Question about LG LRSC26944TT 36" 25.5 Cu. Ft. Side-by-Side Refrigerator w/ Digital LCD Display & Jet Freezing Draw...
Replacing funnel/funnel frame on LG fridge model # LRSC26944TT
Need to remove old funnel frame from freezer door,but cannot figure out how to get to it. How do you remove bezel on outside of door without breaking it ? Would like to findout how it all come's apart.
I am a year too late to help this person but also recently had to replace Funnel Frame on my LG Fridge model # LRSC26925SW. Literally just finished so sharing a quick tip. Not sure if it's same on all models but worth an easy shot. Tried the screw driver thing with no luck as it was just digging into the plastic even at the one little tab hole at bottom of the Frame... So instead, I stood to left of Fridge and cupped my hands around the edge of the door and into the left side of the curved part of the bezel (more towards the bottom) and simply pulled towards me and out away from door (almost like clamping my grip tighter) and the bottom portion popped open with enough gap to work the rest off gently by hand. Pull out from the bottom first and then slide the assembly down to release the top. Once you replace the funnel frame and are ready to reassemble, work the top of the Bezel with the display in first and slide upwards, you'll know when it's in the right place and then snap the remaining three sides a little at a time with the side of your hand (firmly if necessary). It didn't break any clips in case you are wondering... they are designed to release and clamp in that fashion... Ice dispenser now works as good as new... Funny part is all I "really" needed was the Funnel, but LG changed the part and it would only fit if I also replaced the Funnel Frame. Good Luck to the next person reading this!
Mike W
Posted on May 15, 2010
  • pat_kelly854 Oct 24, 2010
    Worked like a champ. Thanks
Mikwip has it perfect. Be gentle, but it works like a champ!
Posted on Aug 14, 2010
    President:
  • 1,136 Answers
Hi, This model# is not showing up but, most models have two smell gaps on the under side bottom edge and you need to use a flat screw driver and insert it into the gap and twist it so that it will realease.
Some older models had two very small screw on the under side of the bottom edge of the cover.
It is plastic so there is a chance it wil break but, it will come off. It might help if while twisting the screw driver, try pushing down from the top of the cover. Every time I have to remove this cover I worry about it breaking.
Just be patient while twisting the screw driver.
Please let me know if this helps you at all or if I can assist you further.
Vic
Posted on May 28, 2009
Can you replace water dispenser tube inside door from front display panel or you need to disassembly door from inside fridge?
Unless the tube is cracked and broken, there should be no need to replace it. Try sending a small amount of compressed air through the tube to clear a suspected blockage.
Jun 17, 2015 | LG LRSC26944TT 36" 25.5 Cu. Ft....
Why is there heavy ice buildup in our 2 year old LG bottom freezer refrigerator model LFX25970
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 24, 2010 | LG LFX25960 Bottom Freezer French Door...
We have a Lg LFC25760SW fridge and the lights stay on in side the fridge
LG had a circuit board malfunction with many french door models with fridge lights staying on with the door closed. the bulb lens usually overheats; deforms; and falls off. the plastic frame surround is warped too. the bulb sockets are darkened too. if this is the case, call LG and they will usually repair this overheating issue for free. you can just unscrew the bulbs for the meantime.
Jun 15, 2010 | LG LFC25760TT Titanium Bottom Freezer...
How do you replace the dispenser funnel on an LG Refridgerator model LRSC-26923
funnel itself squeeze in on sides to release tabs. so many tabs broke a redesign was made 5-30-2005 , have to replace frame bracket and funnell. models after tant had new design. part number from exploded view: 3016JA2002C funnel 278d location number exp. view
3210JA0006S frame 278b location '"" '' ""
Sep 10, 2009 | LG LRSC-26922 Side by Side Refrigerator
LG refrigerator - Need help replacing a part in the door.
How to install part ac110-115v for lg refrigerator
Jul 10, 2009 | LG Refrigerators
LG LRSC26925TT ice dispensing funnel broken
Yes. But LG came out with a new frame for the funnel. So you have to order the funnel and the frame which is installed through your front control panel. Good Luck I just did it.
Jul 08, 2009 | LG Refrigerators
There is water dripping filling up the bottom under the salad container. The model is a LRTN22311TT.
Remove contents of fridge and check the drain line running down the top back of the back of fridge and follow to lower section of fridge (usually a back ledge or under the crisper sections) and locate a small round drain hole. Also, check to see that the drain collector (funnel looking thing at top back of fridge section) is located under the freezer defrost drain opening, to allow water to flow through the fridge into the drain pan under the fridge.
If something has obstructed the drain funnel, path, tube, or lower drain hole, remove the blockage to allow water to drain into underneath of fridge into drain pan for proper evaporation of water produced from the usual daily defrost cycle of fridge/freezer.
If that is not the problem, it could be that you have a leaking water supply line for your ice maker and you'll need to see if the freezer is allowing excessive water to flow out of the ice maker into the fridge section.
Another simple check/solution is that the fridge is not properly leveled, meaning that the front of the fridge should be slightly higher than the rear to allow for proper drainage and self closing of the front doors. This will help keep the water flowing in the built in channels and drains.
A perfectly level fridge isn't the right way to install most moveable refridgerators, while built in fridges (Sub Zero, etc.) are designed for plumb and level installations for proper functioning and use.
Apr 09, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Have a 2005 model#LRSC26925TT LG fridge with front ice&water disp. and digital panel. Ordered replacement funnel and frame since mine is outdated and need to replace. Can we replace on our own and...
When you order the new replacement, did you ask the supplyer whether it can be replace the old panel? Sometime the wireing inside is different, I do not suggest you touch it unless you got the panel is completely same size and same founction and you know how? Otherwise it is a headache.
The panel must be right one.
Jul 21, 2008 | LG Refrigerators
Removal of broken funnel assembly and installation of new one
You will need to remove the front display panel to get into the funnel frame.  Look at the bottom of the frame and you will see a little slot to slide a screwdriver in.  With your screwdriver, insert it into the hole and pry gently.  You will hear snaps and cracks as it comes apart.  It may sound like the plastic is breaking but that is normal.  Once you remove the display panel, you will see the frame and just replace it with the new one.
May 12, 2008 | LG LRSC-26922 Side by Side Refrigerator
LG LRSC26944TT 36" 25.5 Cu. Ft. Side-by-Side Refrigerator w/ Digital LCD Display & Jet Freezing Draw... Logo
991 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
