Question about ESA ET427E 27" TV
Input channel with no remote
So I have this tv and i can't get to the input channel ( only have universal remote not org) how to change the input to audio video without the remote?
  • 864 Answers
You should be able to select the AV input with an Input or Menu button on the front of the TV.  If there are no arrow keys the Channel and Volume buttons may provide up-down-left-right action.
Posted on May 28, 2009
How to change input on tv without a remote
Which TV do you have? Some will have an Input or Source button on the front panel. A few will have an option to change the source from the menu. Both of these options require the front panel lock to be inactive.
A few older TVs allowed you to find the A/V input by pressing Channel Down on the front panel buttons until you passed channel 2 (or Channel Up until you nearly reached Channel 2). This option wouldn't work if the A/V inputs had been deleted when someone minimized going through unused channels.
If the Source or Input button was only available on the remote, you will need a universal remote that includes this feature. These cost a bit more than the lowest end remotes. Then you will have to try all of the codes to find the one that makes the Source button work with your TV. (Several codes may work for On/Off but not the change input.) The Universal remotes that can be programmed from a computer (USB connection) will be the easiest to set up. Remotes.com may have a replacement original or substitute remote for your TV that should work for all of the TV functions.
I hope this helps. Please add a comment with the TV make and model for specific options for your particular TV.
(low end TVs usually only had the Source/Input button on the remote.)
May 12, 2012 | Sony Televison & Video
How do i get to the different inputs on Admiral Tv
Original remote only here---Universals are far from Universal.
Apr 17, 2012 | Televison & Video
I have lost the orignal remote for my tv and have a universal remote. I get the tv/video button to work. is there some way to change it with out using the remote?
Unfortunately, the Input button (to change the source from INPUT 1, INPUT 2,
INPUT 3, INPUT 4, Front Input, HDMI/DVI, and last-active channel) is only on the remote. If your universal remote was built 6 months after the TV was released, try a different code for RCA/Thomson TVs (assuming the remote has an input or source key). Thomson built the TV.
If your universal remote doesn't have an input key, you probably need a higher end remote (one with that key or one that can be programmed from a computer). Alternatively, you can get an exact replacement remote here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=HD52W58&uuid=12927154203570 .
I hope this helps.
Dec 18, 2010 | RCA HD52W58 52" TV
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
Toshiba 27a45
yes a universal remote will work but you may need to try several to find one that will, not all work to select your inputs. first try changeing the channel below channel 2, thats were most tv inputs are located (accessed)..
Jul 20, 2009 | Toshiba 27A45 27" TV
Lost remote control for an emerson tv. how do you change input from channel to video without the remote?
I just purchased one of these televisions and it didn't come with a remote. However, a Philips Universal Remote (SRU2103/27)
with a code 0520 works fine. I haven't explored all the codes but I can easily change from tv stations to Video 1 and Video 2 merely by pressing the "Input" button on the remote.
Jun 17, 2009 | Emerson EWF2006 TV
Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
Jun 13, 2009 | Sylvania 6420FB 20" TV
Lost remote
with a code 0520 works fine. I haven't explored all the codes but I can easily change from tv stations to Video 1 and Video 2 merely by pressing the "Input" button on the remote. Another reply mentioned using a duraband model instead of Emerson and it worked for him.
Apr 20, 2009 | Emerson EWF2006 TV
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Mar 16, 2008 | Toshiba 24AF45 24" TV
ESA ET427E 27" TV Logo
2,153 people viewed this question
Top ESA Televison & Video Experts
Colin Stickland
Colin Stickland
matt martin
matt martin
Are you an ESA Televison and Video Expert? Answer questions, earn points and help others
