Question about Dewalt Heavy - Duty 18 Gauge 2" Brad Nailer Kit Reconditioned - D51238KR
Airy brad nailer ATK 0250S
When I connect the gun to the air supply, air just constantly runs out of the top/frount. I opened the top and found that a flat washer needs replacing. It is not a rubber washer but seems to be teflon. Only half was there and very brittle. Any ideas were I can find a replacement washer? When i hook up to the compressor air comes out of the trigger and does not work???thnaks mb
Try Samona International or Summit Tools in Burnaby, BC.
Posted on Oct 04, 2010
  • 52 Answers
Ereplacementparts.com. see if they have a schematic for this gun. Good luck sound like a head cap seal.
Posted on May 28, 2009
Gun leaks
No it is not. It should not leak at all. Where is it leaking air from? The 3 obvious places are the exhaust at the top of the head, the nose where the driver comes down, and the trigger valve.
Jul 29, 2012 | Campbell Hausfeld 2-in 18 Gauge Brad...
My nailer won't work
Do you have a constant air leak at the head of the gun? If so you have a blown diaphram seal. Order from mfg.
Feb 10, 2012 | Shop Fox W1776 18 Gauge 38"2" Brad Nailer...
The gun constantly exhausts air when connected to air compressor. Won't build up the pressure when connected. Must disconnect between firing trigger
Easy fix if air is leaking out the top of gun. Remove the head and lube with white grease or silicone paste. If orings seem to be loose, order repair kit from dewalt (you can tighten orings by removing the oring and wind a bit of teflon tape in the oring groove). If air is leaking from the trigger, replace the valve. If air is leaking out the bottom where the nail ejects, pull out the cylinger and lube the orings that seal the cylinder to the body of the gun.
Oct 19, 2011 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Does the brad nailer only use 2" brads or cam smaller nails be used also
Most nail guns are labeled with the longest nail/brad they can shoot but are capable of shooting shorter nails/brads. There should be a data sticker on the gun, usually on the magazine rail, or at least in the manual that tells you what pressure to operate the gun at, what guage brads the gun can shoot and the size of brads from shortest to longest it can handle.
Oct 22, 2010 | Sears TNT 3 gal Air Compressor with 2 in...
I have a Porter Cable brad nailer BN125A, at 125 PSI and depth adjustement turned to the deepest drive setting, the brad does not set flush with the surface. Problem?
A brad nailer in good working order, set to the deepest setting and using 125psi should almost shoot the brad through the wood. If you have been oiling the gun properly (three to four drops at he beginning of your work session and again in the afternoon if under constant use) then you probably have some worn o-rings inside the gun. Porter Cable makes a driver maintenance kit (PN1001 60062) for your gun that will make it work like new.
Oct 04, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
How to remove brads jammed in the nailer
Open the top where the plunger is...remove the jam and push the plunger back..close up the gun and you should be fine. Make sure you disconnect your air hose first!!!
May 09, 2010 | Tools & Hardware - Others
The driver doesn't return after firing. it is a porter cable brad nailer BN200
This is pretty common with brad nailers
Remove the brads from your gun - disconnect from the air supply
On the front of your gun is a latch - open it
Check the sliding surface for build up of dirt or small pieces of metal from the brads.
Once clean polish the surface with a fine steel wool or a small brass brush
Reassemble with a drop of machine oil on the sliding surface
Oil your gun as you normally would
Using a piece of soft wood dry fire the gun 10 or so times to ensure that the dents it is making in the wood are all pretty even
Reload and nail something
Mar 08, 2010 | Porter Cable-Cable BN200B 5/8-inch to...
You should be able to find a local Dewalt/Black and Decker service/repair shop and they will be able to sell you all the parts you need, I would recommend getting a full upper rebuild kit and replacing everything, while you have it open already
Mar 15, 2009 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Magazine cover for airy nailer
Airy no longer has a home base in the USA. E-bey might be your best option
Feb 23, 2009 | Tools & Hardware - Others
Nails won't shoot
18 guage nailer has a very thin driver and plastic cylinder which bends or breaks easily. Remove the head noting all the parts in the head and remove the piston which should be at the top of the cylinder. Check for broken or bent shaft. Most likely broken and jammed in cylinder. Parts are not expensive. Check WWW.toolpartsdirect.com for diagram and parts
Nov 17, 2008 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Dewalt Heavy - Duty 18 Gauge 2" Brad Nailer Kit Reconditioned - D51238KR Logo
621 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
