Question about Dell Dimension 8300 PC Desktop
Dell Dimension 8300 - Can't Boot from XP Disk
Greetings All,
I am having a problem with a Dell Dimension 8300 that I am trying to reinstall Win XP.
The desktop has the factory DVD-ROM and CD-ROM drive.
I just changed the hard drive because the original died.
The drive type is IDE with the jumper setting set to CS like the original. It is a 40GB drive (like original) that I know works because I removed it from another system.
When I attempt to boot from the XP CD, the disc is not read. Instead I get a message that says to hit F1 to retry, and F2 for setup (BIOS Setup). In covering all the bases, I've tried this on both the DVD and CD drive.
In BIOS, I have tried a number of different options in forcing boot from CD.
*Moved the CD-ROM was the first boot device.
*Removed the hard drive from the boot order
*Upon startup, hit F12 for boot menu and select CD-ROM.
*Replaced the CD-ROM drive with a known working CD-ROM drive from another system.
I've also reset the BIOS to make sure that I am running off default settings.
At this point, I am out of options.
I know my CD works, for I have used it before; especially recently; yet I haven't a clue why this 8300 just remains stubborn.
Any help or insight would be greatly appreciated.
Thanks!
  • Frankie Cruz
    Frankie Cruz Jun 02, 2009
    Thanks Guys,
    Removing the DVD drive (thanks crapiemael) via physical connection absolutely had be done as opposed to just disabling it via BIOS. I don't know why just disabling it via BIOS wouldn't do the trick, but that's what happened.
    Once physically disconnected, I was able to boot XP off the CD-ROM and install the OS. After installing XP, I then reconnected the DVD-ROM and allowed to be added automatically as a new device.
    Unfortunately, the hard drive set at Master (instead of CS) didn't work well.
    When I set it at Master, it shows as "Physical Unknown Device" and
    doesn't provide me the area to unput the specs per the drive. This machine in particular wanted to see CS, and that's
    it!
    Thanks for your input AtlastIT. The UBDC is a neat tool and will definitely come in handy!
  • Kevin Kraft
    Kevin Kraft May 11, 2010
    Have you tried booting a different CD on this machine? If you need a bootable CD to test, you can Google UBCD and download or download a Linux distribution just to test.
  • 241 Answers
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
Posted on May 28, 2009
My desk tot computor runing office xp will not let me log on after installing new driver
go in safe mode and make rollback.if you now the driver go into taskmanager.make a rollback.it's strange the computer should work after reinstall.have you scaned it whitout ethernetcontact.
Mar 23, 2013 | Dell Dimension 8300 PC Desktop
I am trying to re-install windows xp on a DELL dimension 8300 but it does'nt boot it can go to the BIOS and everything but it say Boot.mgr is missing
You should use the bootable Windows XP CD to start the installation.
To do that, you must first enter the BIOS in the Boot Options select the DVD drive as first (so that it will boot from CD/DVD first, instead of the hard disk). Save and Exit, insert the bootable Windows XP CD in the drive and when prompted to do so, "press any key to boot from CD-Rom".
Hope the above helps.
Mar 13, 2011 | Dell Dimension 8300 PC Desktop
How do I reformat a Dell dimension 8300, it will not do anything after inserting the operating system disk
You need to make the DVD drive the first bootable device.
F2 on boot up should take you into the bios, it should say on the first screen as you boot what key takes you into the bios/setup.
Change the boot settings to allow the dvd drive to boot first.
It should now say press any key to boot from cd/dvd when you put your installation disc in
Sep 04, 2010 | Dell Dimension 8300 PC Desktop
Misplaced cd for operating system
reinstall CD will not help u do a clean install after formating, so u need to get a windows install CD....try piratebay.org u can get the torrent link file there for any win OS and download that, it will get u the full working version of any Win OS in google do a search "Torrent piratebay Windows XP" u also need to get/install BitTorrent software from google/internet to get the torrent link file...
the full file of WinOS say 400 - 700 mb may be a ISO file that u need to burn to a CD so that u can boot from the disk and install windows
Feb 01, 2010 | Dell DIMENSION 3000 CELERON 2.4GHZ...
Dell Dimension Startup
try going into your BIOS and changing the boot sequence, it may be set to boot from floppy instead of harddrive. or you could just reinstall windows, but that sucks cuz then you lose all your data and programs. and not to be rude, but you shouldnt have bought a dell, they are full of problems.
May 11, 2009 | Dell Dimension 3100 PC Desktop
Windows Will Not Boot
your harddisk got virus or some bed indexing units.
I also get this eerror then i have win xp bootable disk then i boot my cxomputer with win xp and go to recovery console then type "chkdsk /r"then press "y"
then it fix the eror on disk then i restart winxp and all worrking fine but my system has some virus theh i remove all virus from it with avast antivirus in boot time.
May 08, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Need a 1394 PCI Firewire card for Dell Deminion 8300run.XP-SP3
Sure....this will work for you.
Thanks and please take a moment to give this solution a rating of fixya. Thanks! :c)
Feb 13, 2009 | Dell Dimension 8300 PC Desktop
I'm having an issue reinstalling Windows XP on a Dell Dimension 8400 PC.
Okay you need to boot from cd
put win cd in drive restart when asked to boot from cd hit enter
this should get you there
if not we'll have to change your boot options
Jan 15, 2009 | Dell Dimension 8400 PC Desktop
How do i Reinstall Windows on Dimension 3000
When you see the Dell screen on startup hold CTRL and tap F11. This will bring you into the Dell specific restore utility.
Jul 26, 2006 | Dell Dimension 3000 PC Desktop
Dell Dimension 8300 PC Desktop Logo
2,104 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
