Question about LG WM-1832C Front Load Washer
LG WM-1832 C
How do you repair a loose inter tub?
  • gwing89 May 28, 2009
    The spin tub is loose from the back. I have all srews out of the back and have hit the center shaft with a rubber hammer. Nothing has moved or broken loose to this point.
  • 89 Answers
The spin tub
or the entire tub itself?
if its the spin tub inside, it would be caused by serious issues
the whole tub is just a replacement of the suspention. access is through the rear.
Posted on May 28, 2009
  • slypp187 May 28, 2009
    that would be a broken inner tub. unfortunatly common on this machine.
    the break would be on the yoke inside. with this machine hard water and improper laundry detergent (non HE detergent) can cause this.
LG WM-1832 Awful noise - Spider in broken - How to fix ?
Seems like you need beaucoup parts and with what they charge for parts you just might be better off getting a new machine.
If you go to the attached link you can find out the part numbers and prices of the parts you want - if you ask them your question they will have the answer for you right there. http://www.appliancepartspros.com
Mar 24, 2017 | LG WM-1832C Front Load Washer
How do I open a lock LG WM 1832 CW front end washing machine with water and clothes inside?
First you will need to get the water out and really the only way to do that if the unit won't drain it is to open the filter to get the water out and besides that, there is probably a blockage at the filter that is preventing it from draining in the first place. You will need a lot of towels handy or a wet/dry vac at the ready!
Nov 28, 2012 | Washing Machines
Washer say on screen LE and will not turn.. Also when manually turn the turn hear grinding noise too.
Grinding noises are bad. If you are lucky, you got an item (like an underwire support from a bra) between the inner and outer tub, which may be removed through the heater or drain openings in the tub. If you are un-lucky, your rear tub seal failed, causing the rear bearing to fail, or the shaft broke loose from the 3 arms of the spider which drives the inner wash tub. Either of those things is $$$ and a lot of work to repair, involving removal of the outer drum, seperation of the outer drum halves, and repair. (translation: minimum 2 hours labor if you've ever done one before)
Feb 28, 2011 | LG WM-2277HW Front Load Washer
Machine will not discharge water
Any error codes? Pumps out OK?
Sounds to me as if the cold water inlet screen is plugged up, preventing rinse water from entering machine. Turn off the cold water to the machine and remove the cold water supply hose. Check the screen inside where the hose came off the machine. Run some water out the hose into the drain or a bucket before reconnecting to machine. Let me know if you still have problems.
Apr 19, 2009 | LG WM-1832C Front Load Washer
LG wm -1832c front loader making noise
when you take the panels off you will see that the barrel is suspended by springs on top and fake struts on the bottom. be careful when removing the panels. if the barrel is leaning forward it's the front struts, if it's tilting upward it's the rear. and be careful how much you load in a front loader
Feb 17, 2009 | LG WM-1832C Front Load Washer
How do I make my WM 1832 CW washer ready to move?
It is best to re-install the four shipping bolts in the back of the machine during the move. If you don't have them, contact a dealer. Please don't rate, as anything but a Fix-Ya lowers my score. Thanks.
Jan 26, 2009 | LG WM-1832C Front Load Washer
How do I make my washer ready for moving? I have an WM 1832 CW
you should ( ifyou have, reinstalla the origianl shipping brackets) thiswill preventthe machine from bouncingaround internally
Mildew smell on cloths
The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
If your washer is a LG WM-1832 it has a assessable filter behind the access door on the lower left front of the machine. Clean that out first, and if it has a tub clean or sanitary cycle use that cycle (if not, use hottest longest cycle available) with 3 Affresh tablets or use whirlaway to clean out the washer outer tub (the not visible tub that holds the water). You might want to use another cycle like that with bleach to head off mold or mildew growth. Use of proper amount of detergent and fabric softener should really help the clothes odor issue from then on. Also check the tub seal at the bottom of the door area to clean out any lint from drain hole areas to help prevent water from remaining in the tub seal area.
Oct 28, 2008 | LG WM-1832C Front Load Washer
Water continues filling and overflows
Tubing at bottom of tub was loose and leaking, reinstalled it and installed a clamp and it works
Dec 01, 2007 | LG WM-2432H Front Load Washer
LG WM-1832C Front Load Washer Logo
211 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
