Question about Heavy Machinery
I was given a mtd 5 hp model 243-645B000 chipper. It had been
Stored for a number of years with gas. I took the tank and carb off and the stem was clogged up. it started up but I have to run it on choke to keep it running. maybe replace the diaphragm?
  • 10,865 Answers
Because it was stored with gasoline in it, the entire carb. is likely gummed up. It needs to be removed, soaked in carb. cleaner for a few hours, and then rebuilt using the correct carb. kit.
Posted on May 28, 2009
I have a mtd chipper shredder that's been idle for years. I have new spark plug, gas & oil. Air filter is clean. Any other tips to get it fired up?
The unit could possibly have carburetor issues after being idle for so long. For a start, add maybe some solvent to the fuel to attempt varnish removal in the carb without taking it off the engine. I suggest using a dose of the Chem Tool Berryman B-12 in your fuel mix. It is pretty strong and if you are lucky, it will enable the engine to run. If not, carb removal and rebuild will probably be required.
Feb 27, 2011 | Mtd Heavy Machinery
I have a Briggs & Stratton 5HP Engine (Horizontal shaft) And it has the diaphragm carb on it. The last person to own it messed with the carb adjustments and it'll have trouble starting and idling...
2 turns out should get ya started adjust from there. If adjusting doesn't help you may need a new diaphragm. While you have diaphragm out blow through the 2 holes you'll see under diaphragm with air to hopefully avoid pulling carb off to clear screens on pick up tubes. Also check carb mounting screws through carb into tank. They frequently come loose on chippers and log splitters because of hard mount.
Oct 07, 2010 | Mtd Heavy Machinery
I Have a push lawm mower (mtd product model # 11a-439s729) serial# 1d261k81143 I have to prime before pulling the lanyard to start . I have no problem starting the engine ,the real problem is it will die...
I really need your engine number but I am going to guess that it is a 3.5 to 4 HP Briggs & Stratton with a black primer bulb on the side of the carb.
Try this the next start. Take a screw driver handle just a bit smaller than the primer bulb and FORCE it against the carb body trying to make a seal with the primer rubber against the carb body. You use your thumb if you can manage to depress the entire area of the center of the primer bulb agains the carb body. If it runs normally when you do this..... the Primer Bulb has a pin hole in it. (No joy..... read on)
If after doing the above you strill have the same problem remove the air cleaner and tighten all of the screws that mount the carb to the gas tank. Often over time the carb body will warp and then it starts getting air introduced into the diaphram that is between the cab and the gas tank. Tighten the screws. There are usually 5 of them. (Remember the body is plastic.... tight but don't break it) Then try another start.
If that does not work the diaphram between the carb and gas tank is probably damaged and will need replaced.
If you need parts info respond with your engine number or go to www.briggsandstratton.com and look it up for yourself using your ENGINE TYPE MODEL SERIES number found on the air shroud above the spark plug.
Thanks for choosing FixYa.
Kelly
Sep 29, 2010 | Mtd 22" Yard Machine Push Mower
MTD 5hp. Starting and running only while I spray
Remove the fuel line from the carb. Drain fuel tank and blow thru fuel line until clear. If you use compressed air be very careful to use LOW pressure. I just use my mouth. reinstall fuel line replace the fuel filter, add a new spark plug for good measure and refill gas tank
You should be chipping away right soon!
Mar 04, 2010 | Garden
I need a owners manual for a 10 hp chipper schreddermodel 24a464g729 serial no. 1io14g4o175 i think i may need blades
Go on line to " PartsTree.com" Start your search by clicking on MTD. Go to chipper/shredders, and fine your Model number, It's listed. In the search window- type in chipper blade. Also, on the drawing schematic of the machine, the blades are # 31 in the list of parts. I looked up the 2005 model. There are are few years with the same Model #.
Jul 14, 2009 | Mtd Products Yard Machines 158CC Tiller
How do I clean the fuel line on troy bilt 5hp chipper vac?
unscrew the nut on the bottom of the carburetor and remove the float bowl it must be emptied and cleaned , debree and water gets into the bowl and blocks of fuel flow reinstall the bowl and start, some carbs don't have a float bowl requiring you to remove the gas tank and carb which is a more involved cleaning.
Jul 14, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
MTD chipper shreader
Sounds like the carb is gummed up. Do a complete carb cleaning and see if it helps.
Jul 10, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
MTD yardman chipper wont start get spark need manual
I am successful too at using the starting fluid in the carb or directly into the clinder. That is how I start my MTD 5.5hp chipper. My problem is I have to hold down the primer bulb to keep it running. If not, the engine will stall.
May 12, 2009 | Troy Bilt Walk Behind...
Owner manaul
MTD manuals are here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
Apr 02, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
5hp b&s mtd chipper wont start
defiantly the carb but its not bad - clean / soak it with some seafoam and blow out all the holes. its just clogged and isnt getting the fuel/air mixture right.
Mar 30, 2009 | Heavy Machinery
Heavy Machinery Logo
960 people viewed this question
Top Heavy Machinery Experts
ray gallant
Tom Chichester
Bill Boyd
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
