Question about Jenn-Air JGS8860BDP Stainless Steel Gas Kitchen Range
Gas range igniters won't shut off
Jenn-Air jgs8860bdp igniters continuously clicking until unit is unplugged. Causes?
  • 58 Answers
The problem that you're describing is commonly associated with the spark modulator. It usually occurs after a spill or when the ignitor electrodes have remained wet after a cleaning. If after a day or two it continues to spark intermittently on its own, then the only recourse would be to replace the module. Hope this helps,,,, Bill
Posted on May 28, 2009
I have a Jenn Air cooktop that had the same problem. Initially it was an intermittent problem when burners were in use. Eventually the igniters would start clicking without anyone attempting to use the cooktop. Constant clicking....drives you nuts! I tried every solution posted on this and other forums...nothing solved the problem.
Someone suggested the POLARITY in the electric circuit might be reversed. An electrician tested the circuits...and in fact that was the cause of the problem!!!
The unit had worked for years with no issues, then suddenly it reacted to the improper wiring.
Finally....I live with a peaceful kitchen again!!
Posted on Jan 28, 2011
Oven heats up to set temperature of 500 degrees, and shuts off completely on its own. replaced electronic control, and it still does the same thing. Any suggestions??
Does it have a thermostat to regulate the temps? If it is working correctly it will turn the element on and off to maintain the set temp.
There is also some thermo couple in there to regulate the flow of gas. If that goes haywire gas does not flow properly and ........
Nov 24, 2015 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Jenn air gas kitchen range, front keypad is not working
I have the same problem. Please let me know if you have found a solution
Jan 27, 2011 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Jenn air gas/elctric slide in range self cleaning does not work
iF THEY ALREADY REPLACED THE EXHAUST FAN , MAY WANT TO REPLACE THE HI LIMIT THERMOSTAT AT REAR OF OVEN... THE THERMOSTAT MAY RESET AFTER 20 MININUTES OF COOL DOWN..
Apr 02, 2009 | Jenn-Air JGS8860BDP Stainless Steel Gas...
My electrician is here to do the electrical for my new Jenn-Air Gas stove Model # JGS8860BDP.  The store said we need both 110 and 220 outlets inside the stove space.  My electricial doesn't think...
Trust the Electrician. 99.9% of the time, the only requirement for working at a retail store is to know absolutely NOTHING of the product they sell. Where an electrician is liable for any damage to property or person injured due to his/her work... not to mention to 2 years of required training to get your journeyman lisence.
Jan 13, 2009 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Have a slide in Gas Jenn Air model JGS8860BDP, but no manual. Ho
Google your range (i.e. Jenn Air JGS8860BDP). You will be brought to Adobe Reader which will have a copy of the User Guide for your range. Doenload it to your computer, or print it directly.
Nov 11, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Ignitor would not turn off on front left burner
Same problem with the ignitors on the burners myself.  But only when i turn on the left side burners do they continually spark.  Any one know what ignition module on this?  How does it prove flame?  To ground?  Might I have a bad ground causing it to not rectify the flame?
May 16, 2008 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Jenn-Air JGS8860BDP Stainless Steel Gas Kitchen Range Logo
538 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
