Question about Lexmark X2580 Wireless All-in-One InkJet Printer
Ink cartridges make a slamming sound from left to right and wont print
Lexmark X2500 series printer will not work. The power will not turn off, and when it is on, the ink cartridges travel to the left and then rapidly back to the right, making a slamming noise.
  • Lexmark Expert
  • 228 Answers
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
Posted on May 28, 2009
Encoder strip was pulled out of lexmark 2500 how do i reinstall it?
This article from the Lexmark website might give you an idea on how to re-seat the encoder strip back to its position: Printer Cartridge Stalls or Is Blocked
Mar 29, 2012 | Lexmark X2500 All-In-One Printer
Replaced the ink cartridge and it is not printing
Try to check your ink levels. On your computer, go to Start menu > Programs > Lexmark 2500 Series folder > Lexmark Solution Center. If ink levels are substantial for printing, go to the Maintenance tab and select Clean to fix horizontal streaks. It could be due to clogs and dirt in the cartridge nozzles caused by long periods of non-usage.
If the light continues to flash for both cartridges, try to replace both cartridges with different known working cartridges or better yet, replace them with new genuine Lexmark supplies.
Dec 05, 2011 | Lexmark X2500 All-In-One Printer
Will not load paper,when it does it prints for ****.how do you check ink cartriges
Try to remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. Close the printer cover. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, reinsert the cartridges. Load some paper and try to print again.
To check the ink levels using your computer, Click Start menu > Programs or All Programs > Lexmark 2500 Series > select Lexmark Solution Center. In the main dialog screen, the ink levels are displayed.
May 08, 2011 | Lexmark X2500 All-In-One Printer
I recently replaced my ink cartridges for my Lexmark X2500 with brand new ones, Lexmark brand, I inserted them and followed instructions and now it still tells me that it can not print that I need new...
  • Open up the "Printer Solution Center." If there is no icon on your desktop for your Lexmark printer, click on the "Start" menu button, which is located at the bottom left-hand corner of the screen. Click on "All Programs," and then look for "Lexmark." Select the "Printer Solution Center.
    Choose "Install a new printer cartridge" under the "Maintenance" tab.
  • Click on "Next" until you see the "Print the Alignment page" option, then choose "Print."
  • Repeat steps 1,2 and 3 if the ink level gauge still isn't showing sufficient ink.
  • Apr 13, 2011 | Lexmark X2500 All-In-One Printer
    Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    Where do you insert the ink cartridges on lexmark x4650
    These are the instructions for X2500 Printer
    1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
    2.Open the top portion of the printer to reveal the ink cartridges.
    3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
    4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
    6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
    7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
    8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
    Oct 25, 2009 | Lexmark X2500 All-In-One Printer
    Print spooler doesnt work wont print, on windows vista, lexmark x4530 printer
    # Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
    # Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
    # Continue doing this until it looks clean.
    # Then dab the cartridge on the towel to make sure the ink is flowing.
    # Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
    1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
    2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
    # Reinstall the cartridges, making sure you snap them correctly into the printer.
    Hope this help. Please Rate My Response! Thanks!
    PREM
    May 26, 2009 | Lexmark X2500 All-In-One Printer
    Lexmark x2500
    To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
    Nov 04, 2008 | Lexmark X2500 All-In-One Printer
    Lexmark X2580 Wireless All-in-One InkJet Printer Logo
    422 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
