Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Screen looks 3d and schrunk
My RCA projection HDTV looks like it is in 3D and it is skinner in the middle than on the sides.
    Genius:
  • 1,030 Answers
This is an indication of convergence failure. on these model the first suggestion or more like question is this do you have the convergence option in the customer setup menu? If you dont i suggest you read the fl231 problem in the tips and tricks section of this website. If you do and you still have the bow tie three d effect then the next solution is to replace what is known as convergence power supply. note when you start replaceing the boards that effect convergence it may need adjusting that a technician needs to do
Posted on May 28, 2009
Screen looks 3d
Here a answer given by a pretty good expert on this site that applies to your set:
http://www.fixya.com/support/r5119668-fix_convergence_problems_rca_chassis
These are not a set I like to work on but there is a ton of info in that answer
Apr 03, 2012 | RCA HD52W59 HDTV Projection Television
My rca hdtv has a 3d look, and it is blurry, what can i do
this 3d look is coused by bad convergance ics you have to replace them no adustment will fix this
Dec 24, 2007 | RCA HD52W59 HDTV Projection Television
52 rca bottom left corner words are blurry but fine every where else when you play a video game It almost looks 3d to
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 04, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv is showing 3d colors
Go to menu then setup if you do not see convergence you have a blowed fuse FL231 on bottom board to the left side this is your deflection board on right side of your (FBT) flyback Transfomer are 3 Fuses in aroll they look like small brown tirangler caps but are Fuses it will be the one in the middle Call Partstore.com !-866-925-7278 or look it up online.
Nov 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My Sony Projection TV middle of the screen curves down on top and curves up on bottom. Picture looks dubble like 3D, screen looks like concaved. Left side of the screen color is light green and blue, right...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
Sep 26, 2009 | Sony KP-51WS510 51" Rear Projection...
Looks 3d
Sounds like your Convergence needs to be adjusted. Go to your Setup Menu and look for Convergence. Choose that and the TV will automatically run it's Convergence program If that doesn't fix the issue then you may have to get the unit serviced
Sep 15, 2009 | RCA HD52W59 HDTV Projection Television
3D looking pic. on my RCA-P52813BL
The prob.is ur covergence.Go to menu setup look for convergence,see no convergence.U have an open Fuse(FL231)lacated right side of the Flyback Transformer.There are 3 in a roll small brown rectangle looking caps,but they are fuses.The one in the middle is dead.
Sep 02, 2009 | RCA P52812BL 52" Rear Projection...
Rca 7302rd5 56"hdtv tv looks like a 3d moive
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jul 03, 2009 | RCA R52WM24 52" HDTV Projection Television
Picture almost looks like it is in 3D on RCA 52" rear projection
there are 3 brown fuses by the flyback the 1 in the middle is bad
Jun 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen looks like its in 3d
LOOK FOR OPEN FUSE (CTM) BY IHVT, THE MIDDLE ONE.
Feb 20, 2009 | RCA P52937 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
121 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
