Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Fridgidaire Electrolux Professional Series Oven, not preheating
I have pressed (in error) the LOCK feature and now my oven door will not open and the lock indicator is on the display. Most of the buttons with the exception of the cooktop, oven light, timer and clock, will not work..just beep when I press them. When I turn on the oven to preheat, sometimes it does nothing, or eventually warms up a little bit. The broiler works very well though.
  • 864 Answers
The model number listed in your problem is a refrigerator.  Go to:
http://www.frigidaire.com/manuals.aspx
and enter the model number of your range/oven unit to find the user manual.
On my GE range I only have to press and hold the LOCK button for several seconds (until it beeps) to unlock it.
Posted on May 28, 2009
I cleaned the oven self clean, now the oven preheat feature won't turn on
I don't know what kind of range you have or if it is gas or electric. You may have to call a repairman.
May 25, 2015 | Kitchen Ranges
Control lock preventing the operation of the stove
Hi Bruce, this is AP!
I understand you are struggling with the lock feature on your Electrolux duel fuel range, model EW30DS65GS. In order to cancel the Control Lock feature, press Control Lock and hold for 3 seconds. The control will unlock the oven door and resume normal operation.
This door lock feature is activated by pressing Control Lock and holding for 3 seconds. The Door Lock indicator light will flash for 20 seconds until the door has finished locking. Do not attempt to open the door while Door Lock is flashing, this may result in the door locking open.
This information is also located in the owner's manual should you like to view it again, you may retrieve a manual using your model# and the following link http://www.electroluxappliances.com/Owner-Support/Product-Support/
I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Thanks,
Apr 02, 2014 | Electrolux EW30DS65GS Dual Fuel (Electric...
The door on my frigidaire professional series will not lock on cleaning cycle. oven stops the self clean cycle because the door is not locked???
Hi Glenn, thank you for allowing me to assist you!
Based on the symptoms you are describing, you may either have a communication error from the EOC (electronic oven control) or faulty door lock assembly. Let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn your range on. If resetting the power does not correct the issue, at this point I would highly recommend reaching out to a service technician who would be better able to assist you in the diagnosis and repair of your range. You can often locate an experienced technician in your area by going to the manufacturer website.
Dec 03, 2013 | Electrolux Frigidaire Professional Series...
I went to clean my oven last night but my oven door wasn't latched. I started the cleaning and the word "door" flashed on the screen. Sure enough my door was not fully latched but the lock mechanism had...
HELLO,
HERE ARE SOLUTIONS ON HOW TO CLEAN THE OVEN OUR SELF
self cleaning solution
  • 1 Remove oven racks and soak them in soapy water
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on food.
  • Fast Cleaning method
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently. 6 Dry with a soft cloth
  • hope this solution help?
    Thanks.
    Sep 20, 2010 | Frigidaire 30" Self-Cleaning Slide-In...
    F90 code on Fridgidaire range/oven
    F90 Maximum oven door unlock time exceeded.
    F91 Maximum oven door unlock attempts exceeded.
    F92 Maximum oven door open time exceeded.
    F93 Maximum oven door lock time exceeded.
    F94 Maximum oven door lock attempts exceeded.
    1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
    2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
    3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
    4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
    5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
    6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
    7. If all situations above do not solve problem, replace EOC.
    F90 is a door lock code, Try this...
    unplug the range.
    wait 1 minute.
    turn the range back on,
    then while holding in on the oven door.
    start another self clean.
    wait 2 minutes.
    then cancel the self clean.
    do not release the door until the door lock light goes out.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Jan 04, 2010 | Frigidaire FEF352 Electric Kitchen Range
    I have modle 465 oven about 10 yrs old and it is a self cleaning oven. Anyways I preheated the oven 450 and the door locked and I can't get it opened.
    the safety lock engaged, then got stuck, a common problem. try banging around the door with your hand and press and pull the door
    Jul 10, 2009 | Ovens
    Frigidaire professional series electric oven door won't open
    MY OVEN DOOR WONT UNLOCK ON MY FRIGIDAIRE PROFESSIONAL SERIES STOVE 31606390
    Jan 22, 2009 | Electrolux Frigidaire Professional Series...
    Self-cleaning error message f90
    unplug the range.
    wait 1 minute.
    wait 2 minutes.
    Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
    New fridgidaire self cleaning oven w/ no insturction manual
    its a new oven?? press the clean button the arrow up(the display should read 3:00, press start,the door will automatically lock and your on your way. remember to remove racks first, they will warp and discolor
    Feb 24, 2008 | Ovens
    Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
    503 people viewed this question
    Top Frigidaire Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
