Question about HP LaserJet 3330MFP All-In-One Printer
HP Laserjet 3330 w/ green fax light staying on and orange cancel light blinking My Fax is not reciveing and every time someone trys to send me a fax it says Busy. What can i do to fix this problem so my fax can start working again??
Start it up again from the power source, press the menu enter button to get to service , use the < button, under service, press menu/enter, browse to service: restore defaults, press menu/enter twice.
It works, give it about 2-3 minutes to finish rebooting, it will continue flashing and then go away
Posted on Jul 22, 2009
My 3330 HP scanner bulb does not go away, the cancel light is flashing, the green fax light is blinking
I have serviced many of this machines and in your case the scanner unit will have to be replaced.
The only down part of this is that you can`t find this part on HP Service because HP will not make parts for this printer again.
Jun 06, 2011 | HP LaserJet 3330 All-In-One Printer
TRYING TO USE THE FAX PART OF THE 3330 HP PRINTER BUT IT WILL NOT SEND OR RECIEVE WHEN THE PHONE LINE IS PLUGGED IN. WE SWITCH BACK TO OUR OLD FAX MACHINE AND IT WORKS JUST FINE
Hi, first of all you have to be sure that you are plugging the cables in correct places. Then please press the "on hook" dial button and if you dont hear any signal then maybe your HP has damaged fax option. Also there is a difference between "pulse" and "tone" line signal. Please check that option in the fax menu.
Best reggards
dipl. eng. Pifonski
Feb 18, 2011 | HP LaserJet 3330 All-In-One Printer
A report for sent faxes
Look on page 31 to set Fax Call Report Time, set it to "send fax only" for Tx confirmation report.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/bpl11457/bpl11457.pdf
Sep 23, 2009 | HP LaserJet 3330 All-In-One Printer
Describe your hp laserjet 3330 ?
The problem may be in the machine you're sending to, if you get a copy thru the adf or on the glass with no lines, it's the same image you would send thru fax. Check the narrow glass though, I usually find white out on that glass and have to clean it off.
Aug 11, 2009 | HP LaserJet 3330 All-In-One Printer
Tried to print something from the glass, got error message
this is usually the case when certain settings that are required by the registry are not in place, The solution could be as simple as unistall the scanner driver restart the system and reinstall the scanner driver.
If this doent work get back old registry values by going to start-Programs-accessories-system tools -system restore and restore the settings to the time when youre sure the scanner worked .
Jul 09, 2009 | HP LaserJet 3330 All-In-One Printer
The hp laserjet 3330 diverts to fax too quickly
What you need to do is on the printer, hit the menu/enter button, then scroll through until you see "Fax Setup" click enter, then scroll until you see "fax receive setup", click enter, then scroll until you see "rings to answer". Here can you set it to a higher number of rings, just remember to click enter once you've got the number set to where you want it.
How to fax from glass on laserjet 3330
Use the alphanumeric buttons on the device control panel to dial the number.
If the fax number you are calling has been assigned to a one-touch key, press that key.
If the fax number you are calling has a speed-dial entry, press phone book, use the
alphanumeric buttons to enter the speed-dial entry, and then press menu/enter.
Note When dialing by using the alphanumeric buttons, include any pauses or additional numbers
that are necessary for the call, such as an area code, an access code for numbers that are
outside of a PBX system (usually a 9), or a long-distance prefix.
2. Load the document onto the flatbed scanner face down.
select YES when Send from glass? 1=Yes 2=No
appears, and then press menu/enter..
If this fixes your problem please rate this as fixed. If it didn't,please don't rate and add a comment and I'll be glad to help you further. Thanks.
Apr 18, 2008 | HP LaserJet 3330 All-In-One Printer
HP LaserJet 3330MFP All-In-One Printer Logo
327 people viewed this question
Seeker5211
Seeker5211
