Question about Canon PIXMA MP130 All-In-One InkJet Printer
Cannon mp130 not printing colour
I changed both the ink cartridges  both coloure and black i  went to print  a picture out and its only printing  black  it printed colour before  i might have changed have changed my printer settings im not sure could you give me some advice kind regards eric
  • elhaugen Oct 04, 2008
    I have same problem. Do you think it is my print head? I heard they are about $50.
    President:
  • 4,402 Answers
Click on print then a box will come up and select advanced options
and fine where it says print grayscale and then select the color.
Posted on Jan 09, 2008
Need to print black only but low colour cartridges cause error
Most likely you cannot. If you do not have any of the colour cartridges with ink in them, the print heads will dry out and when you want to print in colour you will not be able to print in colour.
Feb 02, 2012 | Canon Office Equipment & Supplies
Cannon S330 Printer was operating correctly, print cartridges required new. cartridges changed, will not print, after a time then would print black only, after more time colour began to print for several...
Sounds like your print head may be faulty. If you can, get it replaced. This is caused by using recycled cartidges or faulty ink cartridge.
Thanks,
Lolita
Jun 12, 2008 | Office Equipment & Supplies
Cannon MP220 displays colour ink vol unknown
For the Canon Pixma MP220, I kept getting a message saying "Col Ink Vol Unknown" after refilling and replacing a cartridge. After reading some of the other responses it appears as though Canon cartridges contain internal chips that prevent you from using them after they have been refilled. However, I tried a few things and this is what worked for me.
1. Insert your refilled Canon cartridge like normal, close the lid.
2. The Error message "Col Ink Vol Unknown" should still appear.
3. Use the "Menu" button to scroll to "Maintenance" (press "Menu" 8 times to find it), then press "OK" to conduct a "Nozzle Check" and a coloured test will print out.
4. The Error message will still appear but you will be able to print using colour AND with black and white. For some silly reason the Canon Pixma MP220 won't print using black and white if there is no coloured ink...
Hope this helps!
Feb 03, 2010 | Canon Office Equipment & Supplies
Won't print because color cartridge is empty and l don't need color
Try changing printing preferences/properties. Click on option for color, then click on box for "black ink only" or similar. Try now. If you still cannot print after changing preferences/properties, you will need to replace color ink cartridge due to manufacturer's built-in software that prevents printing when ink is low. Great for the ink companies!!!
May 18, 2009 | Cannon i70 Printer
Have changed Ink Black and Colour... Stil getting error Message.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma IP4300 - cartridge recognition preventing any printing happening.
I seem to be having a similar problem with my cannon pixma 4300 as certain others, i have just recently replaced all the inks with " original" cannon inks and all of a sudden it refuses to print anything, it says that one of the inks is not working, ( Yellow) I remove it, replace it again and the light comes on but when the slide retracts the light seems to go off. any ideas would be great, this seems to be a fault i have read a few times.
Aug 11, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
Why is there 2 black ink cartridges in my Canon MP600 printer
On some printers, probably including yours, the black ink will be taken from the reserves in your colour cartridge unless you specifically tell it to do a black and white print on each document, regardless of whether it's printing black exclusively. I wouldn't worry, the black ink in it's own cartridge can also be used for colour photos etc with no detrimental effects.
Mar 29, 2008 | Canon PIXMA MP600 all-In-One InkJet...
My canon i960 is printing only green
I had this problem. If I tried to print a black& white photo on to glossy paper, it would only print green. When I tried on to plain paper using the 'fast' option, it printed in black. The reason for this is, on plain paper it uses the black cartridge, but output to glossy photo paper using the 'high' option, uses the mix of colours in your colour cartridge. If one or more of your colours has run out, you will get a print with the ink left in the cartridge. Replace the cartridge or refill it & your problem is solved.
Dec 19, 2007 | Cannon Canon i960 Photo Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
118 people viewed this question
old marine
old marine
