Question about General Electric Profile Smartwater Ultra Plus Reverse Osmosis Membrane
GE smartwater R.O. system leaking out weep hole
GE SmartWater RO system (GXRM10GBL)- not quite 5 years old. Water begins to leak out the weep hole after turning the handle ... then won't stop leaking even with the handle turned off. Water source must be turned off to stop leak from weep hole. Waiting a day or two before turning the water source back on will cure the problem ... at least for a little while. Basically, I'm turning the water source on and off all the time, lately. What's the deal? Is the membrane used up and needing replaced? Thanks, CJ
Same exact problem started for us last night. (Same model, installed by me about four+ years ago) Water was really coming out of the weep hole, and didn't stop until I shut it off at the valve. This happened once before, and all I had to do was clean the drain line adapter, because it gets full of gunk from the disposal over time. But this time that did not do the trick. (Plus there was not all that much gunk this time....) So I was baffled for awhile but came up with this solution.
I hooked up a small length of clear tubing to my cheap-o tire inflater/air compressor. Put the clear tube against the weep hole. Turned on the compressor, and VOILA!, a bunch of gunk that was clogging the drain tube came out. I think when this tube, or the drain line adapter gets clogged, it causes water to go out the weep hole instead of down the drain. (If you don't have a small compressor, then theoretically there is enough air pressure from something like a bicycle pump, and this solution *might* work with one of those. But if you try this, of course only use the DOWNWARD (air-going-outward) pump action...pulling up (inward) would force the clog deeper up the drain tube)
Posted on Oct 02, 2009
Not enough hot water ge smartwater water heater gas
1) Copy following links:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Low temperature setting, extremely cold incoming water, Water leak or broken pipe running hot out of tank, crossover caused by bad faucet cartridge or bad recircirculation check valve,, bad gas control valve thermostat.
Feb 19, 2013 | General Electric GE SmartWater Household...
I have a GE smartwater reverse osmosis system model number GXRM10GBL02. Water leaks daily from the small hole on the faucet on my counter top. Any idea why water comes out that small hole? Otherwise the...
That is the drain for the reverse osmosis system. You have what is referred to as an AIR GAP faucet. The waste water is pushed up there before it goes to drain just as the drain for a dishwasher does. If water is coming out of the faucet the drain is most likely plugged or the line is kinked causing water to back up and overflow. Check the drain line for kinks and clean out the drain where it attaches to the stand pipe.
RJ
Oct 22, 2010 | General Electric GE SmartWater Household...
I have a GG40T06/487-246 GE SmartWater Water Heater, it is about 10 years old and now there is leak on the position of the stem of the reset button connecting to the gas valve. Any suggestions to replace...
A 10 year old water heater is at the end of its life expectancy. No sense replacing a gas valve to have the tank rust out next month. I'ld replace the whole unit. Also, install a drip pan, under it and a WAGS safety device. Any water in the pan and the WAGS will shut off he Water and Gas. If your water heater has an expansion tank near by, replace that too.
Jul 19, 2010 | General Electric GE SmartWater Household...
Sink tap has overflow going directly into the drain and constantly running. This is a reverse osmosis system that is outside warranty.
If you mean the little weep hole on the tap is leaking? If so, then the drain line connected to the sink drain is clogged. Remove this line and see if it's draining free.(have bucket ready) Most likely it will be where it enters your sink drain at that fitting, clogged with sink drain materials.
Jul 17, 2010 | General Electric GE SmartWater Household...
GE SmartWater RO Filter Tank Leaking?
I had same system under my sink for same amount of time and have since then removed entirely for health reasons related to Ro Systems. Mainly the tanks becomes contaminated [alge build up]and my faimly had constant nagging stomach aches which took a long time to resolve untill we decided to disconnected and throw out our "beloved healthy RO System" and decided to install a bi annual disposable type filter system. If you are expereanceing this I would advise the same as for the leak ,There are so many connections under there and it is usually not the tank but the fittings in lines some where and the reason it looks like the tank is because that is the lowest point the leak has traveled. So check all your fittings and if you decide on simple water filter I will advise you.
Please rate. Thanks jj505
jthomefix
gmail.com
Mar 28, 2009 | General Electric GE SmartWater Household...
Hot Water inconsistent
Something you can do, following your fathers logic,   is to attach a hose to the drain of the tank and run water from the bottom of the tank into a drain untill all the sediment is removed (Water runs clean). This is normally done once a year as preventive maintenance  on all tank type water heaters. The logic sounds good to me.
Feb 16, 2009 | General Electric GE SmartWater Household...
GE smartwater R.O. system making noise from hole on side of fauce
Probably some gunk clogging the drain line. First step would be to remove the drain line from underneath the sink and check to see that it is clear. If it isn't, the next thing that may happen is when it gets completely clogged, water will start shooting out of the weep hole. As an added measure< i would say to force compressed air down the weep hole to clean out any clog in the line that you can't reach.
Feb 13, 2009 | General Electric Profile Smartwater Ultra...
General Electric GE SmartWater heater problem
most units from GE come with a 3 year manufactures warantee and the home depot should have no probleme giving you a new one off the shelf with your receipt they will send it back and get there money back from GE so they pass it on to you. it would cost you the same amount to fix that one then to buy a new but yours is still under warantee untill july. hope it works out for you.
Jan 04, 2009 | General Electric GE SmartWater Household...
General Electric Profile Smartwater Ultra Plus Reverse Osmosis Membrane Logo
2,675 people viewed this question
Top General Electric Water Filters & Coolers Experts
Tom Chichester
Are you a General Electric Water Filter and Cooler Expert? Answer questions, earn points and help others
