Question about Apple iPod nano
Ipod 4 GB not charging and gets very Hot when I try to charg
Won't charge when I try it gets very hot...either on computer, ac or on a port...tried different usb connections all hot and won't charge ipod gets hot when itry to charge
2 Suggested Answers
SOURCE: Ipod 4 GB not charging and gets very Hot when I try to charg
my nano 4gb ipod gets hot when i try and charge it on conputor ac ports it gets hot
Posted on May 28, 2009
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
I have the Insignia HD camcorder, this is the second one I have and the second time I have this problem. The first couple of times it charges, then I don't use it for a couple of months, try to charge it...
Have you tried using an AC to USB charger?
I know that some products that charge through a USB port are not able to completely and correctly charge from the computers USB port because it is undervolted for what the device needs. (I have the same issue with my cell phone).
Also, may of a computers USB ports will power enough for data transfer, but not enough for charging the unit.
Try using an AC to USB power supply and not the computers USB ports.
Hope this works!
Apr 07, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
I had my ipod on a dock its been on for a year now and when i woke up in the morning it was really hot and didn't charge. Ever since then when i put my ipod nano on either the usb port on my computer or my...
it looks like that ur docks charging coil has burned out and its basically bcuz of u not taking it out from the switchboard.this has damaged the rechrging coil and this may also hav effected ur ipod.i dont understand the part that th ipod charges in ur truck???
May 04, 2009 | Audio Players & Recorders
Mar 18, 2009 | Apple iPod nano
Hie..m vikram i hav apple nano 4 g black... i used it whole day...n ma baatery was almost low... then i kept it 4 charging... first a sign of apple came....n then nthing appeared on it.... i kept it...
HI Vikram,
What you can do is connect ipod to ur computer usb port ( desktop: connect it at the rear usb port for charging) Then try reseting it Menu and select button for 6 to 8 secs,... see Apple logo and try using it :)
Jan 23, 2009 | Apple iPod nano 8 GB Pink (3rd Generation)...
Apple ipod not getting charged
First, please check your connection (I'm sure you have already done this). Make sure that the cable is plugged in and working on both ends.
If that is fine, I would recommend taking it back and getting a new one. If you just recently purchased it, you should be able to return without a problem. It sounds like you might have a defective product and you don't want to get stuck with it after the return period.
Good news is that when you get the new one, if you use iTunes, it will automatically sync up and you wont have to manually load songs.
Hope this was helpful but if you still have questions, let me know.
Have a great day
Nov 13, 2008 | Apple iPod nano
30 GB iPod went blank
You have to plug it into your computer and reset the Ipod
Sep 02, 2008 | Apple iPod MA446LL/A MP3 Player
My ipod will not charge on the docking station
my ipod wont charge. it shows the charging icon, but when i take it off the charger it dies like it didnt charge at all
May 05, 2008 | Audio Players & Recorders
Ipod will not recharge
See if anybody at you job has an Ipod and use there battery charger. It may be the battery charge and not the Ipod.
Jun 24, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
247 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
