Question about Dell Inspiron 1420 Notebook
My screen goes to white after booting up
I turn on my comnputer and after it does the whole login process, icons are visible, i'm getting ready to search for my wireless internet and it hesitates and then goes to a white screen. i facing the same problem. after i update my windows, my screen turn white when i login. try to login safe mode also fail.
  • 2 more comments
  • e_jhyong May 29, 2009
    i already try that before. it doen't work.
    re: uncleandy82 on May 28, 2009
    yup. just after my windows update. at first i still can login safe mode. after a while, my safe mode also turn white screen.
  • Andy May 11, 2010
    Hi, you say the problem started after you did a windows update? Have you tried starting up with the last known good configuration?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Did the whole problem start happening after you ran a window update?
    Does it happen at all during the time the laptop boots up?
  • 197 Answers
You might need to restore your system. To do this go to Windows, click accessories, click system tools then click system restore. Restore back your machine the date before you updated your windows.
Posted on May 28, 2009
  • iya velasco
    iya velasco May 29, 2009
    try to use external monitor and if on the external monitor is ok, update your video driver. if not display on both, suspected faulty monitor. you might need to change it.
Acer Aspire 3610
How far does it get in booting. Do you see the Windows screen with the side scrolling bar before it reboots. During the boot process, start hitting the F8 key once a second until it drops you into a menu where you can select to start in Windows with safe mode. If you cant get that far, hit the DEL key a few times a soon as you boot the computer to try to go into your BIOS. If you can get into either of these, I may be able to help you.
Jan 23, 2008 | Acer Aspire 3610 Notebook
Laptop screen display -when laptop is started screen message reads prepairing atoatic repair. then message dissappears and only mouse icon is visible.
On boot up tap the F8 key until you get a menu. Select Safe mode. If it boots disable all startup processes and services by clicking Start, run and type msconfig. Reboot, if it boots the you can enable one item and reboot until it no longer works and you will have your culprit.
May 16, 2013 | Compaq Presario CQ58-a10NR 15.6" Windows 7...
I tried normal but it didn't work so I tried safe mode and it din't work The mouse icon stays there then the computer goes off then I click the mouse and it goes back on the login screen never pop up
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps.
Jan 15, 2013 | Computers & Internet
My X boyfriend made nhiself as adminestrater . He changed my password and im unable to get in.
You can usually login as a different user by following these steps:
  • Switch on your PC and press F8 repeatedly. This will take you to a menu screen with the option to boot using safe-mode.
  • Select safe-mode using your arrow keys and press the 'enter' key. It will now boot up as far as your login screen.
  • the login screen should show you 2 icons, the first will be your administrator icon and the second will be for a guest login.
  • Click on the guest login icon to boot into windows
Note that you may not be able to access some of the administrator files depending on the administrator's security settings.
From here you should be able to create a new user profile or alternatively you can re-install your operating system.
Best wishes,
Graemevm
Jan 08, 2012 | E-Machines eMachines Desktop PC
White screen after i get to desktop after login
Restart laptop, hit F8 Repeatedly, boot safe mode, then do a system restore as far back as possible, Post here again if that doesn't fix the solution.
Oct 22, 2009 | Dell Inspiron 1525 Laptop
Video screen will not display after pc goes thru it start up sequence. But during start up process will display window welcome page
Try restarting the computer in safe mode and when it boots, see if the screen is visible. If it is then there is an incompatible screen resolution that is trying to be displayed in normal mode. Set the default screen resolution to one that you know works with the adapter....usually 800 X 600 is safe until you get a normal boot. If you have video during the booting process than I do not believe it to be a hardware problem, usually windows driver or a setting.
Aug 31, 2009 | Computers & Internet
KB mouse not working...screen goes white..
Check the cmos setup and see if the KB and mouse have been disabled.
May 10, 2009 | Computers & Internet
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Open Questions:
See all Dell Inspiron 1420 Notebook Questions
Dell Inspiron 1420 Notebook Logo
500 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
