Question about kawasaki Full Suspension Mountain Bike Men
Kawasaki bayou 1992, i changed the starter it turns but does not engage, the chain turns the gear moves but moter turns doesnt turn over.. what am i overlooking, ive tried what i know and nothing works..
    Champion:
  • 225 Answers
Sheared pin on gears(if the gear turns but not the shaft)
Posted on Jun 13, 2009
Kawasaki starter not engaging
Hi, Ricky the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starter spins but engine does not crank
Starter spins but doesn start the bike Ex 500 com The home of the Kawasaki...
Starter spins but doesn turn the engine
Mar 22, 2017 | kawasaki Motorcycles
Kawasaki bayou 300 starter spins but wont engage all the time
The larger idler gear ring was spinning but not spinning the entire gear. I couldn't figure ... Starter Idle Gear Limiter Kawasaki Bayou 220 250 39076 1060 ' eBay ... kawasaki bayou 300 starter will not engage.
Mar 21, 2017 | kawasaki Motorcycles
86 kawasaki 300 bayou, turn the key on, hit start button and there is nothing. i did find a wire terminal on the regulator / rectifier Fixed it and still nothing. what component should i look at..?
Hi, Lee and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and downloads that you will need please visit the websites below. Good luck and have nice a day.
kawasaki bayou wont start
ATV Connection
DOWNLOAD 1986 Kawasaki 300 Bayou
http://www.bikebandit.com/aftermarket-parts
Owner Center
Jan 27, 2016 | kawasaki Motorcycles
Kawaski bayou 300 stater wont engage engine all the time why
Hi, Gary you may have a starter solenoid or starter drive going south for more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
bayou 300 starting problem Kawasaki ATV Forum
1986 Kawasaki Bayou 300 Starting Issues
Kawasaki Bayou not starting
Owner Manuals Service Manuals Kawasaki Vehicles
Jan 25, 2016 | Motorcycles
My Kawasaki 1983 550 GT got new starter brushes now it spins without engaging, but it did before, WHY?
You can remove the gas tank, then pull flywheel cover, you will see the starter bendix, with your fingers turn it back and forth you will see how it pushes out when turned. chances are it went bad. if you have an air impact wrench the flywheel bolt is easy to remove,
Nov 09, 2015 | kawasaki Motorcycles
Starter motor solenoid wont engage
There is condenser shaped part attched to the starter moter this is the part which makes the starter moter to spin and when it is stuck the moter does not spin you can check it by one person sitting in the car holding the key to start position and another one hit it softly with some spanner or something The starter moter will move there is a small gear in it which requires replace ment Or the other possible reason can be the carbon brushes in the starter moter are worn out or the place where these brushes touch on armature the place is worn out that Y ou will only come to know when you will take the moter away from the engine Lastly I hope you might have checked your battery that it is giving sufficient current to the moter
Aug 16, 2012 | 2003 Volkswagen Jetta TDI
My 92 saab 9000 wont start. it makes a spinning sound sort of like a hairdryer. the battery is fine and i get the oil changed every 3000 miles and all the other fluids regularly checked. so what could it...
Either the timing belt/chain/gears has failed, which can really change the sound of cranking, but the engine visibly goes around.
If the engine does not turn (as it sounds is the case with your car), but the starter spins fast enough to be described as sounding like a hairdryer, then the starter drive is bad and the starter will need to be replaced or rebuilt.
The starter drive is turned by the starter motor, and the drive in turn turns the gear that engages the flywheel of the engine. The part that turns that gear will not let the starter motor be pushed by the engine — it has a one-way, overrunning clutch in it. If the engine got a chance to spin the starter, the starer would simply explode. It is maybe 10 or 15 to one between the engine. One good start using the gas pedal would spin the starter like 15 to 25 thousand RPM...
If that overrunning clutch fails the starter motor cannot spin the gear that turns the engine.
Jun 27, 2010 | 1992 Saab 9000
kawasaki Full Suspension Mountain Bike Men Logo
336 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Phillip Edwin
Level 1 Expert
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
