable from the socket, but the socket and bulb
come as an assembly.
Mar 26, 2008 | Microwave Ovens
Replacing oven light bulb
On the bottom. Remove bottom plate you will see them (2). Don't forget to unplug it and metal parts can be very sharp, be careful.
Dec 09, 2007 | GE JVM1640 Microwave Oven
Oven Halogen Lamp
It's pretty simple to replace the light without having to remove the oven from the wall...as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Aug 04, 2006 | GE Advantium SCA1000H Convection /...
Microwave Ovens Logo
552 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
