Question about Kenwood KAC-9103D Car Audio Amplifier
I have a kenwood kac 9103d
The sound is realy low i do not hane the contro could that be the problem?
  • JASON CORLEONE
    JASON CORLEONE May 11, 2010
    HI PAL SO HOW MANY SUB U ARE USING ???? TRY USING 12" SUB 1500WATTS AND 200-500WATTS RMS THATS WILL B GOOD DUDE OR CHECK LOW PASS FILTER .. TRY USING DOUBLE SUB
zzedly
  • 300 Answers
SOURCE: kenwood kac 9152D
Usually, protection mode is caused by one of these conditions:
  • Shorted speaker outputs.
  • Speaker output shorted to ground.
  • There is an internal issue, causing DC voltage to be present on the speaker outputs.
  • Amp overheats.
  • Ground connection is insufficient for amp or HU.
I'm not sure of the history or symptoms of your amp, but those are the reasons why the amp could go into protection mode.
Posted on Mar 13, 2008
  • 109 Answers
SOURCE: No sound from KAC-9103D
What kind of amp is it?
Posted on Jun 19, 2008
djmaximus_87
  • 26 Answers
SOURCE: Power lite on, no sound from amp after 1hr of usage
HI DUDE UR REMOTE WIRE FUSE IS BURNT .... REPLACE IT ... AND UR SPEAKER ... OR SUB TAKES LOT POWER FROM AMP .... ....
Posted on Jun 23, 2009
etirbynnor
  • 655 Answers
SOURCE: why does the kenwood kac-9103d has two sets of
Hello damasogrizzl,
The 2 sets of terminals are connected internally. Having 2 sets just makes it more convenient when wiring multiple subs. The amp is rated for 900 watts RMS into a 2 ohm load. The specs claim that it is stable at 1 ohm but does not give a power rating.
The Radial SD competition series from Phoenix Gold are rated to handle up to 600 watts RMS. If you have the model RSdC124 with dual 4 ohm voice coils, it would be best to wire the voice coils in parallel for a 2 ohm load and connect the sub to one set of terminals on the amp. If your sub is the model RSdC122 with dual 2 ohm voice coils, you should wire the voice coils is series for a 4 ohm load and connect the sug to one set of terminals on the amp. Wiring the voice coils in parallel will result in a 1 ohm load. And, while the amp may be stable at 1 ohm, the sub will be seriously overpowered.
Hope this helps.
Posted on Sep 23, 2009
  • 7 Answers
SOURCE: All the power and head-unit cables were installed
try checking the amps fuses
Posted on Apr 20, 2010
No sound
Sounds like the bumby road may have made ur output wires touch and short out some output transistors in ur amp. Or ur amp has bad solder connections. Either way have ur local repair technician have a look at it
Nov 16, 2012 | Kenwood KAC-9103D Car Audio Amplifier
Power keeps cutting in and out
Sounds like u have some blown output transistors possibly. Check all connections especially Ground! If no luck have ur local repair technician have a look at it.
Feb 04, 2011 | Kenwood KAC-9103D Car Audio Amplifier
My kenwood kac 9103d just crapped out on me and i am looking to buy a new amp but when i bought my sub the guy specifically wanted to know what type of amp i had to match it to the sub. so now do i have to...
More specifically, the amp must support the resistance of the sub, or subs. If your amp is 2-ohm stable, it can run a sub, or subs wired for a 2-ohm load. Also, whatever the recommended maximum wattage is for the subwoofer, try not to exceed this much, if at all, with the amplifiers wattage.
Jan 18, 2011 | Kenwood KAC-9103D Car Audio Amplifier
What size amp is the kenwood KAC-9103d amp
im not sure what you mean by what size amp....whether you mean physical size or wattage (power) so I have provided a website link for all the specifications that you require..........
http://my.kenwood.com/Car_Entertainment/Power_Amplifiers/KAC-9103D
PLease vote if you liked this response....
Aug 20, 2010 | Kenwood KAC-9103D Car Audio Amplifier
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Repairing a kenwood amp
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Dec 20, 2007 | Kenwood KAC-9103D Car Audio Amplifier
Kenwood KAC-9103D Car Audio Amplifier Logo
63 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
