Question about Sony Cyber-shot DSC-W55 Digital Camera
Flash broken,lens stuck i turn it on and the camera clicks and it sounds like the lens is detached from what useed to move it. its says "acess" then black screen then "Turn power off and on." i think its forever broken.. :( flash broken,lens stuck i turn it on and the camera clicks and it sounds like the lens is detached from what useed to move it. its says "acess" then black screen then "Turn power off and on." i think its forever broken.. :(
I have the same problem...so do you think that it's so expencive to repair??
Posted on Oct 26, 2012
  • 643 Answers
The gears within the lens housing are broken. flat rate if sent to sony usually is about 150 i know its almost the price you paid.
Posted on Jun 03, 2009
The view finder or screen are black. The lens moves out when the camera is powered on, I can hear the shutter click when pushed; the telephoto is moving; I have all the settings show on the screen when...
I know it may sound like the shutter is moving, but you're going to have to actually look down the lens barrel to confirm it's actually moving, and not just producing a sound effect from the camera. Also keep in mind Canon's SX IS series cameras are notorious for the following problem (fantastic cameras otherwise).
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 31, 2010 | Canon PowerShot S3 IS Digital Camera
My Casio Exilim 7.2 Megapixel camera is stuck on zoom.
ur zoom lens trrip is broken 1side dont use zoom inout strip cost 50$
Jun 18, 2009 | Casio EXILIM Digital Camera
Lens Stuck open on Mz67 hp camera Error code Mz60-022
Was this stuck fully open or was the lens partially opened, or was the lens jammed?
The lens can be removed and replaced with another lens from another non-functioning camera (See ebay). The lens component can also be dissembled. Putting the lens back together is tricky because the parts have to be aligned just right for the lens to work. If working with a Jammed lens, extra care has to be considered not to break any of the moving plastic parts of the lens or that part (if not entire lens) is junk.
With the motor detached from the lens, the lens should extend and retract freely. Use this to test the lens when you dissemble the camera. Be careful of the flash board.
Mar 15, 2009 | HP Photosmart MZ67 Digital Camera
Lens stuck, green Power light flashes, nothing happens.
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time  you will hear a clicking noise which is normal  once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
x
Dec 08, 2008 | Samsung Digimax S500 Digital Camera
Hp photosmart 945 lens is stuck
Looks like the large lens cannot get it's lense out with the electric drive. This is operated by a little motor with gears. The clicking sound is from gear-teeth. Your guide shaft (3 of them) may be blocked by sand or dust or broken guide-pins.
Once the large lens is fully out. The small internal lens will be moved in and out for zoom. I have recently fully dissassembled my broken HP945 which was fallen on its lens in extracted mode (under charge from docking station). If you want pictures how it looks inside, let me know. rene_bdm@solcon.nl
Jun 04, 2008 | HP Photosmart 945 Digital Camera
The camera zoom got jammed
This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 at my shop. Broken drive gears are generally This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 labor at my shop.
Jun 14, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Lenc cover will not open
Jun 12, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera lens
Apr 29, 2007 | Canon PowerShot A510 Digital Camera
Canon Ixus 40
Apr 27, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
My Camera has E18 Problem
May 07, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Sony Cyber-shot  DSC-W55 Digital Camera Logo
418 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
