Question about Ricoh Office Equipment & Supplies
Pale copies on Ricoh FT4415. Believe adjustments possible on key pad.
RicohFT4415. Copies are very pale.Contrast Key has no affect..Need codes to darken copies.
Codes won't help you. You need to replace developer, and/or drum, clean optics and then re-calibrate the density. In other words, you need a tech.
Posted on May 28, 2009
Ricoh aficio MP c3000 touch screen: displays, printer reacts to physicly pressed keys (number of copies changes on the screen etc), prints scans but does not react to touching the screen
the touch screen might be out of order, or if just when yo press something specific , as example the tray 1, an it react as you pressed something else then the touch screen need calibration. you can enter the calibration process by pressing in this right order the next buttons. first press once the yellow key then press 1993 and then press the red stop key 5 times and the lest 5th hold it for 10 seconds, after you release it press the blue number key pad 1 and then adjust the screen as it request the machine from you one order then other till the end for more info please write more info..
Oct 02, 2016 | Ricoh Office Equipment & Supplies
The HP1415 MFP make pale prints/copies.
There is no fuser oil in this machine. Using the display and menu buttons, perform a FULL calibration up to three times and test for improvement. Not sure why upgrading firmware would interfere with scanner operation...it should not, and that would be my next recommendation. Good Luck!
Nov 23, 2014 | Office Equipment & Supplies
How do I adjust contrast
Check all pix sources first, Use Menu to put brightness to mid range, then contrast to 80-100%, if pix is still bad the problem is either main board or LCD panel
Oct 19, 2014 | LG Televison & Video
My lcd backlight is very pale, how can I encence the brightness??
Reading your user manual on page 12, bullet 9 you will find the method of changing the contrast of the display. There is no brightness adjustment possible, however the contrast DRASTICALLY affects the readability of the display.
Jul 23, 2011 | Korg PA500 61KEy PROFESSIONAL ARRANGER...
Canon PC921 Replaced toner, bad copies. Is there a separate drum to be replaced?
yes that it 's the most possibillity.
but you must be assure that :
- the paper is not moist. (it makes pale copies)
- the glass has you cleaned up. (it makes black background uneven)
- the transfer unit is not dirty. (it makes black background)
May 21, 2011 | Canon PC-921 Black and White Copier
Pale copies and two vertical white streaks
I'm afraid that regarding pale copies, you are better off checking your consumables (toner, fusers, etc) and then try talking to Toshiba. However, the vertical white streaks can be caused by excess ink and other contaminants on the inside of the printer. If you open the main door to both the printer and finisher (if fitted) and look at all of the visible runners, feeders and other handling devices, try to see if any of them line up with your vertical streaks on a page. If so, try manually rolling them and cleaning them thoroughly. This might help remove some of the streaking (it did on mine).
Hope this helps, Alistair
Feb 28, 2011 | Toshiba e-Studio162D Copier
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Touch pad very pale
When you say it is pale.... Do you mean you can not read it? There is a display adjustment on the control pannel. If you have adjusted it to the max, you most likely have a blown back light Lamp.
Apr 17, 2009 | Minolta Office Equipment & Supplies
155 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
