The agitator doesn't seem to agitate the clothes enough
My top load Whirlpool does not seem to agitate the clothes enough to get them clean the clothes stay at the top instead of circulating. I noticed that the agitator fins are now smaller on most top load machines can I purchase a different size agitator?
  • 10,865 Answers
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Posted on May 28, 2009
    President:
  • 1,136 Answers
Hi, Do you know if the lower half of the agitator is moving? Is this a two piece agitator? With the washer off, try and turn the upper half of the agitator. It should turn one direction and stop the other direction. If it turns both direstions, the agitator dog kit will need changed inn the agitator.
Please let me know if this helps you orif I can assist you further.
Vic
Whirlpool ultimate care II agitator seems as if it is not woking properly
this is for the whirlpool washer,if you grab the top of the agitator can you spin it both ways without it grabbing,it should only spin one way,if you can spin it both ways you have bad dogs,the agitator cam kit part number is 285809 and it's around 13 dollars.pop off the center cap of the agitator,remove the 7 1/6 inch screw in the middle and pull off the top of the agitator to get at the dogs,you'll see them there are 4 of them,they waer down and the top of the agitator doesn't work.watch this video.
http://www.youtube.com/watch?v=ensJz0h6wLM
Jan 10, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
The agitatae doesn't seem to be cycling the
The agitator is made in two parts. Upper and lower. The bottom part does the actual agitating.
The upper part is supposed to be loosely fitted. It just screws down the clothes to contact
the bottom agitator slowly.
The top part turns one way, and slips the other way. By the action of what is called "Dogs" inside
the top part. These dogs are probably worn and need to be replaced
Take the top off the agitator and there is one bolt in the middle of the agitator. use a long extension
to reach the bolt and remove it.
Pull off top agitator (keep it straight up so you don't lose the dogs_
Go to local Appliance store and ask for Agitator Dogs.
Replace Dogs exactly as they came out
When you re-assemble the top it will be loose. This is normal.
Good Luck!
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top loading cloths washer agitator is loose when it should be turning. how do i tighten it?
Sounds like you might have bad agitator dogs. Remove the agitator cap, theres a 5/16th bolt that needs to be removed then the top of agitator comes off. The dogs are 4 little gears with teeth on them, when they get worn the top half of the agitator doesn't move.
May 09, 2011 | Washing Machines
My top load 4.5 cubic whirl pool cabrio washer does not seem to clean my clothes. it almost acts like there is not enough water
your agitating belt might be slipping or worn, try holding the switch down with a pencil, and keeping the lid open and see if the agitator is moving or sluggish..good luck.
Jul 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Clothes are wrapping tightly around agitator and slows it down.
is the agitator broken are they getting caught on an edge? are you using enough water? the machine is suposed to agitate even tho the lid may be open, it will not spin.use soap...
Feb 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator doesn't turn
Take the top off the agitator, pull the cover out, there should be a bolt to unscrew, after this os off take off the top and you will probably need some agitator dogs.
Jan 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Agitator slipping
change your agitator dogs in agitator
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
264 people viewed this question
Top Washing Machines Experts
