Question about Sony ICF-2010 AM/FM/SW Radio
ICF 2010, no sound suddenly
Sony ICF 2010 suddenly no sound. All else seems normal. Have used radio shack 4.5 v AC adapter for few years. Any suggestions much appreciated. AL
When I use AA batteries, it works fine. However, as soon as I plug in my Radio Shack AC Adaptor it shuts down. I bought another adaptor, no help. I have made sure that the input voltage polarity is correct. So I'm back to using batteries....works great with batteries. I checked across the power input of the radio with a high impedance ohmmeter....no short evident. I guess the only solution I can suggest is to get an "official" Sony AC adaptor instead of the Radio Shack version.
Posted on Oct 04, 2012
  • 494 Answers
If the radio does not work with headphone then the external jack for audio may have broken loose from it's soldered points. Simple re solder may make the repair. Beyond that it would have to be diagnosed by a technician.
Posted on Feb 09, 2010
Sony icf sw7600gr won't power up on battery power and showing exhausted battery symbol,only on ac adapter will work
check the connection inside the radio, switch of AC-DC connector maybe loose contact.( leak diode more probability replace it)
Nov 09, 2015 | Sony ICF-SW7600 AM/FM/SW Radio
I have had a Sony ICF SW7600 for the last 18 years. Now, it only wishes to work on batteries and not on the AC adapter anymore. What can be the problem and how to fix it
I have the exact same problem here in Europe with my perfectly with my Sony shortwave after 18 years. If I fiddle with the ac adaptor in the radio plug, it works for a while. I have replaced and soldered the yellow tip adaptor twice in 18 years and hopefully the problem is with the power plug and not the radio plug.
Any help is appreciated.
Dec 20, 2012 | Sony ICF-SW7600 AM/FM/SW Radio
Sony ICF-SW35 needs an AC adapter. 220VAC in, 4.5
CLICK HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2010 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
I have a Sony icf 2010. No sound, but white noise.
AA batteries need replacing or the contacts are corroded and one more, the PC board is connected to the AA negative post by a wire that touches the pad on the PC board. Sometimes it will lose contact because of oxidation or corrosion, to fix this a wire soldered is best but just repositioning the wire will make the cure. Requires removal of the circuit boards.
Jan 20, 2010 | Sony ICF-2010 AM/FM/SW Radio
Replaced batteries, checked good proper polarity. Everything but clock is dead and error 3 message but no AC adapter is present.
A tad late on this ..... the power jack may have developed a break from the power board under stress. Resoldering might be the solution. Second may be the contacts are not making contact or corroded.
Nov 05, 2009 | Sony ICF-2010 AM/FM/SW Radio
I have a Sony ICF 2010 (for over 20 years) and when I turn it on, the only reception I get is on the FM frequencies (+ aircraft freqs). Thank you. Alex
Late answer on this.... There is a FET problem with older radios and this could be the problem. Static can "zap" the transistor making the radio deaf on receive in the AM modes.
Aug 24, 2009 | Sony ICF-2010 AM/FM/SW Radio
Use Sony ICF-C1IPMK2 in Europe
A transformer type (Linear Mode Power Supply) AC to DC power adapter with a 9.V nominal output, measures about 12.V without load when tested with a multimeter. A power adapter with a nominal output of 7.5 V, measures a little over 9.V. Considering a number of people across different forums reported the adapter's measured power output as 12.V, I think the nominal rating of the AC to DC adapter should be 9.V. However, keep away from Switch Mode Power Supplies.
Jul 21, 2009 | Sony ICF-C1IP White Powered Speaker System...
NO POWER AC OR BATTERIES
May be a bad power adapter solder joint on the side of the radio. Email me with any questions at.... poikaa@yahoo.com
Apr 21, 2009 | Sony ICF-2010 AM/FM/SW Radio
Sony ICF 2010 Shortwave scan does not scan, it beeps.
It will not scan blank memories and it will not scan on search function till you specify a frequency range.
Rod
Jan 30, 2009 | Sony ICF-2010 AM/FM/SW Radio
Sony ICF-2010 AM/FM/SW Radio Logo
317 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
