Question about ION Audio TTUSB10 Turntable
Distorted sound quality randomly
Hi.  I've been using the Ion TTUSB10 record player (plugged into my Mac), and seemingly randomly, I get a very distorted metallic sound coming out.  I usually have to turn it off and wait a few minutes, and then it goes away for a while (about 10 records worth), and then comes back again.  Any thoughts?  Thanks!
  • 104 Answers
My first thought would be the rubber drive belt, as it gets hotter it might get a little bit stretchy and then when you give it a break it gets less stretchy [make sense ] but thats only my guess as i,ve had turntables for over 25 yrs , but then that wouldnt account for the mettalic sound, that would only be if the platter was slightly warped and hitting the chassis [the main unit ]
Posted on May 28, 2009
Hi guys. do I connect the headphone out from a cassette player to the 1/8" jack on my ion turntable to record cassettes? Thanks. Joe Markovich marko74@verizon.net
If you mean the RCA jack pair, yes. Set the switch underneath the TT to LINE. That raises the cartridge output toa usable Line Level.
Go to http://audio.manualsonline.com to find the manual. Register and you will find it under ION.
Mar 02, 2010 | ION Audio TTUSB10 Turntable
ION TTSUSB10 does not record stero
I solved the problem by using www.wiki.audacityteam.org home page under the technology heading and clicking on USB turntables. The mixer had to be changed to 2 channels. (stereo)
Jan 05, 2010 | ION Audio TTUSB10 Turntable
Sound quality
Did you make the audio changes in the Windows Control panel documented in the Ez Vinyl 4.1 Setup Instructions? You must set audio format and levels to specified levels for Windows 7.
Dec 27, 2009 | ION Audio TTUSB10 Turntable
ION TTUSB10 turntable plugged into Toshiba laptop,
Maybe the output is not good enough for line in on laptop try mic in, then double click the sound icon down bottom right where time is, goto options, properties, then recording inside of recording make sure all boxes are ticked so you have all options like mic wave stereo mix line and so on, click ok, now make sure what ever you have the turn tables pluged into is selected as your recording device and not muted try again, once this is all ok ., it should work. hope this helps. also make sure your software you use to record is also set up same. take care
Dec 03, 2009 | ION Audio TTUSB10 Turntable
I have a friend who wants to convert a vinyl record to CD but wants to know how to eliminate the scratching "ssss"
This one is real easy first off make sure you use good quality cables and hook it into a decent sound card I would avoid the usb connection especially if you have a lot of other usb stuff plugged in.
Then dump the software that came with it and get a copy of "Goldwave" or some other quality software.
I use goldwave to record OLD 78 rpm records which are really bad at throwing up noise. goldwave has filters that you can apply after you have finished recording
These are superb at getting rid of hiss crackle pops and a whole heap of other stuff. Its also pretty simple to use.
I have tried other software but keep coming back to goldwave. It also has some fancy tricks up its sleeve too if you want to get creative
If you found this information useful please click
Aug 13, 2009 | ION Audio TTUSB10 Turntable
Ambient sound is louder than the music
I have a Mac (OS X 10.5.7) and had the same problem with the Ion TTUSB system picking up room noise. This seemed to fix it:
In System Preference, under Hardware, choose "Sound".
Choose "Input".
Under "Choose a device for sound input" choose USB Audio CODEC  type: USB
I hope this helps,
Cheers!
Jul 05, 2009 | ION Audio TTUSB10 Turntable
No sound
Try setting the recordsettings of ur soundcard to "record what you hear". This way it will record ALL the sounds that are produced in windows. Warning: this also means that it could record an windows systemsound as well.
Jan 01, 2009 | ION Audio TTUSB10 Turntable
Help
Hi if you click on control panel, click on hardware+sound,then click on the recording tab find it will show up as microphone USB Codec click on it, click the properties button,click on advanced tab,
in the default format make sure that " 2 channel,16-bit,44100Hz (cd quality)" is selected, the incorrect default is for 1 channel.
Hope this is of some use to you.
Regards leo21682
Dec 29, 2008 | ION Audio TTUSB10 Turntable
LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Nov 29, 2008 | ION Audio TTUSB10 Turntable
ION Audio TTUSB10 Turntable Logo
233 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
