Question about Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump
Tring to take the pump face off the motor
I have a Sta-Rite pool pump I am trying to remove the seal plate I need some tricks or tool suggestions to remove the seal plate. What shoud I use to remove the impeller?
  • Anonymous Mar 13, 2014
    Leaks at seal plate
  • 3 Answers
You have to remove the back cover from the motor. Next loosen the capacitor. Put a 7/16" wrench on the shaft and the pump impeller will screw off by hand.
Posted on Jun 04, 2009
My sta rite pool pump motor is starting to squeal
motor is going bad probably overheating seals replace whole unit
Aug 08, 2012 | Sta Rite Pool & Spa
STA-RITE 5P2R-125G with 0.75 HP motor. Had bearings in motor replaced and was advised that shaft seal is also replaced. Now have a leak from the motor side of the seal plate at the bottom. They replaced...
the absence of the copper cone will not cause a leak, however, there is a different shaft seal that needs to be used in lieu not having the copper cone installed.
If the impeller is damaged or cracked, that can cause a leak at the shaft seal. If you replace the impeller, the shaft seal will most likely need to be replaced as well.
Feb 23, 2012 | Hayward 1 Hp 2 Speed Super Pump Inground...
Have a Sta-Rite 1.5 hp Model #HMSF 1F - trying to get it apart to change seal- has been leaking and losing prime- four bolts hold the motor on- tried to separate there first but will not pull apart (maybe...
Remove impeller housing cover. Insert screwdriver carefully into back of motor to keep the armature from turning then unscrew impeller clockwise or opposite the direction of operation. Replace seal on impeller and pump housing. Lube seal with graphite. Replace impeller and housing cover. Remove screwdriver from motor. You should be good to go.
Sep 10, 2011 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
I have a Sta-Rite 1 HP pump for my inground pool. The motor started squealing and I bought a new motor and seal. I replaced both but I can not get the pump to stop leaking past the seal. I have even...
Thank you for posting your question here on Fixya.com.
It is likely how you are installing the seal. You can not touch the faces of the seal as you install it and need to be very careful with how you press the parts into place. Another common problem is not removing all of what was left of the original seal insert (the copper piece). Finally, inspect the area around the impeller threads for hairline cracks. If you notice cracks where the bronze bushing molded into the plastic meets the plastic replace the impeller. Those cracks can let leaks thru.
When installing the seal faces use a clean, dry cotton rag to apply even pressure with. Do not use petroleum based lubricants to ease installation. Instead use synthetics like magic lube to grease up the surfaces. A small piece of 1" PVC or a bearing driver works well for installing the insert. You can also use the small cardboard insert from the seal package as a means of covering the seal face as you press it.
In the end making sure you follow these directions you should be able to stop the leaks. Try using the new seal after you thoroughly and carefully wipe it clean. If not, replace them one last time and handle with care.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Jan 05, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Pump is leekin water
there are a couple of places where the pump may leak. The discharge fitting, the seal plate o-ring, or the shaft seal. If the shaft seal is leaking, water will be dripping from the bottom of the pump where the motor mates to the seal plate.
Sep 16, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
How do you replace a seal on a Sta-Rite pool pump? How do you remove the old seal? Ceramic and graphite.
Replacing a shaft seal requires some good mechanical ability.
first, always make sure power is off at the breaker before you work.
You'll have to remove the band holding the wet end to the seal plate. Then remove the diffuser covering the impeller. Remove the cover on the back of the motor. You either need a 7/16 open end wrench or a armature tool to hold the motor shaft while you unthread the impeller (if the impeller has a screw in the middle, you will have to remove it by turning clockwise, left hand threads) counterclockwise. You can then pull the carbon part of the seal off of the impeller, make sure to remove all of it including the metal sleeve. You will then have to remove the seal plate and push the ceramic part out from the back. You can then clean and lube the seal plate and install the new ceramic part of the seal, try not to touch the ceramic with your hands if possible. You can then lightly lube the impeller shaft and slide the carbon part of the seal with the carbon facing toward the ceramic as you thread it on. If the seal plate had a copper heat sink, you can either replace it or use a different size seal. (I believe it's a PS-201) Re-install the seal plate, impeller (and screw if applicable) and diffuser. You should now be ready to mate the seal plate to the wet end. Make sure you fill the pump before you try starting it up, especially with a new (dry) seal.
Aug 14, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
I had to replace my pump motor and can't get my pump to quit leaking at the joint. I am trying RTV Sealer as we speak.
Did you change the seals? Whenever pump motors are replaced, the ceramic shaft (mechanical) seal should be replaced. Its also a good idea to replace the seal plate and diffuser seals.
May 29, 2010 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
sounds like you have not unthreaded the impeller off the shaft of the motor. it unthreads counter clockwise.
Jan 23, 2009 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Tring to take the pump face off the motot
at the back there should be a 'c' clamp remove the 'c' clamp and the whole shaft should pull out.
Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump Logo
573 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
