Question about Tsurumi Pump s Submersible Trash Pump - 3000 GPH, 1/2 HP, 2in., Model# HS2.4
Pump trips breaker
Pump runs for a few minutes then trips GFI. Will start right back up then trip again, runs fine no noise.
If the seals are damaged, water will leak into motor section and cause GFI to trip and yet the pump will seem that it is running fine if plugged into a non-GFI receptacle
Posted on Jun 12, 2009
    Problem Solver:
  • 5 Answers
May be drawing to much power on your breaker check voltage and amps that pump uses, should be in owners manual
Posted on May 28, 2009
Not cooling
is the freezer plugged into a gfi outlet? outlet may have tripped.
if there is power to the unit: (light on, fan running, etc.)
a large clump of frost around the lines/ top shelf, means it could be a leaker and will need to be replaced.
a clicking, humming noise repeating every few minutes could be a compressor start relay.
if the freezer has tripped the breaker, the compressor has developed an internal short and again would have to be replaced
Oct 31, 2013 | Freezers
GFI breaker tripping
It could be a faulty pump,
rusty pump & moisture on copper windings leaks active, neutral back to earth on your pump & trips your breaker.
Solution: Replace pump.
Aug 21, 2013 | Fisher and Paykel Washing Machines
I have a kohler bath jet tub. When I push the button the motor tries to start and then trips the gfi breaker. Thought maybe it was the gfi breaker and replaced it. Wasn't it. I took out the gfi breaker and...
Did you try an electric motor rebuilder? $500 seems too high to repair a motor. Motors have either a capacitor or dual windings to get them started and it sounds like yours has failed. Get the numbers off the MOTOR and call a motor rebuilder in your area for pricing.
Gary
Jan 24, 2011 | Kohler Home
Colman Spa trips GFI what is most common problem? GFI test good. Pump disconnected still trips, is heater most likely? Can you replace only heater? thanks
this should be simple ...
1.shut off the power
2.disconnect wires to heating element
3. turn power back on and see if it works if so replace heating element 45-95 dollars
if it still trips unplug all the cables from the pumps blower ozonators and see if it runs now,,,, if so plug each cable back (one at a time) until it trips again.if it trips that the problem pump etc.
99 percent of the the time its not the gfi its a device that is wet or shorted out ..Try everything else before replacing the gfi
Dec 31, 2010 | Balboa Instruments BALBOA 30kW HEATER ASSY...
Pump plugged in to grounded receptacle trips the
If by "trips the breaker" you mean the GFI then you are leaking current to ground, GFI's trip when there is an imbalance between the current going to the motor on the HOT side and returning from the motor on the NEUTRAL side, if it is tripping the GFI it is likely the sign of a failing motor.
May 27, 2010 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
I have a AquaScape 4500 GPH Pump it has worked fine. Today I spent all day cleaning out my pond. All I did was lift the pump out of the pond and spray the muck off it. After completly cleaning the pond and...
Where the wire goes into the pump there is a o ring thatis probably leaking and any sort of water the motor might be getting is tripping the breaker. You probably have it plugged into a gfi and it sense very low amounts of water, and trips, You can determine by plugging it into a regular outlet and it should work. But definently fix the oring at the point of entry on the pump
Apr 17, 2010 | RTO AquaScape 4500 GPH Pump
The pump keeps tripping the GFI. We have cleaned
How long have you had this pump? Have you had it long enough for the bushings and bearings to go bad. Have you added anything else to that line that feeds the breaker. that feeds this pump If you tell me thies things i can give you a much better awnser
Aug 08, 2009 | Savio Water Master Solids Handling Pond...
Rule H53sp-24 pool cover pump trips GFI breaker
GFI devices are prone to degrade over time. Also, when used outdoors there are additional moisture issues that may cause sufficient current leakage to trip the breaker.
I had a similar problem this Spring. I was using a 20 amp GFI "master" outlet that protected two additional outlets 'downstream' of it (wired to the 'load' terminals on the GFI outlet- I'd have the check the doc. to see what terminology was used here). The pump was plugged into one of the downstream outlets.
Replacing the GFI seemed to solve the problem. I did ante up $20 for an 'outdoor' model of the 20 amp GFI unit, several bucks more than the standard 'indoor' unit - have no ideal if that represented additional value or not.
Note also, that this is the third such pump I have used for my pool cover. The other two failed to come on at all after about a year's use. The mfg replaced them under warranty (I may have had to send back the old pump - I forget!).
Curtis
Mar 22, 2009 | Rule H53sp 24mgra Swimming Pool Cover Pump...
GFI for pump keeps tripping...
no you need to put 60amp breaker in house panel box
Jan 15, 2009 | Beckett Water Gardening Beckett Statuary...
Tsurumi Pump s Submersible Trash Pump - 3000 GPH, 1/2 HP, 2in., Model# HS2.4 Logo
898 people viewed this question
Top Tsurumi Pump Plumbing Experts
Donni Steen
Tom Chichester
Are you a Tsurumi Pump Plumbing Expert? Answer questions, earn points and help others
