Question about Whirlpool ED2GHEXN Side by Side Refrigerator
Crushed ice dispenser not working
Crushed ice not coming out, only cubed with a tiny amount crushed...keep hitting button but to no avail. Please help!
  • 64 Answers
Remove bin and all ice. clean out bin with warm water as it is not shifting ...jambed with ice/snow
Posted on Aug 26, 2009
Getting shaved ice instead of cubes
Several possibilities, but check first for cubes that are too small (means too little water is coming in during ice maker fill) and those cubes fracture into smaller bits when they are dispensed.
Another possibility is the cube/crushed plate inside the dispenser is stuck. This is a curved plastic piece that lies next to the crusher blades inside the dispenser head of the ice storage bin. For cubes this place must be retracted (swing away from) the crushed fingers to allow the cubes to pass without being broken up.
Oct 30, 2016 | Refrigerators
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Mu Kenmore refrigerator's ice maker is dispensing crushed iced even in the cube mode
Take out the ice bucket and check the metal arm and make sure it moves freely. Ice may have gotten stuck.
Jul 20, 2016 | Kenmore Refrigerators
Dispenses crushed ice instead of cube ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
Aug 17, 2009 | Refrigerators
Kenmore side by side will only produce crushed ice and not cubed
remove the ice bucket inside and clean any clogged ice from inside the dispenser.
Apr 29, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Ice dispensor only dispensing crushed ice - not cubed
Make sure that your ice tray is properly instaled. There is a rod that must go into a hole. When you select ice cubes rather than crushed ice a solenoid raises which moves that rod. It then opens a flap so the cubes can bypass the crusher. Either your rod is not in the hole correctly or the solenoid has gone bad. The rod that I am speaking of runs along the underside of the ice tray. It has a spring on the rear end that holds the bypass flpa closed.
Dec 02, 2008 | GE GSH22JFT Side by Side Refrigerator
Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker only dispenses crushed ice, not cubes
There is an opening next to the auger that dispenses the ice.  In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed.  Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Viola! Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
check it out!  Thanks to Jake!
Apr 03, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Whirlpool ED2GHEXN Side by Side Refrigerator Logo
116 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
