Question about Spark Plugs BR4HS Plug 10/BX #3322
Misfire on 1999 kia sportage
Where are the spark plugs located on a 1999 kia sportage 2.0 engine
    Problem Solver:
  • 11 Answers
Go to autozone.com and register. its free. then put in all your info,year ,make, model, engine, and they have repair guides free.. hope it helps!
Posted on May 28, 2009
How does the 2.0 liter kia engine ignition system work
No engine fires all spark plugs at one time.
Ever see an engine that has all pistons come up
at the same time,won't work designed like that
Injectors fire along with the plugs!!
You'll have to access a factory diagnostic
manual, if you want to know the misfire detection
strategy for your motor.
Could ask that question using Google or study
your motor on the internet
Jul 16, 2013 | 1999 Kia Sportage
Misfire and poor acceleration in kia sportage 1999
either you have a faulty gas pump, one or more spark plugs or cables ar going bad or nrrd to br replace, could be a vacuum leak too, yourcar have the check engine light on? if so, need to know what code the will help you a lot.
Nov 24, 2011 | 1999 Kia Sportage
Can oil in spark plug hole after changing coil packs,plugs and wires cause 1999 Sportage to run worse than before? Engine is "dieseling" and blew white smoke for a minute or two. Changed valve...
The oil down the plug hole will cause the white smoke, and as you said it cleared in a couple of minutes, but also may have oil fowled the new plug. It cannot have damaged the engine.
pull the oily plug out and clean it in some solvent and try again, make sure the plug caps dont have oil on them
Apr 24, 2011 | 1999 Kia Sportage
My 1999 kia sportage glx se is misfiring but still drives,there is no warning lights on dash no engine managment light on either, would this just be the spark plugs ot the spark plug leads that is causing...
Check your fuses the one for check engine light might be bad. Every time I had a misfire with my Kia the check engine like came on. You may also take it to an Auto Zone or a store that checks the computer of your vehicle for free. If it is a misfire there are a few remedies I know of
First if you haven't changed your spark plugs in the past few years you should look at replacing them.
Second older vehicles the gas tends to get sediment in it because you are not using all of the gas in your tank even if you run it out. I found that out because it would drive fine until I filled the tank up which in turn churned up the sediment from the bottom went through my gas line and caused a misfire. The easiest way to fix that is maybe a gas treatment which may break down the sediment. The harder and more expensive is drain the tank change the pump and the fuel filter. You don't need to drain the tank entirely to change both but it defeats the purpose of change both and still having sediment in the tank.
Third in order get the computer checked, change spark plugs, have leads checked, then use fuel treatment. Just so you know when you use fuel treatment it will run a little rough at the beginning because the sediment is being broken down give it a week or so to let it run its course.
good luck
Apr 13, 2011 | 1999 Kia Sportage
How to change plugs on 02 kia sportage
  • 1
    Keep a regular schedule for inspecting the spark plugs on your 2002 Kia Sportage. According to the official 2002 Kia Sportage owner's manual, spark plugs and ignition wires should be inspected every two years or 48,000 miles, whichever comes first.
  • 2
    Let your 2002 Kia Sportage sit for a few hours before opening the engine compartment. You want to make sure that the engine is cool before you begin working on it.
  • 3
    Pop open the hood of your Sportage and locate the ignition wires, which will be attached to the top of your engine. The 2002 Kia Sportage has a four-cylinder engine, meaning there are four spark plugs each attached to an ignition wire. The ignition wires run from the engine to the fuse box, which is located in the left side of the engine compartment.
  • 4
    Inspect the ignition wires of your 2002 Kia Sportage. These wires will need to be replaced if they appear worn.
  • 5
    Disconnect the ignition wire to your spark plugs. Grab the rubber boot located near the base of the wire and pull upward instead of yanking on the wire. Remove only one wire at a time, or mark the wires with a colored Sharpie marker before disconnecting all of them. Improperly reconnecting the ignition wires can seriously affect the performance of your Kia Sportage.
  • 6
    Attach the spark plug socket to your socket wrench. Use the socket wrench to remove the spark plug from the top of the engine's cylinder.
  • 7
    Inspect the spark plug. There will be some soot, but if the spark plug is completely covered in soot, it needs to be replaced.
  • 8
    Position your replacement spark plug in place and secure it with the spark plug socket on your socket wrench. Be careful not to overtighten the spark plug after it has been snuggly fitted.
  • 9
    Position the rubber boot of the proper ignition wire in place above the spark plug and insert it with your hands. Close the hood of your 2002 Kia Sportage
  • Mar 16, 2011 | 2002 Kia Sportage
    2000 Sportage: where is the spark plugs located on a 2000 Kia Sp...
    They are under the black plastic cover that is in the middle of your valve cover gasket. Remove the intake hose from the aluminum intake plenum on top of the valve cover and the silencer box against the firewall. Remove all the connectors from the sensors which should be 2 on the plenum and the 2 large vacuum hoses on the plenum. Then remove the 3 12mm bolts from the plenum at the throttle body and remove the plenum. You can reuse the throttle body gasket at the plenum so don't destroy it. All the other bolts are 10mm and use a screwdriver to loosen the clamps on the hose. The sensors have clips that you need to remove with a small screwdriver, then disconnect them. Remove the bolts on the cover and the cover. Then remove the bolts holding the coil packs down. Do one plug at a time. 2 of them are connected to the 2 plug wires and 2 are underneath the 2 coil packs. The connectors on the coil packs are fragile so remove them carefully. Reverse the steps to reinstall the plenum, etc.
    May 16, 2010 | 2000 Kia Sportage
    My 99 kia sportage is misfiring, and there is oil in the spark plug. Also the kia doesn't want to run over 55 mph and to get it to go that fast the rpms are all the way up to 4. Changed spark plugs and...
    Hi, it might be caused by an oil ring on the piton that broke or pistons that is damaged. If you do a compression test, you will be able to find out at which cylinder the engine is misfiring and then you will need to take the cylinder head off to determine the extent of the damage.
    Nov 10, 2009 | 1999 Kia Sportage
    Trying to change the spark plugs and can not find them
    If you look under the hood, you will see a BLACk cover under the intake tube.this black cover has 6 bolts and has to come off..its alot of work to take everything off..under this black cover are 2 COILS with 2 spark plugs under them.
    DO NOT REMOVE the plugs with the egnine hot .this car has aluminum heads and you will strip the plugs.
    The other 2 wires can be more easily seen and have a black boot on them..under the 2 black rubber boots are the other 2 spark plugs..
    Lots of Kia sportages misfire and skip and the check engine lite will come on..usually its a bad wire or plug..very common in these cars..also, if the VALVE cover gasket LEAKS at all, oil will get into the boots or wires or plugs and cause the car to skip and idle rough or MISFIRE..
    Good luck and hope this helps.
    May 24, 2009 | 2002 Kia Sportage
    Spark plugs
    the spark plugs are under the little black cover in the center of the engin you have to remove the air intake to get to them but not too complex
    hope this helps
    Sep 16, 2008 | 1999 Kia Sportage
    Spark Plugs BR4HS  Plug 10/BX #3322 Logo
    227 people viewed this question
    Top Ngk Vehicle Parts & Accessories Experts
    Ian Kime
    Ian Kime
    steve morris
    steve morris
    Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
