Question about Kenmore 62702 Microwave Oven
Kenmore microwave hood combo 721.80039 works but it will not cook
All functions seem to be working as normal
  • 4 Answers
SOURCE: Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Posted on Nov 23, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: KENMORE MICROWAVE (HOUSEHOLD) LOCKED
It sounds like you press STOP two or three times to lock it. Maybe that (or another key) will unlock it.
The lock / unlock procedure will be covered in your owner's manual.
Or you can try a hard reset - unplug it from the wall for one minute, then plug it back in and try again.
If you don't have your manual, you can get one here. (Enter your model number without any spaces)
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 01, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Kenmore Galaxy Microwave Hood Combo Model 72180002400
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Posted on Aug 02, 2008
SOURCE: kenmore microwave model 721-63252301 - no heat
we are going to try to find a fuse and replace that or just buy a new microwave
thank you
Posted on Jun 06, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: I have a Kenmore Microwave hood combo model number
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Posted on May 16, 2010
I have a Maytag microwave, model# MMV5165BA and it has no heat.Everything displays and vent works but no heat.Can you suggest anything before I toss it out?
If it operates as normal but items don't seem to get hot it probably is a Magnatron failure (microwave producer). More times than not the repair / replacement of a Magnatron these days is not worth the investment, especially if the microwave is 4 years old or older ! You should be able to replace your microwave with a similar featured microwave / hood for about $300 to $400. You might try a JVM1750DMWW by GE great micro/hood for about $300, includes one touch sensor cook capabilities,300 CFM vent fan,removable rack,option to turn the turntable on or off, 1000 watts of cooking power. Good luck !
Nov 28, 2009 | Maytag MMV5165 Microwave Oven
Microwave door shut, but interior light is on - micro won't work
Yes. One of your door switches is not working. It could be an alignment issue or a faulty switch. There are actually 3 switches in the door latch area.
Eric
Sep 06, 2009 | Kenmore Microwave Ovens
Kenmore Ultra Wave Microwave has no power
after removing the cover of microwave chk for continuty of cavity thermostat usually calld TCO(thermal cut off). it is located on top of the cavity and circular in shape.usually neutral wire goes through this 2 control board and this TCO is for protection of cavity from overheating.if this tco is open.then replace it.usually this happens when u cook for 2 long.
Aug 15, 2009 | Goldstar MV-1515 Microwave Oven
Does stove-top need downdraft if microwave has oven-hood combo?
We have a stove with no downdraft, and a microwave with a hood above it. It works just fine. I expect you could keep your downdraft and put a microwave without a hood above it, and that would also work. I don't think, however, you can buy an above the range mocrowave oven, that slides in on brackets, which will not have a hood.
Jan 08, 2009 | Microwave Ovens
Kemore Microwave Hood Combination
I HAVE KENMORE 665/61629 LIGHT STAYS ON. AND DO NOT COOKS. AND THE FAN DOES NOT WORK.
Jan 05, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Jul 29, 2008 | Kenmore 62622 Microwave Oven
Vibrating noise when cooking
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
Dec 07, 2007 | Kenmore 62642 / 62644 / 62649 Microwave...
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Kenmore 62702 Microwave Oven Logo
114 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
