Question about Kenmore 43042 Front Load Washer
Kenmore Washer/Dryer Stack -- Need to replace Washer
I have a 9 year old Kenmore Washer and Dryer stack (dryer on top; washer on bottom). The model numbers are 417-800-42990 (dryer) and 417-400-42990 (washer). The washer broke and I need to replace it. I went to Sears and they have TWICE sold me a washer that, upon delivery, the delivery folks refuse to install because they say it's the wrong kind. Help! Does anyone know what kind of washer a Kenmore 417 dryer can be stacked on top of?
It's hard to tell how they are connected, but apparently the top of the washer is removed and the dryer is bolted on top of it.
  • lisaheline May 28, 2009
    Thank you! I just purchased on-line a Kenmore #40412 that looks EXACTLY like my current (broken) model. It also has a removable top that can be clipped in the back and screwed in the front to the stacked dryer. Keeping my fingers crossed that all goes well on delivery day.
    Thanks again -- glad to have my faith restored in at least some Sears Technicians.
  • Anonymous Mar 20, 2014
    Can I Stack a Kenmore Dryer Model 417 on to a Kenmore Washer 41182
  • 89 Answers
First of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
  • slypp187 May 28, 2009
    no problem, and good luck
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool dryer model # WED9270XW1? If yes, what stacking kit do I need to use?
You can stack just about any dryer on any washer, so long that the controls of the washer are on the the top of the washer has no penetrations and no control.In general, dryers are independent from the washer and are light weight.
So the conclusion: so long that the dryer does not interfere with operating the washer - YOU ARE A OK :-)
Oct 14, 2014 | Whirlpool 8541503 Duet Stack Kit 8541503
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool washer model # WED9270XW1? If yes, what stacking kit do I need to use? Can I stack a new whirlpool washer model # WFW72HED
As we could see new one are not compatible with older one as size and dimension of new washer are changed but in case you could try .It is simple just try compatibility of your older washer stack kit with new one in most new model
Remove front panel on kenmore washer dryer stack model110.26182
Model# 110.88752799 Kenmore stacker washer/dryer
Q; How do I remove the front control panel? (to remove the timer dial, to replace a switch, etc)
A: reference diagram- http://www.searspartsdirect.com/partsdirect/partsdirect/printSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK1105180-00001.png
-remove four crews (#8 on diagram) from left and right sides.
-remove one screw (at #21 on diagram) from the bottom of the panel.
-remove #7 panel from the left and right side
- this will expose a thin metal catch (#9) on each side. With a small finger or screw driver, push down on the top of this metal strip where it bends horizontally. This will compress the spring (#14) and release the catch.
- the control panel will fold down now.
Jun 01, 2012 | Kenmore 98702 Stacked Washer/Dryer
I want to try to put my washer (Frigidaire FTF model) on top/bottom of my dryer (also frigidaire). However, we didnt receive any brackets which are standard for stacking, so we are curious to how to stack...
Hello the advice about removing the top of the washer and bolting the dryer to it is exactly what to do.Under the washer top is built in brackets to do that.Every front load Frigidiare washer leave the factory pre-equipped to stack the dryer to it by removing the top and bolting the dryer to it
Aug 21, 2011 | Frigidaire FTF530FS Front Load Washer
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Oct 27, 2009 | Kenmore Washing Machines
I have a Kenmore washer model no.4174102000 that has broken and was advised it cannot be fixed. I have a Kenmore stackable dryer model no.41781042000 and am being told by Sears that I have to buy a new...
a stack unit is a very risky investment, altho it's understandable if you have limited space. if the hold downs on the washer are rusted out or broken thru you need to have someone weld them for you. That's how we used to do it where I worked but stacks are not usually easily worked on. I'm afraid you will probably have to get an entirely new unit or maybe a used one from a reputable used appl. dealer in your area. Check around, you might get lucky and find one relatively inexpensive
Aug 24, 2009 | Kenmore Washing Machines
The tub is leaking in the botto center
had the same problem...the washers that hold the water in need to be replaced...only $20 for parts, but labor is $700 to take entire thing apart and is not covered after 1 year [I've had 9 yrs]; I opted to trash / replace entire stack unit; buy new amana washer & dryers @ home depot b4 7/29/09 / big sale!
Jul 14, 2009 | Maytag LSE7806A Top Load Stacked...
Removal of front panel of a stack washer and dryer mod
Their are screws between the washer and dryer. Undo those and the screws inside the dryer, next too and below the lint trap.
Jan 17, 2009 | Maytag LSE7806A Top Load Stacked...
Kenmore 43042 Front Load Washer Logo
1,384 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
