Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Engine won't start . Pour gas in cylinder it starts then quits.
I have a Silver Series 4.5 HP Lawn Boy. Model # 10301 2 stroke. If I pour gas in the cylinder it starts, runs for a few seconds and then quits. If I do get it running, I have to tilt it sideways to keep it running. If I set it down too fast it stalls. It will continue to start while I am there but after it sets awhile it won't start. Thank you, Lou
  • bootsreg May 29, 2009
    So far its starts on one to three pulls.But getting the choke adjusted is tricky.
  • 10,865 Answers
Hi lou. your carbeurator is gummed up. It will need to be removed, soaked in carb cleaner for three hours and then rebuilt using the correct kit.
if you are not familiar with how to do this i recommend that u have it done by a lawn mower pro
Posted on May 28, 2009
  • Joe Hogan May 30, 2009
    I would use a carbeurator cleaner which you add to your gas, like seafoam, available at most auto parts stores. one ounce per gallon. This will clean your carb and keep it clean.
    if this doesn't improve soon though, I would recommend that a new carbeurator kit be installed for your carb.
22hp.zero turn sometimes smokes then stops.
The smoke could be caused by blowby around the piston rings. Pour a small amount of transmission fluid in the spark plug hole and turn the engine over several times. Check the plug for fouling. Also check the coil wire for spark.
Apr 15, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Brand new Briggs & Stratton lawn mower Model 90000 E series won't start.
trry a shot of starting fliud see if it wont start then make sure your getting a spark to
Jun 13, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Won at my kids kempo class gio ya49 model what do i need to do to start it not sure if straight gas or mix also do i add oil anywhere thanx
You are going to need more information before you start this up.
You need to know whether it is 2-stroke or 4-stroke.
You need to know the manufacturer, I see some use 25 parts gasoline to 1 part 2-stroke oil. Other machines use a different proportion.
If it is this manufacturer, mix say 25 ounces of gas with 1 ounce of 2-stroke oil in a separate container and pour into gas tank.
If it is 4-stroke, you will need oil in the crankcase, not in the fuel tank.
Try to find the name of the bike/quad somewhere.
Dec 21, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
After about 15 to 30 minutes, engine starts pinging (for a few seconds) then dies
Not familiar with tecumseh lawn boy. Lawn boys I worked on were 2 stroke, if this is the case the crank seal is sucking air after engine warms up. New seal would fix. If you can't do it you're self may not be economically worth it.
Sep 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
I have MTD Yard machine and don't know if it is 2 or 4 cycle. Oil should be-SAE30. Can I use oil for 4-cycle which they soid me i Can. Tire.(M otomaster)
If your mower has seperate fill caps for the oil and the gasoline, then you have a 4 cycle or 4 stroke engine. In this case use SAE HD30 motor oil. If there is only 1 fill cap and it says oil & fuel mix, then you have a 2 cycle or 2 stroke engine.
Good luck
Sep 10, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn Boy mower will not start. New gas and plug.
Is the plug getting wet? if not, try introducing fuel to the intake and attempt to start it again, the interlock on the handle works by killing the ignition fire and applying a brake to the flywheel, this should be a Tecumseh engine, carb troubles are quite prevalent on these, by substituting fuel to the intake you are acting as the fuel supply, if it starts and runs briefly you have confirmed a fuel system issue
Jun 01, 2010 | Garden
Engine will not start, no spark
Try taking of the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs that are really close to the fly wheel. Use fine sand paper or emery cloth. Then check the spark plug wire for rust (clean if any). Try replacing the spark plug if it is old.
Let me know if this helps.
roundo4
Aug 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
No spark
After seeing what you and other ASK type web sites charged to answer my question, i called the dealer he answered the question for me. i ordered the part online and repaired it myself.
My advise before you pay anyone to answer your question try calling a local repair center, i found they were willing to answer my questions without a CHARGE
May 18, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
1,225 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
