Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi WD-62527. Dark picture.
Purchased Jan 2005. Lamp replaced once. Dark picture. During night time scenes I can hardly see anything. Have bright turned all the way up. Hooked to satellite system. Problem started after move in April. Formerly on cable system. Thanks.
  • 126 Answers
That unit is a two mirror set. Meaning the light engine lens shines down onto a small mirror and that is reflected onto a large mirror and then onto the screen. Gravity being what it is dust and other contaminants cover the lower mirror. Moving the set would only aggrevate dust settling on it. To fix the problem the screen must be removed and the mirror cleaned. You won't believe the difference. It will be like watching a new tv.
Posted on May 28, 2009
Mitsubishi wd 62527
Possibly the color wheel which is not available, you have to go with the optical engine which is part#: 938P015020
This would make repairs UNECONOMICAL
OR any one of 5 fans:
Chassis fan & Lamp fan: 299P288010 $20.00
http://www.shopjimmy.com/catalogsearch/result/?q=299P288010
PBS fan: 299P296010
Ballast fan: 299P287010 $25.00
http://www.shopjimmy.com/catalogsearch/result/?q=+299P287010
L/V fan: 299P295010 $27.00
http://www.shopjimmy.com/catalogsearch/result/?q=299P295010++
May 06, 2014 | Televison & Video
Mitsubishi wd 62527
hello there it could be a loose connector that u may have disturbed or broken look again inside if it worked before with
sound the chances are its ok
Jan 21, 2018 | Televison & Video
Picture on my mitsubishi wd 60737 is dark. i have increased the brightness but picture looks like a night time scene
A few things occur to me, if Lamp not recently replaced (2year average life) it may be nearing the end of its life.
Just a few models (not sure if this is one) use two mirrors where most just have one large mirror.
If the issue was gradual you may have the two mirror set, one tiny mirror at bottom of screen area points up and reflects the image into the large mirror in the back of the set which puts it on the screen to view.
If your model has the two mirrors the little one will be coated with dust and such and cuts brightness up to 70%
You can call Mitsubishi and ask if your model has two mirrors or one, if Two mirrors and they will not tell you how to get at them I can.
Let me know if you need more help.
Dec 12, 2012 | Mitsubishi WD-60737 60 in. HDTV
I have a mitsubishi 60 inch tv model wd-60c9 and i purchased it this year ..aug 06 2010 and the picture has became very dark..i am using hdmi conection and purchased new and better cables..issue still dark
The tv projection lamp have problems,it shorting out some how.That why,u have a dim picture.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp for the replacement.New tv,call mitsubishi for a warrenty repair.
Oct 18, 2010 | Mitsubishi WD-60C9 60" DLP HDTV
Flashing green light on Mitsubishi WD- 62527 TV
how time dose the light blinking was your pix
dark if so you need a lamp@powersupply for lamp. hope this help you out,
Aug 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Green Blinking Light WD-52525
Is it possible your having poor air movement around the set. If lamp is frequently blowing it sounds like over heating. Sorry your having troubles. That tv offers a fine picture.
Jul 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Random, intermittant blue lines
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 10, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
769 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
