Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
FWT445GES1 Washer makes loud banging noises like it's going to explode.
My Frigidaire model FWT445GES1, was making noses like the drum was coming off. it nocking and is loss when you grab it. How do I fix this? thanks My Frigidaire Gallery FWT445GES1 Washer is not working properly. It makes a really loud knocking sound as if the belt is broken or something. I think my dryer Frigidaire Gallery 417.59012890 also needs to be serviced. Zippers and sweatshirt strings constantly get stuck in the drum as it spins and I've even had beautiful shirts get completely destroyed in the dryer by getting stuck between the spinning drum and the stationery part of the machine. The most important issue is my washer. I haven't been able to use it in over a month. Any help? Local to Worcester, MA
  • 89 Answers
Washer- you need a complete tub and bearring kit. this is a common problem for people who have well water. (also just happens) the rear yoke has become corroded and broken. its a costly repair.
dryer - you would need a new front slider seal. very simple to install.
Posted on May 28, 2009
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
The drum is moving front to back and making terrible noise
The retaining nut/bolt for the drum has come loose. Remove the back cover and check the drum axle and attachments.
Jan 21, 2011 | Frigidaire ATF6000ES Front Load Washer
My frigidaire gltr1670a washer is making a banging noise when on the spin cycle. I took the bottom cover off and watched the drum it doesn't seem to be from the outside of the drum cover it sounds like its...
It sounds like the spider arm supports in your washer has failed. The spider arms hold the stainless steel wash drum to the axle. You need to stop using the machine immediately since the wash drum is flopping around the plastic tub. It is an expensive fix. The replacement drum/spider can cost over $300 with shipping. Get a few estimates before deciding whether to repair or replace. Sorry.
Dec 09, 2010 | Frigidaire GLTR1670A Front Load Washer
My Frigidaire frontloader is not spinning until dry. The drum appears to be banging against the interior, making a loud noise.
were the drum support brackets removed after purchase? you may need to open the front access panel and remove two brackets that support the drum during shipping. also at the rear are support screws that need to be removed
May 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer frigidaire GLTF1670A
you need a new drum, wich is pretty much like buying a new machine
Jun 18, 2009 | Washing Machines
LOUD BANGING AND SCRATCHING NOISE ON SPIN CYCLE
Urgent stop using it !!!!
The drum suspension is coming to bits , get someone in to look at it before the drum comes through the side of the machine
Jun 16, 2009 | Frigidaire GLTF1670A Front Load Washer
Loud banging noise during final high speed spin
I have the HE3T which is 6 yo. Last week it started making a loud banging noise in the spin cycle. I had a repairman come out. He said it is the drum bearings. He said that it is a problem with these machines and to call Sears. He said that the drum and bearing is one assembly and that Sears should cover it.
I called today and Sears todl me that I have to pay for a Sears technician to come out a determine if it is indeed the problem. If so, it will be covered under the lifetime warranty on the drum. I have to pay for the service call $75.00 and if it is the problem, I will be reimbursed. Cross my fingers!
May 21, 2009 | Frigidaire ATF6000ES Front Load Washer
I had the same problem (9 year old washer). It was a broken support spider for the drum. It had corroded nearly through, so it was ready to break. Had to buy an assembly that included the drum. Cost about $265. The tub assembly has to be removed and split to remove the drum assembly. I found out that the door boot has to be reinstalled with the tub assembly out and the counterweights in the front removed. My door boot was glued to the front panel. Had to cut it loose with a razor blade. If the problem should be the bearings, the repair procedure will be the same.
Apr 28, 2009 | Frigidaire GLTF1670A Front Load Washer
A loud bang .....like a hammer was thrown in there.
ouch!! can you "lift up " on t he inner drum with a movement of 1 inch or more??? if so sounds as if you needa rear bearing assy. dont know how old machine is, but genearlly if parts not covered its not a worth while repair. will run hundreds of dollars
Feb 14, 2009 | Frigidaire Washing Machines
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
1,652 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
