NO PICTURE. HAS SOUND. REPLACED BURNT FUSE F904. NO CHANGE.
Hitachi ct5081k, no picture, has sound. just replaced burned fuse f904, 125v,1.5a made no change
3 Suggested Answers
SOURCE: tv has sound but no picture
repalced two fuse 125v 1.5amp and picture came on works fine. But I would like to order a remote if you have in stock. Thand you for your reply.
Posted on Jun 02, 2008
SD Tech
  • 14553 Answers
SOURCE: colors are seperated on toshiba 50A61
Go into menu and with original remote call up convergence--either it has a problem(will not adjust) or you may with the remote be able to manually adjust the convergence back: sometimes if a power outage/surge it scrambles the convergence memory.
Posted on Aug 29, 2012
Installed new lamp on my hitachi60v715 no picture or sound
Possible power supply or Lamp Ballast that has instantly blown a fuse.
If no power or lights etc someone has to open and test voltages etc.
If beyond you---have set taken to a shop---a house call is usually a waste of time and money in this situation.
May 17, 2012 | Hitachi 60V710 60" Rear Projection HDTV
My Hitachi 60VG825 is not showing a picture. The lamp has been replaced and there is still no picture, The sound is fine. I was told that the transformer may need to be replaced. Any suggestions as to...
I would say to check the video fuse however if your not replacing the board it isnt an expensive repair cost for labor and part and four years of a good amount of use is appropriate surges could have also lead to the damage
Robb
Sep 28, 2010 | Hitachi 60VG825 60 in. LCD Television
I have a 1988 Hitachi Model CT5081K; Serial W8J000983. The problem is the TV can be turned-on via remote control but no PICTURE or SOUND.\r\nAre the fuses and/or bulbs need to be replaced?
I had a TV like that and it did the same thing. There are three Rear Projection lights in the back..once they are done so is the rest of the TV. I had a tech look at mine and they don't fix them anymore. Sorry.
Aug 28, 2010 | Hitachi Televison & Video
I have sound but no picture
Always unplug the TV before you start....:)
On the Sanyo DP19648 has sound and NO picture.Take the TV apart locate the power supply board on left.Remove the plugs for the lights etc.take out the screws carefully unclip the power supply.Turn it over find the F1 tiny chip fuse locaed off center to the left with metal sheild away from you.I used a 2 amp (bc fuse unknown)I broke an agc style standard fuse and used the wire that was inside the fuse and also replaced the slightly bulged 220uf at 25volt cap which is located top side not far from burnt fuse.I suspect the fuse blew bc of the small orange bulged cap.
From Ed the tech....good luck
Jun 22, 2010 | Sanyo DP19648 19 in. LCD TV
57F500A, powered light on with no sound/picture, ticking noise
Over the years of servicing these sets and others for Convergence issues, I have on several times gotten defective Convergence ICs. In your case where a Resistor is now open, (Probably a 1.5 ohm 1/2 watt), I would suspect you had gotten a hold of a defective IC. I would replace them both again. Make sure to use Heat Sink Compound between the ICs and Heat Sink.(Just a thin coating on the metal area) You can get the heat sink compound from Radio Shack. They should also have the Resistor you need.
Good luck,
Skyassoc
Jul 23, 2009 | Hitachi 57F500 57" Rear Projection...
Flat tv, sound but no picture. have tried
I had one that had a black screen and fixed the problem by repairing the inverter. When I opened the unit I looked at the capacitors on the inverter board and found them swollen. I looked at the bottom of the board and found that the fuse had opened up. The caps were a cheap quality low temp variety 150uF at 25V I replaced them with 330uF 25 volt 105C caps. I then replaced the 2.5A surface mount fuse with an axial 2.5A pico fuse and the TV worked beautifully.
Jun 12, 2009 | Philips 15PF5120 15 in. LCD Television
Tv has sound but no picture
May 31, 2008 | Hitachi 50UX57B 50" Rear Projection...
No power no picture no sound
You have a shorted power component. Probably either the voltage regulator or the Horiz. output transistor. Both will be mounted to a heat siink of some type. The Horiz. power circuits along with the flyback transformer power up 90% of most TV sets.
Geno
Feb 16, 2008 | Televison & Video
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
