Question about Dell Latitude D800 Notebook
Not powering up.
I have  D800 and when I plug in the adapter in to the computer the green indicator on the adapter goes out.The adpter works fine with a diffirent dell.Is this a board problem or a socket problem?
  • RatJr Mar 31, 2008
    I have what appears to be the same sort of power socket problem.
    Assuming I can get to the socket on the mb is there a way of fixing or does the socket need to be replaced.
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
Could be either but it's pretty common to have power socket or power pin problems. The pins/Sockets are poorly designed and poorly manufactured. There is a HUGE industry in just fixing the pin/socket problems on laptops. I've fixed one each on my Sony Z505 and my wifes Fujitsu. The problem is caused by the daily tugging and pulling on the cord. It puts strain on the poorly designed socket.
Once you get it fixed you might try gettinga Cable Retention Device like the one on this video. . . I did and so far no more pin problems.
Posted on Mar 04, 2008
    Sergeant:
  • 457 Answers
Sounds like a socket problem
Posted on Oct 21, 2007
Ho do I reset ac adpter inspiron 1525
What kind of problem do you have with this unit? You can't reset AC power adapters for laptops. If it doesn't charge the battery or turn the unit on, it would be one of two possible problems, usually. The adapter is bad or the plug socket is broken on the inside, either from age or getting bumped while plugged in.(most common problem). The only thing you can do in that case is to have the socket replaced. (the entire notebook has to be disassembled to replace and put back together) I'm sorry to say but, Most computer shops won't do that. Check the adapter first, is the green light on? Check with a voltmeter to verify. Hope this helps but sorry for giving bad news.
Mar 15, 2013 | Dell Inspiron 1525 Notebook
Where can I get a power adpter for a Northwestern Bell 77340 phone or I know it is a 6V DC adapter, but how many mA?
I'd be surprised if the phone draws a full amp. A 6-volt 1-amp (1000 mA) adapter should be fine. Make sure you get the polarity right on the plug.
Dec 13, 2010 | Cell Phones
We have a ASUS X83Vb laptop. The computer is no longer accepting the charge from the adapter. The adapter works fine with a green light, but once it is plugged into the computer, the light flickers or...
If you remove the battery does the Laptop power on? If the answer is yes then the adapter is fine and the battery needs replacing. They generally last for about 2-3 years and then they die. If it is under warranty then return it to the seller and they will replace the faulty components.
Thanking you
damnor01
Nov 15, 2010 | Computers & Internet
Orange battery light is doing a double blink right now... Does that mean the battery is being charged??
I had the same problem, I removed the bettery while it was still plugged in, tested it, then plugged it back and and now all is fine.
or you may try If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective - please look for a replacement. Hope it helps.
Jun 25, 2010 | Sony VAIO PCG-K35 Notebook
When the computer is turned on via the power button, the computer does not come on. When I check the LED indicators, the on/off indicator goes green, the battery power indicator is first orange, then...
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jun 30, 2009 | Computers & Internet
Green Light turns off when plugged in to the computer.
hi bro what u need to do is ... understand when u plug in the ac adapter the light on the ac adapter goes off and whne u unhoook it it comes on .. right there is a possible static charge in the mobo bcoz of which the ac current is nt able to flo on thru the wires to the motherboard .. what u can do is turn ur laptop off completely unhook the ac adpter and take off the battery as well press the power button for 15 sec press and hold it do this xcersice .. hook every thing up and try to charge the battery again it should work .....second possible thing can be may be the connectors on the mobo can be bad on the pin in the prong on the ac adpter must be twisted ,,, so check for that as well ...if still no go then either problem with the onboard power connector on mother board or the whole mother board power aseembly IE replace the mobo ....
cheers
Mar 13, 2009 | Dell Inspiron 6000 Notebook
Compaq evo n610c battery not charging
Dear All,
As per your asking that question the conclussion is there is an problem with battrey not on mother borad either problem is in Adpter connector please check out that adpter conncetor or else in the power connector in your computer iam telling you that there is an no problem in mother borad 100% suerly i tell you,
Regards
Vishwanath.K
Mar 11, 2009 | Dell Microsoft Windows XP Home Edition
My dell notebook d800 does not charge though the adapter is working and the when turned on it does not come,whether on ac or on battery
check your battery. may be it it faulty.
or check also your adpter power supply and earthing working properly.
Nov 12, 2008 | Dell Inspiron E1505 Notebook
Mains switch on
some shortage inside the computer, go for technical assistace from qualified technician
Nov 04, 2008 | Dell Latitude D600 Notebook
Compaq presario M2000 power cord won't charge my laptop
Check that your power adapter is working fine it may be that the power cable is broken somewhere between the adapter and the laptop. You could try another charger / adapter.
Jul 15, 2008 | Compaq Presario M2000 Notebook
Dell Latitude D800 Notebook Logo
153 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
